Help! axle problems. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-26-2009, 05:27 AM   #1 (permalink)
nissancrawler's Avatar
Member # 76684
Well, first things first, I'm a fucking idiot. When I had the axle built, I specifically told them to place the pumpkin as close to the spring perch as possible. In a genius move, I completely forgot about that all-important u-bolt.
Here's what I've got:
Is there any reason I couldn't get a block machined to fit against the housing and perch, and drilled/tapped, and just weld that to the housing/perch and use Grade 8 bolts on that side?
A u-bolt just won't fit, it would have to be a 4.5-5" u-bolt to get around the housing, and would have to have a machined piece welded to the bottom of the housing to hold it.
The only other option is to cut the perches off, get new ones, and offset the housing 5/8-3/4" from center. This isn't as ideal due to oil pan/driveshaft/spring-tire clearance
This is one of those things you just can't fucking believe you did...
[QUOTE=nahmus;9175355]asking chit chat to stop before they are done is kinda like asking piranhas to stop after one bite.[/QUOTE]
nissancrawler is offline   Reply With Quote Quick reply to this message
Old 07-26-2009, 07:54 AM   #2 (permalink)
Pat
Member # 120
fab a stud plate for the diff side and weld it in. . You will just use high grade nuts on top of the sprig plate. Looks like there is plenty of room and good metal to weld to. Kinda like the dodge 44's or 60's used to do it.. You could use Dana 44 steering arm studs.. 9/16x18.. you could even make the plate out of some thick material and thread it for the studs instead of welding the studs in
Easy, Quick and Strong.. Problem solved
Try out a AppleSeed...
Pat is offline   Reply With Quote Quick reply to this message
Old 07-26-2009, 07:56 AM   #3 (permalink)
Member # 69441
Smart ass comment-- 4 link that should fix it
Lj stretched Dana 80s 47s coilovers 5.8 aodw 203 205
99grandtj is offline   Reply With Quote Quick reply to this message
Old 07-26-2009, 12:09 PM   #4 (permalink)
Member # 76684
duh on the studs, can't believe that didn't cross my mind. Thanks for the idea, that makes me much more comfortable than bolts. There's enough room to do a thick block and thread it for studs.
Yeah, 4 link would be nice, but...this project has been sitting for 6 years, and I want to get it going again. The money just isn't there for a 4 link seutp.
Old 07-26-2009, 09:08 PM   #5 (permalink)
Pat
Member # 120
no problem.. What axle you building there anyhow?
Old 07-26-2009, 11:10 PM   #6 (permalink)
Member # 27344
mine was closer,i just bent the u bolts.
the stinky truck is offline   Reply With Quote Quick reply to this message
Old 07-27-2009, 12:43 AM   #7 (permalink)
Member # 76684
It's a crossed up offroad 60/9".
They did a great job on it, they did exactly what the idiot that ordered it told them to do. There's no way I can fault them for this one.
Yeah, I was sorely tempted, but the way it is, there isn't even room to get the u-bolt bent and between the housing/perch. it would have to be a 5" u-bolt to get around the housing. When you try and put it on from the bottom, you can't get the u-bolt past the bottom of the spring perch.
There's plenty of room for a thick block for studs, I'll just do that.
Old 07-27-2009, 01:05 AM   #8 (permalink)
DWT
DWT's Avatar
Member # 19850
Could always weld a heave piece of small ID tube to the front and back of the housing and run a couple bolts up from the bottom. I'd do that over welding a bolt on there and losing the temper in the bolts any day.
'89 auto x toyota pickup, most fun I've ever had with my clothes on.
Taiwanese Garbage should stay in Taiwan.
DWT is offline   Reply With Quote Quick reply to this message
Old 07-27-2009, 01:07 AM   #9 (permalink)
Member # 76684
Nope, no room for bolts or tubing on the bottom. I'm not going to weld bolts, I'm going to weld a threaded block on and install studs.
Old 07-27-2009, 01:29 AM   #10 (permalink)
DWT
DWT's Avatar
Member # 19850
I'm not talking about doing anything on the bottom... Just on the front and back of the housing itself. If there is room for a threaded block there is room to run a bolt through some tube. The only thing I'd worry about with the block is having enough meat to be strong. If you can pull it off then you have a sweet front axle. If not you fawked up.
Old 07-27-2009, 01:50 AM   #11 (permalink)
pro web-wheeler
RedBullJeep's Avatar
Member # 12217
Stud plate was what I thought of too. Also, that tie-rod looks a lil flimsy...I know that one makes for quicker changes but I'd get something beefier.
Nice housing. I've seen the Crossed Up Pro Modified setup and they do well with it. You should be stoked.
RedBullJeep is offline   Reply With Quote Quick reply to this message
Old 07-27-2009, 03:13 AM   #12 (permalink)
Member # 76684
I know what you meant, but the bolts would have to be 5" apart to do that, which would make for an interesting spring plate. The threaded block will be on top, so I can keep the normal spacing.
Old 07-27-2009, 06:10 AM   #13 (permalink)
Member # 3511
Just use square bolts around the spring instead of around the tube.
Chuck P
A man can do all things if he will
oldjeep is offline   Reply With Quote Quick reply to this message
Old 07-27-2009, 06:13 AM   #14 (permalink)
Member # 3511
Or if you want to get fancy, you could do something like this
Chuck P
