465/205 race track clocking options?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-14-2009, 10:39 PM   #1 (permalink)
Member # 67889
I have read about 25 threads about this, but no one talks about or shows any pics of their finished work. I would like to hear how you did it and see some pics.
I want to clock it flat. (The front output of the case will not be used in my rig.)
So far I see two real options.
1) Buy a clocking adapter. - D.D. Machine did sell an adapter (maybe he still does) sounds like he’s not on PBB anymore.
2) Build your own. I have seen two examples. I think one had a cross member built into it.
I don’t want/need a doubler.
What you got?
jeepgif is offline   Reply With Quote Quick reply to this message
Old 04-14-2009, 11:41 PM   #2 (permalink)
Member # 67889
Originally Posted by trkklr77 View Post
pre made plate, do you really think you can bang out 16 holes in 2 seperate patterns with a hand drill and a punch.
Huh? Hope you are you being sarcastic…
If I were to make one, I was thinking of machining 2 chunks of ˝ or 5/8 plate for the mating surfaces and then join them with a length of 3/8 or ˝ wall tube machined to fit. I could clock to the appropriate angle needed. Then add some gussets and a mounting surface for the cross member. But that’s just me…
I want to see whats been done. DIY or pre made, either way.
I take it your vote is for pre made. Can you point me to a source?
Old 04-15-2009, 05:14 AM   #3 (permalink)
Member # 43040
Pre Made, i got mine from DD Machine. I cant get a photo at this moment.
95 S-10, one tons, 44's, 7lb pulley
Joshinator is offline   Reply With Quote Quick reply to this message
Old 04-16-2009, 03:05 PM   #4 (permalink)
Member # 67889
i dont know why you would make it so thick?
the dd one is just a piece or 1/2". you counter sink the holes and use flat top fasteners.
i dont know what kind of tool you have on hand but every time i build something similar i have to do it twice because i dont have a drill press or better and shit gets crooked.
Tools (for me) are not the issue. Time is the issue.
So D.D. Machine is the only guy making these things?
I assumed that I would hear about more options. or at least see some cool DIY stuff.
This is still Pirate; right!?!
Maybe i'm just behind the times
Old 04-16-2009, 03:11 PM   #5 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
How about a shorter version of draggbody's adpater from Jed's Machine?
https://www.pirate4x4.com/forum/showt...&highlight=205
I would guess that Jed's still has the files to make the figure 8 pattern.
guidolyons is offline   Reply With Quote Quick reply to this message
Old 04-30-2009, 06:16 PM   #6 (permalink)
Member # 67889
D.D.Machine Clock Up Adapter
Anyone have any pics of the D.D.Machine adapter installed?
By adding the ˝” adapter plate do you loose that much in spline engagement into the coupler?
I need some pics of one installed to get a warm fuzzy feeling…
