"Conquistador" ¯the Mexico build - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-02-2008, 08:47 AM   #1 (permalink)
Member # 87218
"Conquistador" …the Mexico build
The word is out that we are working on a pretty “cool” build (no pun intended). This will not be a typical rockcrawler meant to tackle a few hours of trails and return back to the trailer. The idea is to build a very universal rig that will see a lot of trail time, sometimes 5 to 6 days out before returning. During these trail runs the rig must be able to crawl and climb the toughest of obstacles, yet be able to do some pre-running in the deserts of Mexico at the same time… A true all purpose “Dual Sport” rig. ...Oh, and it's going to be street legal too.
Before we even get started I want to thank all the companies and individuals that are working with us on this build.
On to some specs:
Chassis
This will be a one off chassis that was originally designed for myself but will likely be added to our lineup soon.
It will be a 2 seater with lots of room in the passenger compartment for days of comfort on the trail
and a little extra room for all the gear. It will be 58" wide at the cowl, 20" belly at ride, the rockers will have 30" of clearance at ride, the top of the cage will be around 71" at ride. WB will be 111"
Engine
The engine is from TurnKey Engine Supply. 390hp all aluminum LS1 with the LQ9 intake
Transmission
Part of the fun in driving is shifting gears… the owner wants it to be a manual.
What better choice than a Dodge NV4500 (5speed) with 6.32 first gear.
The input shaft has been swapped to the chevy style and an adapter from
Advance Adapters gets the output converted to 23 spline
with the traditional 6 bolt round pattern.
Transfer Case
We are working with Tony at Stak to be the first recipient of a passenger side drop 3 speed mini case.
Gears will be 4.29:1 / 2.44:1 / 1:1 we added the parking brake, speed sensor, and HD case support.
Tires and Rims
Nothing less than 40”x15” Nitto Mud Grapplers mounted up on a set of 20”x10” Spiderlocks from Poison Spider Customs
Axles
9" housings narrowed to 62.5"WMS
front has SOLID inners with 1995 Ford F350 outers
the tops of the knuckles have been machined for highsteer arms that line up with the stock Ackerman arms. TERA 35 spline drive flanges. YUKON 4340 35 spline axles (inners, outers, and custom rears... all cut down and resplined for the axles. The front will use stock F350 one ton brakes and the rear is set up with chevy 3/4 ton calipers already. The bottom of both housings have already been shaved for additional clearance, and of course they will get trussed up for strength...
Gearing
Front … due to the amount of up travel we are after I’m not sure a Hi9 will work, so if it doesn’t I talked quite a bit with Mike and Chris at TruHi9 about a backup plan. Turns out I can get a Nascar third with 5.42:1 gears (polished, lightened, and hardened) with a 35spline pinion to match up nicely and still have the strength and reliability we are after. I’ll fit it with an ARB in house. For the Rear, Mike set us up a MEGAHi9 with 5:40 gears and an ARB. We know going into this that the ARB will be our week link in the axles… but keep in mind, This is a dual sport rig, and the owner wants to keep it a long time. He’s not likely to be quite as hard on it as a competitor.
Drive Shafts by Tom Woods
Steering
Lance at PSC has been working hard to put us together a system that will meet our demands of higher speeds and streetability just for this build… Of course it includes nothing less than the best stuff they offer.
Suspension
A very special thanks goes out to the guys at Polyperformance for working with us on getting the shocks set up to our needs… they in turn are working with Racerunner directly to get us dialed in and set up to perform the way this buggy will demand. I can't say enough how cool these guys are to work with and helpful they have been.. Here is what we have put together…
Front -3 link design with DOM control arms and QA1 heims. Dampening will be controlled by 14” 2.0 Racerunner coilovers, remote reservoirs, triple rate springs, and Racerunner 2.0 bumpstops with 2.5” stroke. Travel will be setup for 45% bump.
Rear -4 link design with DOM control arms and QA1 Heims. The rough stuff will be controlled by 16” 2.0 Racerunner emulsion coilovers set up to be triple rate coil carriers, 2.0 16” Racerunner external bypass shocks will help with dampening along with 2.0 Racerunner 4” bumpstops and a Currie Sway bar should handle anything we throw at it. Travel in the rear will also be 45% bump.
There is a thread in the desert section discussing “Suspension Geometry for Getting It” created during the design process for this buggy.
Creature comforts
Master Craft seats
Crow Harnesses
Wilwood pedals
Custom roof rack
Spare tire carrier
Speed Glass windshield
Enclosable soft top by Draper Customs
and A/C…. because this buggy wouldn’t be “cool” without it
Enjoy -Tim
CHECK OUT OUR NEW DIY CHASSIS KITS at
Want to see what's going on in the shop?
Bent Fabrications is offline   Reply With Quote Quick reply to this message
Old 08-02-2008, 08:49 AM   #2 (permalink)
larboc@hotmail.com's Avatar
Member # 70148
Sounds quite bling, when pics?
I don't pay nothing for anything.
larboc@hotmail.com is online now   Reply With Quote Quick reply to this message
Old 08-02-2008, 09:16 AM   #3 (permalink)
under_psi's Avatar
Member # 39348
Send a message via AIM to under_psi
sounds good except the mud grapplers.....
[FONT="Times New Roman"][COLOR="Lime"][B]
[/B][/COLOR][/FONT]
under_psi is offline   Reply With Quote Quick reply to this message
Old 08-02-2008, 09:18 AM   #4 (permalink)
Member # 87218
Steel racks are loaded
Old 08-02-2008, 09:19 AM   #5 (permalink)
Member # 87218
Engine is here
Old 08-02-2008, 09:20 AM   #6 (permalink)
Member # 87218
Axles
Old 08-02-2008, 09:22 AM   #7 (permalink)
Member # 87218
Mega9
Old 08-02-2008, 09:25 AM   #8 (permalink)
Member # 87218
Rims and Tires
20"x10" Spiderlocks with 3.5" backspacing... Tires are 40" Nitto Mud Grapplers
Compared to my 35" Baja Claws...
Old 08-02-2008, 09:27 AM   #9 (permalink)
Member # 87218
Suspension parts
I'm still waiting on a lot of stuff but things are trickling in every few days... here is what just came.
Old 08-02-2008, 09:39 AM   #10 (permalink)
Member # 87218
We've started laying out the platform of the chassis... It's based off of our 4 seater (4Play) but has a few changes. I'm going to build slightly out of order so pics and progress will be slow until more parts come in.
Starting with the "frame rails" and building the "subframe" to the dimensions needed for the chosen drive train. We have also already set up the bracketry for the upper links for the four link in the back. Also the front bracketry is done for the lowers and pass side upper of the 3 link.
Rear uppers
Front
This chassis is meant to be as comfortable as possible in the woods... including getting in and out. With that in mind, some rockers that serve as a small step will both protect the bodywork and make getting in and out a snap!
Old 08-02-2008, 09:40 AM   #11 (permalink)
Member # 47730
i love those wheels...20's are the in now. looks like a sweet ride.
a bunch of tube.a v8 and other stuff..
2nuts4u is offline   Reply With Quote Quick reply to this message
Old 08-02-2008, 11:32 AM   #12 (permalink)
Member # 45977
Those axles look good!! Do you plan to build anymore protection for them?
twentyfootdaredevil is offline   Reply With Quote Quick reply to this message
Old 08-02-2008, 11:49 AM   #13 (permalink)
Member # 87218
Both axles will be getting the full treatment. I'm going to try to keep it simple and effective.
-Tim
Old 08-02-2008, 03:58 PM   #14 (permalink)
Member # 100827
Send a message via AIM to smewhtguy
Will be following this one, love the mud grapplers mine have 17,000 miles on them and still look new and perform great offroad.
I do math and stuff, on a professional level.
smewhtguy is offline   Reply With Quote Quick reply to this message
Old 08-02-2008, 04:01 PM   #15 (permalink)
Member # 87218
Call me old school.. but I still like to do a lot of design by hand.
Here's an idea of what the chassis will look like...spare tire will be carried slightly different..
A little bit of suspension analysis by hand...
Old 08-02-2008, 04:07 PM   #16 (permalink)
nhgpnut's Avatar
Member # 42521
Send a message via AIM to nhgpnut Send a message via Yahoo to nhgpnut
What are your plans as far as street legality goes? I would think you would need a VIN# and all the requirements of that years VIN'S regulations. Cool build either way.
If you have it, a truck brought it. Without trucks,you would be naked and hungry.
nhgpnut is offline   Reply With Quote Quick reply to this message
Old 08-02-2008, 04:18 PM   #17 (permalink)
Member # 87218
The buggy will have a 2008 VIN from Kentucky DOT... It will be declared a brand new vehicle when imported into Mexico. After it's imported it will have to be inspected in Mexico for licensing. If it were staying here in Kentucky, it would have to be inspected here and pass local laws (which are VERY lenient in KY). Each state is different... anyone trying this will definitely have to look into there local laws.
One of the coolest things about getting a new VIN for a chassis is that the vehicle can be classified as a recreational vehicle (like a boat) and most people can get a 10 year loan on it (like a boat).
-Tim
Old 08-02-2008, 04:27 PM   #18 (permalink)
Member # 87218
I've worked through some of the design in Bend Tech Pro also... It's not exactly what I'm building but close enough to see what's happening. These are views of 2 different chassis that I bounced back and forth with the customer to get to our final design above on paper.
Old 08-02-2008, 04:28 PM   #19 (permalink)
pipehitter155's Avatar
Member # 73680
-Tim
That's pretty cool....buggy looks likes it's gonna be super rad too...
pipehitter155 is offline   Reply With Quote Quick reply to this message
Old 08-02-2008, 04:31 PM   #20 (permalink)
ItsaCJ6's Avatar
Member # 6340
Sounds cool. I'll be watching.
shameless plug.....For the best deal on 8 lug disc brakes click here-->
Marc
In what appears to have been an understatement, the plant operator described the situation at the Number 4 reactor as "not so good."
Love and kisses, Zaphod..
ItsaCJ6 is offline   Reply With Quote Quick reply to this message
Old 08-02-2008, 04:50 PM   #21 (permalink)
Member # 87150
Subscribed, should be a bad ass buggy when done.
[QUOTE=Dieselmh;11422920]This thread is like McDonalds. It fucking sucks and doesn't deliver. :([/QUOTE]
maxyedor is offline   Reply With Quote Quick reply to this message
Old 08-02-2008, 05:17 PM   #22 (permalink)
Member # 80470
x2
DESracing is offline   Reply With Quote Quick reply to this message
Old 08-02-2008, 05:20 PM   #23 (permalink)
Diesel_Dirk's Avatar
Member # 106806
Subscribing.
Diesel_Dirk is offline   Reply With Quote Quick reply to this message
Old 08-02-2008, 06:04 PM   #24 (permalink)
Member # 85316
Send a message via AIM to svt150j49
awsome!
1996 F150 - Supercharged 5.8L, E4OD, Vortech S-trim, PSD Intercooler, 15 psi :eek:, 1356, Dana 60, 10.25, 5.13 gears, welded rear diff, 14" Air/Coilovers. Check it out:
Build thread::evil::grinpimp:
The un-named buggy - 2.3L, lotsa tube, and FJ80s. :grinpimp:
svt150j49 is offline   Reply With Quote Quick reply to this message
Old 08-02-2008, 08:39 PM   #25 (permalink)
TEEJ's Avatar
Member # 45783
Gotta love KY laws . How's it gonna get to Mehico?
'84 Runner. 4D's.
TEEJ is offline   Reply With Quote Quick reply to this message
