need th350 help - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-20-2009, 07:30 PM   #1 (permalink)
Member # 11985
need th350 help
just recently had a shop install an LQ4 6.0 and a th350 into my '00 s10
the trans was rebuilt, but supposedly built well for higher HP. my 6.0 is cammed and tuned and probably is a little over 400hp. stall should be roughly 1700
it never seemed to have that snap off the line that I expected it to have and when a friend looked at it for me, he says it feels like it's starting off in 2nd gear. when manually shifting (it does not have a manual valve body right now) into 1st, he says it feels like a trans brake is on and is fighting itself. when starting off in "drive", it'll barely spin the tires in his gravel driveway and I would think it should damn near rip the asphalt up with that motor and 5.38s.
the fluid (after only 2 trips) is still fairly clear, but is slightly darker than new and he thinks it's already getting cooked.
I'm going to have a different shop look at it since the first shop is too far away (4-5 hours one way). anything specific I should mention? any area that would be a good place to start looking?
thanks
fawk this, let's go wheelin
M&M Offroad triple threat chassis #27
1TFROT is offline   Reply With Quote Quick reply to this message
Old 07-20-2009, 08:11 PM   #2 (permalink)
Member # 40567
Send a message via AIM to 1TONZR2
damn Steve....tearin shit up already?! hope you get it figured out soon
Brian
96 ZR2 HP60,14B, 5.13s,locked ,F/R tri'ed 4 link,16" SAW COs and 4" SAW bumps front, 16" ORIs rear,RCI fuel cell, Truggied out, 42" PitBull Rockers & TR beadlocks, 5.3L Vortec w/LS6 cam/springs, 231/205 doubler, 1410s, 9.5ti
Over the Top Offroad
1TONZR2 is offline   Reply With Quote Quick reply to this message
Old 07-21-2009, 05:18 AM   #3 (permalink)
Member # 11985
thanks. I wish that was the case, but I don't think it was right from the start. I just didn't notice it due to the extra power.
Old 07-21-2009, 12:25 PM   #4 (permalink)
Member # 5110
What are the spec's on the cam? It sounds like the stall of the converter is too low to start with. What do you have for a cooler? Do you have a temp gauge? If it is applying more than one gear when in 1st I'm of no help on that. Who rebuilt it? Take it back to them.
Link to thread on my calculator https://www.pirate4x4.com/forum/showthread.php?t=204893
Triaged is offline   Reply With Quote Quick reply to this message
Old 07-21-2009, 02:44 PM   #5 (permalink)
92redyj's Avatar
Member # 25857
Who built the trans? I had a TH350 that about locked the tires when you shifted to third and felt like a transbrake if you put it in 3rd while sitting still and applied throttle. The problem was a bad valvebody(also in a brand new freshly built trans).
You are right, if you are on gravel it should absolutly rip the tires in 1st. It does sound like it may be starting in 2nd. I have a 2800 stall with a 5.3, your stall does sound a little low, but it should still rip when you step on it regardless. These motors have some serious throttle response.
DRIVER: Matt Happick
Thanks to: Appalachian Offroad Inc 410-848-2942
92redyj is offline   Reply With Quote Quick reply to this message
Old 07-21-2009, 07:33 PM   #6 (permalink)
Member # 11985
local company in MI somewhere. they built it for the shop who did the motor swap. unfortunately, they are 4-5 hours away. don't want to spend all that fuel round trip and all the down time. I'd rather have someone reputable and close to home fix it and have them pay the bill (if possible)
these should be the specs on the cam
Comp Cam XFI roller
RPM-Range: 1200-6000
Valve Timing: .006
Lobe-Center Angle: 114
Intake Centerline: 112
intake/exhaust
Duration: 265/271
Duration @ .050" Lift: 212/218
Valve Lift: .522/.529
Lobe Lift: .307/.311
not sure what cooler it is, but it's external and works well. the temp gauge has not been over 190* during 2 trips.
thanks for the responses so far. I was leaning towards valve body, but wanted more experienced opinions.
Old 07-21-2009, 08:09 PM   #7 (permalink)
92redyj's Avatar
Member # 25857
Good luck with that one, I don't know of any shops that would do this.
Old 07-21-2009, 08:15 PM   #8 (permalink)
Member # 11985
I hear ya.
