Anti-wrap bar, backwards? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-28-2009, 02:03 PM   #1 (permalink)
Dinkerdoodledoo
Member # 10448
Send a message via Yahoo to Grendel
I searched.
So, I have a buddy's Ford F350 here. With the exhaust and diesel tank, there is NO way to get a cross member in front.
Anyone one run the wrap bar backwards so that the cross member is behind the axle it's controlling wrap on?
Youre the only person on earth who knows all the details of your life, and thus, you are the most qualified captain of your own ship. Dont worry about justifying your course for pirate's sake. There's always someone here to tell you that you did it wrong.
Grendel is offline   Reply With Quote Quick reply to this message
Old 02-28-2009, 02:08 PM   #2 (permalink)
onetoncv's Avatar
Member # 2160
hmm- I suppose it could be done - Jess
- Also see us on facebook @ High Angle Driveline
530-877-2875
onetoncv is offline   Reply With Quote Quick reply to this message
Old 02-28-2009, 03:22 PM   #3 (permalink)
Member # 86553
since its leaf sprung, i don't see what the problem would be. spring over, or under?
02 frontier, dynatrac pro rock 60, 3 link f/r, 14" kings f/r, arb lockers
thats right... a NISSAN!
DON'T JUST STARE AT IT- EAT IT!
You should have licked her asshole.
roastbeef is offline   Reply With Quote Quick reply to this message
Old 02-28-2009, 03:41 PM   #4 (permalink)
Member # 55444
Guy's run them front or rear in the front, just make sure the geometry is good.
If it's an F350, it likely isn't flexing far anyways, so it shouldn't be too difficult.
[CENTER]I have Dumb Ideas[/CENTER]
spidr is offline   Reply With Quote Quick reply to this message
Old 02-28-2009, 03:41 PM   #5 (permalink)
Member # 86199
You could also look at doing something like this.
IMHO it's not the best solution, but I can understand how room constraints can force you to make some compromises.
brendank69 is offline   Reply With Quote Quick reply to this message
Old 02-28-2009, 03:47 PM   #6 (permalink)
Member # 51387
Send a message via Yahoo to Gravel Maker
As you flex the axle moves forward....
if set up in the rear you would be limiting your droop substantially.....
Gravel Maker is offline   Reply With Quote Quick reply to this message
Old 02-28-2009, 03:49 PM   #7 (permalink)
ItsaCJ6's Avatar
Member # 6340
It will work, all your doing is resiting the force of the axle rotating.
shameless plug.....For the best deal on 8 lug disc brakes click here-->
Marc
In what appears to have been an understatement, the plant operator described the situation at the Number 4 reactor as "not so good."
Love and kisses, Zaphod..
ItsaCJ6 is offline   Reply With Quote Quick reply to this message
Old 02-28-2009, 04:00 PM   #8 (permalink)
87JeepWrangler's Avatar
Member # 13959
Send a message via AIM to 87JeepWrangler
not if set up with correct geometry.
rob
87JeepWrangler is offline   Reply With Quote Quick reply to this message
Old 02-28-2009, 04:15 PM   #9 (permalink)
4rnr's Avatar
Member # 34860
Sure you either have to use a slip, or a long (longer than usual) shackle so It can swing forward with the droop. If the shackle is mounted at the same distance from the axle as the leaf's shackles then I would start with a shackle length equal to the leaf shackle length....
Check 91blaze (iirc) He has been running reverse antiwrap bars in rrock competion for years.
92 4rnr 3.4 auto duals 37's...
72 fj40 some stuff.
4rnr is offline   Reply With Quote Quick reply to this message
Old 02-28-2009, 04:22 PM   #10 (permalink)
Member # 55444
Guys have been running them for a long time on the front axle to the trans x-member, it would essentially be the same thing.
Old 02-28-2009, 04:44 PM   #11 (permalink)
kwrangln's Avatar
Member # 6971
Sorry, but I hate blanket statements like this. There is a big difference in how a spring moves in its arc of travel depending on its arch at ride hieght. A flat spring will move the axle towards the fixed mount on both compression and droop, an arched spring will move towards the fixed mount when drooping, and away from the fixed mount on compression. As long as the shackle on the wrap bar matches the length of the spring shackle it should have no trouble matching the travel of the axle during its arc of travel.
I'm the "tack tack tack" welding nazi.
:flipoff2:
"I didn't mean to kill nobody ... I just meant to shoot the sonofabitch in the head. Him dying was between him and the Lord." R. L. Burnside
kwrangln is offline   Reply With Quote Quick reply to this message
