Custom CV shafts - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-23-2009, 11:26 AM   #1 (permalink)
TPIJeep's Avatar
Member # 2082
Send a message via AIM to TPIJeep
Custom CV shafts
I have hit a wall and really not sure where to go from here. I am working on my mini buggy which is modeled off the Polaris RZR and I am to the point where I need to source some CV axle for the independent suspensions. I am using differentials which have a flange that the shaft bolts to, the rear will be using mazda miata spindles and the front will be honda civic.
I need shaft for the rear that will have about 2" of travel and is capable of 30 degrees at each end and am not having any luck.. The ATV stuff is to small to even think about. The front will need 30 at diff and 48 or so at spindle for turning, the problem is the spline requirements of each spindle, the flange at the diff side should not be quite so hard.
Any idea what I can use. Its going to have about 200hp, 45:1 reduction and 32" tires.
I am normally only a danger to myself don't make me include you!!
Southern Motor Sports
Ruston, Louisiana
TPIJeep is offline   Reply With Quote Quick reply to this message
Old 05-23-2009, 11:34 AM   #2 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
Might wanna check out the last couple IFS builds on here, but I doubt they will help. I'm thinkin you probably should have figured this out before building around parts that may not exist.
Dallas Ashley
Your Source for: CNC Cutting & Engraving, Cages, Custom Suspension, Complete Vehicle Builds, and more!
Co-Dog #4432-KOH 2011 #88-KOH 2010, Crew Chief - KOH 2009, 2008
StinkBug is offline   Reply With Quote Quick reply to this message
Old 05-23-2009, 11:56 AM   #3 (permalink)
Member # 15461
why didnt you source these before the build again?
tracker guys, specifically mike hagen rpm4x4 or something like that on here, has used toyota IFS half shafts on his tracker based rigs and he's had good success up to a 35" tire. they have a 6 bolt flange but arent very compact. you might look into those for an option.
95geo is offline   Reply With Quote Quick reply to this message
Old 05-23-2009, 04:23 PM   #4 (permalink)
2D EDGE's Avatar
Member # 47600
Get in touch with Sean at RCV performance he can build any custom CV for you, you could ever need
http://www.rcvperformance.com/
Geoff
Team 2D EDGE would like to thank
as well as pirate4x4!!\
2D EDGE is offline   Reply With Quote Quick reply to this message
Old 05-25-2009, 07:19 AM   #5 (permalink)
TPIJeep's Avatar
Member # 2082
I knew the concept was sound and I am creative enough to make something work if there wasn't an easier way. Hell I can attach two steering ends together with a slip yoke in the middle. We have come to far to stop because of an axle issue! Just trying to pool the power of the PBB together to come up with some ideas, Thanks!
Ruston, Louisiana
Old 05-25-2009, 08:27 AM   #6 (permalink)
I brought the beer
JeepRecoveryTeam's Avatar
Member # 10203
Send a message via ICQ to JeepRecoveryTeam Send a message via AIM to JeepRecoveryTeam Send a message via Yahoo to JeepRecoveryTeam
Geoff
That's where I sourced my CV's from for my build.
JeepRecoveryTeam is offline   Reply With Quote Quick reply to this message
Old 05-25-2009, 01:30 PM   #7 (permalink)
onetoncv's Avatar
Member # 2160
We can make custom flange mount style 1/2 that get's 38 degree's -made for smaller desert style cars- hyabusa cars- Jess
- Also see us on facebook @ High Angle Driveline
530-877-2875
onetoncv is offline   Reply With Quote Quick reply to this message
Old 05-25-2009, 06:35 PM   #8 (permalink)
TPIJeep's Avatar
Member # 2082
Jesse,
I am using a honda civic front spindle, I will use the outer civic joint at the wheel which gets 48 degrees but no slip the inner will have to be a flange style and allow for at least 2" of slip, the flange is about 4.5" in diameter on the differential. Can you adapt this 38 degree unit to my civic shaft and make a custom flange for the diff? Any round about price for the setup would be?
Ruston, Louisiana
Old 05-25-2009, 07:12 PM   #9 (permalink)
Member # 23566
Send a message via AIM to SirMrManGuy
http://www.thecvman.com/store/ This guy is good with custom applications, just call him and he'll hook you up. He know's both ATV and Car/Truck stuff, so he might be able to help you piece something together from off the shelf parts.
95 Nissan Pathfinder, D44 front/H233 rear, dual ARBs, 4.56s, 36 Iroks
SirMrManGuy is offline   Reply With Quote Quick reply to this message
