list of differences between a LS1 and LS2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-27-2009, 03:06 PM   #1 (permalink)
The Piratenite
camo's Avatar
Member # 4
Send a message via Yahoo to camo
can somebody point me to a list of what the differences are between a LS1 and an LS2 ?
Millennials, making hippies look tough since 1980
camo is offline   Reply With Quote Quick reply to this message
Old 07-27-2009, 03:23 PM   #2 (permalink)
Member # 74407
Obviously the 1st thing is the size difference...346ci vs. 360ci or for the left handed 5.7 vs. 6.0. Bore size is 4.00 on the LS2 I believe, and the LS1 is 3.89?? The intake manifold is different, the throttle body is drive by wire vs. cable. Cam sensor is on the back of the block on the LS2 vs on the front of the block in the LS1. The LS2 in stock configuration suffers from extreme heat soak issues which lead to retarded timing and lower power output. This is solved with some tuning.
There's alot more, but those are the basic things.
TireFryerSS is offline   Reply With Quote Quick reply to this message
Old 07-27-2009, 03:24 PM   #3 (permalink)
Keith's Avatar
Member # 52
https://www.pirate4x4.com/tech/billav...SPrimer/Part2/
Rockzombie Smurf
Keith is offline   Reply With Quote Quick reply to this message
Old 07-27-2009, 03:27 PM   #4 (permalink)
Member # 127572
Good LS history here.
http://www.gmhightechperformance.com...ory/index.html
This site is helpfull if you are going to make some serious power from either one.
http://ls1tech.com/forums/ls1-ls2-ls...performance-3/
Countri Boy 84 is offline   Reply With Quote Quick reply to this message
Old 07-27-2009, 04:23 PM   #5 (permalink)
DSI
DSI's Avatar
Member # 920
Send a message via Yahoo to DSI
you have this fun little fact backwards. gen3 rear of block, gen4 front of block
I like Pizza Steve...
DSI is offline   Reply With Quote Quick reply to this message
Old 07-27-2009, 04:46 PM   #6 (permalink)
Member # 15461
basically the LS2 is the same as the LS6 except the displacement. a lot of stuff from the LS6 was carried over directly to the LS2 like the famous 243 casting heads.
honestly if you want the most bang for your buck and are spending some coin then you want to go to the new rectangular port stuff and stay away from the cathedral port stuff. An L92, L76, LY6(I think, I'd have to double check) LS3 will get you into a 6.0L (LY6) or 6.2L displacement. the 4.0" bore on the 6.0L and bigger allows you to run the rectangular port heads and intake and they also have bigger valves that cant run on the smaller bores. if you buy anything smaller than a 6.0" displacement with a 4.000" bore you are pretty much handcuffing yourself for "cheap" big HP add ons. L92 heads are less than 700/pr, add a cam and tuning and you have 500hp.
I have a 6.2L L92 with the car (L76) intake and it has cam phasing and I'll run cam from mast motorsports and it should be good for 480 ft-lbs and 530 hp in pretty much stock trim except a cam and tuning.
95geo is offline   Reply With Quote Quick reply to this message
Old 07-27-2009, 04:48 PM   #7 (permalink)
The Piratenite
camo's Avatar
Member # 4
neat, what has rectangular port heads ?
Old 07-27-2009, 05:18 PM   #8 (permalink)
Member # 15461
An L92, L76, LS3
What I typed was pretty difficult to read...
L92 and LS3 are 6.2L, L76 is 6.0L and I think theres a few more but I'm not positive off the top of my head. They are all aluminum blocks too. They have the 88mm throttle body and are DBW, you would have to swap that out if you wanted but it isnt too big if a deal.
One thing to think about that I saw you post in the vendor thread is that the C6 belt track and accessories pretty much limit you to the T/C style PS pump. You would need to go to the truck belt track to make enough room for a bigger PS pump in front of the engine, if you have room on the sides then you mgiht be able to fit a larger pump off the side of the head but it would be tight nomatter what you do. I'm not positive but Im pretty sure that the ls1's belt track is about 18mm forward of the C6 vette belt track and allows the use of the N pump which is like a super sized T/C pump. The new truck belt track is 40mm farther forward than the C6 vette belt track and will be very easy to mount accessories where you want because it leaves you with plenty of room off the front of the block.
Old 07-27-2009, 05:26 PM   #9 (permalink)
The Piratenite
camo's Avatar
Member # 4
lucky for me I run a TC pump
Old 07-27-2009, 05:33 PM   #10 (permalink)
Member # 15461
Just an FYI, the alternator bracket will need some slight clearancing to make a T/C pump fit because the one that goes in there is similar but not 100% exact. and you also need to make sure the alternator doesnt get into the shocks because it sticks out a lot to the side. I'll get you a measurement if you want, I have on on my engine right now.
edit:
14" from crank CL vertically to the alternator CL, the alternators widest point is 17" horizontally from the crank CL. 14" up and 17" out from the crank CL.
Old 07-27-2009, 05:54 PM   #11 (permalink)
The Piratenite
camo's Avatar
Member # 4
according to Bill
Length:
20.5" length of block
25-1/4" from front of harmonic balancer to rear edge of block
at 25" long the entire motor will still be behind my shock package
Old 07-27-2009, 05:56 PM   #12 (permalink)
The Piratenite
camo's Avatar
Member # 4
but if you can measure the width of the motor from the center of the crank pulley bolt to the out side of the alternator that would be very helpful as I need to fit it between the rails
Old 07-27-2009, 05:58 PM   #13 (permalink)
The Piratenite
camo's Avatar
Member # 4
might have to trip a tad to clear the water neck on the passenger side
Old 07-27-2009, 06:48 PM   #14 (permalink)
Member # 15461
From what your packaging looks like you sholdnt have any issue. Here are some pictures that might help you see what is where.
