Member # 109931
Warn winch remote/toggle in cab
Got a new M-8000 Warn winch, trying to wire a toggle switch in cab, have a 3 wire 16ga. black extension cord and a three position switch. The remote has five wires. Would like to operate winch from cab and still use remote if needed or I would sacrifice the remote switch. I have tried what I thought would be a no brainer with no luck. Can anyone help a dum dum ?
Member # 50177
the plug has 5 pins but only 3 are used. one is a power feed to the switch and the other two are the in/out signal wires from the switch to the solenoid pack. If you pull power from another source you only need two wires going to the winch from your dash switch. I want to say the power feed wire is white but it has been a few years. Once you take the plug apart it is real easy to figure out
Toyota Link Suspension Systems, Weld On Beadlocks, Custom Fabrication, and More To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ________________________________________________ 05 GMC 2500HD d-max, 87 4runner, X chassis rock buggy my buggy build To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by am4x4; 07-17-2009 at 08:17 PM. |
Sponsored Links |
#3 (permalink) | |
Member # 109931
#4 (permalink) | |
Warn likes switching the ground on the solenoids as well as the power. |
I did this a year or so ago and took notes. I don't have that notebook handy at the moment, but what I remember was that there was a power wire, 2 solenoid wires (in/out) and 3 ground wires.What you will want to do is open up the remote and draw the switch, and note what color wires go where. Then just copy that to your in cab switch (double pole double throw momentary) and connect the wires right to the solenoids with ring terminals. I'll look for my notes tonight and try to get something up for you.
he could also bypass the switch on the ground wires, grounding them out permanently, then he'd have a 3 wire operation and be good to go.
Don't really know why they are switching the grounds, I'm sure there's an added bit of safety doing it but don't really think it's that much considering how long the 3 wire version has been around and how few accidents have occured. |
Member # 99795
The easiest way to wire it is to just use the remote cable you now have.
Cut it at the handle and rewire a new 2pole/3pos switch. Here is how it gets wired: ![]() Buy a new remote cable if you want one. That way if you want to use the remote, just switch plugs at the winch.
[QUOTE=Keith Kreutzer;9210743][COLOR="Red"][B]Just pull up your man-panties and drive[/B][/COLOR][/QUOTE] [QUOTE=Ian Malcolm;9210743][COLOR="Red"][B]I mean, it's not your fault. They say talent skips a generation. But hey, I'm sure your kids will be sharp as tacks.[/B][/COLOR][/QUOTE] [SIZE="4"][B] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/B][/SIZE] |
Member # 99795
Then you can use the remote handle to run your bender:
Member # 6156
here's a decent writeup.
http://www.4x4wire.com/tech/winch/remote/ make sure to add a master on/off switch so the momentary switch only works when you choose.
"whatever doesn't kill me postpones the inevitable" 69 Bronco 04 Yukon Denali (beater) 18 Ram 2500 16 4Runner Trail 15 Can Am Commander XT-P |
Member # 40
email me for a wire sheet...
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [COLOR=Red]-- To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. :evil: # 530.532.4529:evil:[/COLOR] TTC 2010 1989 BRONCO :evil:-[COLOR="Red"]Awesome web development for your business[/COLOR]. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#12 (permalink) |
Member # 109931
Had a buddy come by that had done what I was trying to do...We ran another ground from winch motor to solenoid terminal side that brown wire was hooked to and winch started working when operating toggle.
#13 (permalink) |
Member # 56006
Talk to Seabass or PM me...I have wiring diagrams & write ups on how to do it....I havent done it myself yet..
[QUOTE=Sturgell;9689430]Would you rather suck a dick or make out with a dude? Myself I would have man up and suck a dick, pretty sure I couldn't make out with a dude.[/QUOTE] |
#14 (permalink) |
Member # 89217
I just did an in cab control for my M8000 a couple weeks ago. I found a write up on a Yota forum, and It helped a little, but it was for a 5-wire system. I opened up my solenoid box and there were only 3 wires going to the controller. So instead, I just spliced into the three wires and ran them into the cab. I picked up a momentary switch from Napa and one of those flip "missle launcher" switches to use as a power switch.
Here is the panel installed in my XJ ![]() ![]() ![]() |
Thread Tools | |
Display Modes | |
