Sm465 sloppy shifter...common culprits? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-21-2002, 04:36 PM   #1 (permalink)
Member # 3547
The slop in my SM465 shifter has reached ridiculous proportions (it's almost impossible to tell when it's in neutral).
Any hints or tips on common culprits before i tear into it? Any replacable wear parts?
Cheers
BillaVista is offline   Reply With Quote Quick reply to this message
Old 09-21-2002, 05:37 PM   #2 (permalink)
fish's Avatar
Member # 13463
BILLA VISTA THIS IS COMMEN PROBLEM FOR THE 465 BUT I CANT TELL YOU THE RIGHT WAY TO FIX IT UNTIL I TALK TO A FREIND OF MINE WHO WHEELING FOR THE WEEKEND. I DO KNOW THAT HE JUST TACK WELD AN AREA ON THE SHIFTER. BUT IT ALSO SOUNDS LIKE YOU ARE BEYOND A LITTLE TACK WELD REPAIR. I WILL KNOW MORE ON MONDAY..
fish is offline   Reply With Quote Quick reply to this message
Old 09-21-2002, 07:25 PM   #3 (permalink)
Member # 7936
Send a message via MSN to mud-magnet
WHAT, SPEAK LOUDER...................
problems already bill???? , i don't know on the chevy trannys, but on zukis, when hte shifter is "slopy" the fit is a bolt that guids the shifter broke, just feplace the bolt with a new one and back to normal....... might be the same, might not, just my $4.72
94 Sidekick buggy, 16L 8v, auto, dual cases, toyota axles, locked, coils, and 36" Swamper TSL's.
mud-magnet is offline   Reply With Quote Quick reply to this message
Old 09-21-2002, 07:42 PM   #4 (permalink)
Member # 3547
Mike,
not really a major problem....but most of the Wolf works so damned well, I get to be fussy about things
I think I'll tear into it tomorrow
Old 09-21-2002, 08:10 PM   #5 (permalink)
TPIJeep's Avatar
Member # 2082
Send a message via AIM to TPIJeep
2 possibilities:
1: the pin that holds the tip at very bottom of the shift lever has sheared off.
2: The two pins on either side of the shift tower have backed out, to fix mine I drove them in with a punch and put a small tack weld to keep them from backing out.
HTH!
I am normally only a danger to myself don't make me include you!!
Southern Motor Sports
Ruston, Louisiana
TPIJeep is offline   Reply With Quote Quick reply to this message
Old 09-21-2002, 08:31 PM   #6 (permalink)
Member # 7936
well since your having soooo many problems................. i'll trade ya my zuki......... ...............
hmmmm, i can only guess the answer............hehehe
Old 09-21-2002, 09:08 PM   #7 (permalink)
Member # 3547
TPIJeep,
poss. 1 - you mean the shift lever is 2 pieces, with the tip held to the rest with a pin?
Poss 2 - what size are those pins in the side, if I should have to replace them?
Thanks
Old 09-21-2002, 09:17 PM   #8 (permalink)
TPIJeep's Avatar
Member # 2082
Originally posted by BillaVista
TPIJeep,
Thanks
Yes, if I recall correctly the very tip is held on by a pin, they can break off, not common but it can happen.
The pins on the side of the shift tower are about 3/8" in diameter but they are special, a regular dowl will not work, pull your tranny boot, push down on the cap that goes around the shift lever rotate about a 1/4 turn and you will be able to pull the lever out and see just what I am talking about.
HTH
Ruston, Louisiana
Old 09-21-2002, 09:33 PM   #9 (permalink)
DUG
DUG's Avatar
Member # 858
Send a message via AIM to DUG
If the pin in the shift handle busts you normally have no gears. If one of the pins in the shift tower busts or walks out you tend to get problems finding gears. If they both back out you tend to have issues getting it into reverse and can almost not find the rest of the gears at all in my experiance. I wrap a hose clamp around the roll pins in mine because no matter what they do they seem to back out.
The other things that where making my SM465 "vague" where the bushing/collar that slips on the pins was worn out and the end of the shifter where i goes into the rails was shot. It may not seem like a big deal but the longer arm of the handle above the tower makes a little play at the bottom a lot in your hand. I just added some weld to mine and ground it to fit, much improvement.
Be yourself, by yourself.
DUG is offline   Reply With Quote Quick reply to this message
Old 09-21-2002, 11:45 PM   #10 (permalink)
mj
Member # 1919
bill
I have a problem shifter here, I will email images to you as webshots has restricted my usage so cannot add more.
area 1 the welds that hold the pivot ball are cracked loose
area 2 the pin that hold the tip is tiny and in a huge hole so it is floppy
mj is offline   Reply With Quote Quick reply to this message
Old 09-21-2002, 11:50 PM   #11 (permalink)
Member # 144
You mean like this?
its a big hole alright, but the tip isnt loose at all.
That's because you're a pinko fascist. - Haole
I know what antidisestablishmentarianist means
mike is offline   Reply With Quote Quick reply to this message
Old 09-22-2002, 04:20 AM   #12 (permalink)
Member # 3547
MJ,
If you e-mail them, I'll put 'em on my site and send you the links so you can post them for all to see.
Thanks
Old 09-26-2002, 01:52 AM   #13 (permalink)
mj
Member # 1919
the first pics I took the cracks are hard to see so I didnt send them.
will try again for you with a marking pen or something to hightlight if you want.
