Building a turbo 350 on a semi budget, advice please - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-22-2009, 02:28 PM   #1 (permalink)
Member # 20304
Send a message via AIM to BarrelRoll
I've done a lot of searching and havn't gotten what I'm looking for. I'm planning on building a turbo 350 for my next rig (1/2 ton chevy cab/ frame, tons, 40's, tired tbi 350, adventually a doubler) and want a trans that will last but isn't super expensive. I'd like to spend no more than $1000 and perferably under $750 for a decent turbo 350, those figures are not including a shifter or cooler. I'll do the work my self with some help from a buddy. I know the turbo 400 is an option but I want to stay with a turbo 350 because I have one, they are cheaper to find, they weigh less, and they rob less power.
Here's the parts I'm thinking about, let me know if this looks like a decent list
The parts I'm pretty sure on
-Summit performance turbo 350 re-build kit $220
It includes kolene steels, alto red clutches, kevlar bands, new bushings, seals, and thrust washers
-6.2 Diesel torque converter $100
-TCI 321115 Reverse Manual Valve body with compression breaking $220
-Summit aluminum deep trans pan $110
The parts I'm not sure on
-Should I put a new pump in it? The tci stock pump is $84 dollars
-What do I need to upgrade sprag wise? Do I just need a heavy duty outer race or do I need the drum assembly. ATI sells a heavy duty intermediate sprag race for $41 or the upgraded direct drum for $300. I know they are a weak link, anyone have a link to what I should buy.
-Adjustable modulator, I'm thinking I don't need one with the full manual valve body or will it help?
Thanks any other advice would be appriciated. I'm looking for a trans that will handle years of trail riding without giving me a head ache. I've never really had an auto in a trail rig that hasn't given me problems.
This board is no doubt slowly moving from Pirate4x4 to ElitistYuppyWithTooMuchMoney4x4.
-Braxton 357
BarrelRoll is offline   Reply With Quote Quick reply to this message
Old 07-22-2009, 04:12 PM   #2 (permalink)
miniwally's Avatar
Member # 29513
I am running a Th350 in my buggy that goes between 4,500#s and 5,300#s depending on what it's duty is at the time.
5 1/2 years including this years KOH race on stock rebuild parts with the TCI reverse manual valve body with no issues. I am running TBI 350, doubler.
I don't think you should have much issue with slightly upgraded parts and nothing special.
miniwally is offline   Reply With Quote Quick reply to this message
Old 07-23-2009, 12:52 AM   #3 (permalink)
Member # 36396
Location: usually on bottom or behind unless locked in a 69. OR USA
Send a message via Yahoo to no excuses
depending on youre gearing i would look at something a bit different then the diesel convertor, with a doubler setup you would probably not be able to stop it and just drive through the brakes. I run a slight stall in mine (4.3v6, t350, 5.44 speed atlas with 4.56 gears and 39" krawlers) and the slight stall really helps with the braking and launching.
1930 model A buggy for sale
no excuses is offline   Reply With Quote Quick reply to this message
