going from a brake hard line to AN - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-25-2008, 06:59 PM   #1 (permalink)
X-Rated's Avatar
Member # 72707
What are you doing to go back and forth from hard brake lines to AN soft lines? I am redoing my brakes and going to put a bunch of hard line in. I ran soft everywhere and regret it. So anyways. I need to convert from 1/4" hard line to -4 AN and back a bunch of times. I know I could use a 45 degree fitting on the hard line, and then a flare to an adapter, and then a an fitting.
I was hoping there would be something that takes out the middle adapter fitting...
X-Rated is offline   Reply With Quote Quick reply to this message
Old 03-25-2008, 07:04 PM   #2 (permalink)
Member # 3547
http://store.summitracing.com/partde...5&autoview=sku
Fitting, Brake Adapter, Tubing Adapter -4 AN to 7/16"-24 IF, Steel, Zinc
BillaVista is offline   Reply With Quote Quick reply to this message
Old 03-25-2008, 07:46 PM   #3 (permalink)
Member # 56456
So your saying youve got 45 degree hardline? I just did single flare with tube sleevs and nuts and a union to my softline. Those are nifty brakeline to an flare though!
74 f100, 4bt, 3link hp 60/14 bolt, welded f/r np435/205
Fordman500 is offline   Reply With Quote Quick reply to this message
Old 03-25-2008, 07:56 PM   #4 (permalink)
Member # 20092
Rol-Air 37 degree single flaring tool. It's what the airplane hobbyists use. Makes nifty 37 degree AN flares so you will only need the 1/4 tubing, tube nuts, and sleeves. I just finished re-plumbing my jeep and it was a piece of cake. I will never use inverted flare again.
'94 Toyota Land Cruiser FJZ80 - Vortec L33 5.3l, 4L60e, elocked, 3" OME lift, 315 KM2s, Warn 8074.
rock-rod is offline   Reply With Quote Quick reply to this message
Old 03-25-2008, 08:16 PM   #5 (permalink)
ROKRAPR
Diablo169's Avatar
Member # 63382
Send a message via AIM to Diablo169
I've been runnig 45* flare to AN fittings for over a year with no problems. Why you might ask, cause I had to get my Jeep ready for the con and only had a few days and couldn't source a 37* flaring tool. But they have worked fine so far. I plan to redo them soon however.
Why are you running 1/4"/ AN #4 brake lines?
"14 Bolt don't give a shit. It takes what it wants."
-Little Sluice Memorial Weekend 2012
Diablo169 is offline   Reply With Quote Quick reply to this message
Old 03-25-2008, 09:00 PM   #6 (permalink)
Erik D_lux's Avatar
Member # 1007
They make a compression to AN also. Look on summit. They have just about every fitting you would want.
www.DLUXfab.com
Erik D_lux is offline   Reply With Quote Quick reply to this message
Old 03-26-2008, 04:23 AM   #7 (permalink)
X-Rated's Avatar
Member # 72707
the mog calipers use 6mm/.25" hard line to get in them, so when I was plumbing it I already had to use 1/4" for part of it, so I said hell with it and used 1/4" for all of it.
Old 03-26-2008, 04:29 AM   #8 (permalink)
X-Rated's Avatar
Member # 72707
Do you have a link to the tube nuts and sleeves you are talking about? I can find a 37 flare tool, but dont know what nuts and sleeves you are talking about.
Old 03-26-2008, 04:38 AM   #9 (permalink)
X-Rated's Avatar
Member # 72707
http://www.sdindustries.net/37-degre...-fittings.html
something like that ???
Old 03-26-2008, 07:33 AM   #10 (permalink)
Union Fab Works
carwash's Avatar
Member # 21939
Send a message via AIM to carwash Send a message via Yahoo to carwash
hey x-rated, what didnt you like about your full flex line system? spongy? what type of brakes, calipers, master cylinders, etc?
thanks
carwash is offline   Reply With Quote Quick reply to this message
Old 03-26-2008, 08:27 AM   #11 (permalink)
under_psi's Avatar
Member # 39348
Send a message via AIM to under_psi
i recently scrapped the hardline and adapters like you are stating...
decided to go with -3 HP SS flex line, and i actually saved $$...those fittings are $$$....hope i dont regret that....lol....
[FONT="Times New Roman"][COLOR="Lime"][B]
[/B][/COLOR][/FONT]
under_psi is offline   Reply With Quote Quick reply to this message
Old 03-26-2008, 08:38 AM   #12 (permalink)
Shameless Racing
rolloverboy's Avatar
Member # 82154
speedway motors
any line or fitting you need for just about any brake system
W.E.Rock
Pro-mod #734
RCrocs
2014 Class III Champions
Thanks to my wife and daughter, Ray,
, Town Line Auto Salvage
rolloverboy is offline   Reply With Quote Quick reply to this message
Old 03-26-2008, 09:11 AM   #13 (permalink)
X-Rated's Avatar
Member # 72707
well, I have more problems than just that. I am trying to stop 49s, with a real low crawl ratio and a vacum booster. Stock mog calipers.
I am going to swap out the vacum booster for a Vanco hydroboost first and see how that does. if it still feels spongy, I will redo the soft lines...
Old 03-26-2008, 09:43 AM   #14 (permalink)
Member # 20092
Here you go
Tool:
http://www.aircraftspruce.com/catalo...ringtools3.php
You want the 507-FB tool.
-4 tube nut:
-4 tube sleeve:
http://store.summitracing.com/egnsea...=KeywordSearch
make sure you use all steel tube nuts and sleeves. Do not use aluminum. You can use a bulkead union to secure the hard line section to the frame, ect and then connect flexible braided line to the hard lines.
Old 03-26-2008, 11:02 AM   #15 (permalink)
Eskimo's Avatar
Member # 10429
I used a tube nut from discounthydraulichose.com that didn't require a sleeve.. leak free, steel, and cheap..
Just ran that to a -4 union.
FJ-40 Cruggy - tuned 5.3/4WS rockwells/linked/ORI's/42's - Sold.
Eskimo is offline   Reply With Quote Quick reply to this message
