Dual propane carbs - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-22-2002, 11:49 AM   #1 (permalink)
Member # 8417
Dual propane carbs
can you run two propane carbs, other that the dual carb manifold what else would you need??...or can you even do this.
MOFUGRA is offline   Reply With Quote Quick reply to this message
Old 09-22-2002, 12:05 PM   #2 (permalink)
Member # 5286
Send a message via Yahoo to Jason M
Piece of cake. I think one mixer will work just with a T
Look up propane guy
DEAR MADAM:
THANK YOU FOR YOUR RECENT ORDER FROM OUR SEX TOYS WEBSITE.
YOU'VE REQUESTED THE LARGE RED VIBRATOR AS FEATURED ON OUR WALL DISPLAY.
PLEASE SELECT ANOTHER ITEM.
THAT'S OUR FIRE EXTINGUISHER
Jason M is offline   Reply With Quote Quick reply to this message
Old 09-22-2002, 05:21 PM   #3 (permalink)
Member # 232
Re: Dual propane carbs
why
JIM3030 is offline   Reply With Quote Quick reply to this message
Old 09-22-2002, 07:27 PM   #4 (permalink)
DUG
DUG's Avatar
Member # 858
Send a message via AIM to DUG
The why is to get enough air flow through the motor. AFAIK the biggest propane carb out there is the 425 and it flows a little under 600 CFM if I remember right, and I think it depends on the base you use. Most conversions on big blocks use two carbs and I think two converters.
Be yourself, by yourself.
DUG is offline   Reply With Quote Quick reply to this message
Old 09-22-2002, 07:37 PM   #5 (permalink)
Member # 107
Send a message via AIM to The Jerk Send a message via MSN to The Jerk Send a message via Yahoo to The Jerk
the 425 will work just fine
RockZombie:68FJ40 LPG350/420/300/60/70
69FJ40 350/stock | 70FJ55 350/700r4/205 | 72FJ55 stock
The Jerk is offline   Reply With Quote Quick reply to this message
Old 09-22-2002, 07:43 PM   #6 (permalink)
Member # 8417
Re: Re: Dual propane carbs
Originally posted by JIM3030
why
ya i guess more power sucks, what was i thinkin.........
Old 09-22-2002, 07:49 PM   #7 (permalink)
Member # 12544
Don't know if this is any help or not, but here is a pic of a guy running dual propane.
350 Samurai is offline   Reply With Quote Quick reply to this message
Old 09-22-2002, 07:56 PM   #8 (permalink)
PYRO's Avatar
Member # 3246
I use a single Impco 425 mixer which is good to handle up to about a 375 hp motor. It's the biggest mixer that I found that still has an idle circuit. I use this on a 420 c.i. small block chevy with a mild cam and 10.3 to 1 compression. It works very good for what I do with it.
To flow more propane and air you'll need two mixers, two regulators, a dual quad manifold(single plane works best for propane), Split the main propane hose with a "Y" fitting to each regulator and setup the linkage so both mixers come on at the same time(don't try to make it a progressive linkage).
And use a Huge tank
Wayne
@ PYRO WORKS FABRICATION
808-333-9337
PYRO is offline   Reply With Quote Quick reply to this message
Old 09-22-2002, 07:58 PM   #9 (permalink)
DUG
DUG's Avatar
Member # 858
I was just looking at a LP site and they offered a baseplate that would allow you to run two mixers on a single carb intake.
A single 425 is not up to snuff for a 454 from what I understand. My uncle worked for aplace that had LP 454 tow rigs and they all ran dual carbs.
Old 09-22-2002, 08:01 PM   #10 (permalink)
PYRO's Avatar
Member # 3246
Don't mount the regulator on it's back, like in that photo above. It needs to be mounted so the vapor port to the mixer is on the bottom or water will accumulate in the regulator.
Wayne
808-333-9337
Old 09-22-2002, 08:07 PM   #11 (permalink)
PYRO's Avatar
Member # 3246
I've heard they don't work very good, trying the funnel the air flow of two 4 barrels into a single 4 barrel manifold
Wayne
808-333-9337
Old 09-23-2002, 04:40 PM   #12 (permalink)
Member # 232
Re: Re: Re: Dual propane carbs
ya i guess more power sucks, what was i thinkin......... [/QUOTE]
lol sounds like your just trying to fawk up a good thing. if you just what to poor fuel in there stick to that gas carb and keep her wound up
Old 09-23-2002, 05:22 PM   #13 (permalink)
rdv
Member # 11878
A friend of mine runs 2 Impco 300A mixers, both hang upside down (hood-clearance) on either end of a T (made by Impco), which sits on top of a 4bbl carb on a 318. Overkill imho, i only run one 300 on top of a #1406 edelbrock carb, also on a mildly hopped up 318. If I absolutely need those few extra horses, i just switch over to gasoline. Only problem with gas are the sometimes steep angles confusing the carb floats.
rdv is offline   Reply With Quote Quick reply to this message
