RIM GAPS the latest product from www.bootiefab.com.au - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-23-2002, 06:29 AM   #1 (permalink)
Member # 8565
Yes we are now prode top anounce our muchly awaited "Rim Gaps" are now available here are a few pics of us fitting them Down Under style.
P.S "Rim Gaps" are used when you cant get enough back spacing with the rim you have.
First you need to cut the centre out
SAVE THE HAMMERS Post #
Do illiterate people get the full effect of Alphabet Soup?
If electricity comes from electrons, does morality come from morons?
RUFF is offline   Reply With Quote Quick reply to this message
Old 09-23-2002, 06:31 AM   #2 (permalink)
Member # 8565
Then you need to trial fit your "Rim Gaps" to see how much of the gap you need.
Old 09-23-2002, 06:33 AM   #3 (permalink)
Member # 8565
Sorry these are the "Rim Gaps" we have used they are the 32mm style gaps but they come in other sizes also.
Old 09-23-2002, 06:35 AM   #4 (permalink)
Member # 8565
After trial fitting and adjusting the "Gap" you can start welding them in.
Old 09-23-2002, 06:37 AM   #5 (permalink)
Member # 8565
Make sure you have the proper balancing and aligning machine before fitting your "Gaps"
Here is a pic of the "Gap" almost fitted to the rim while on our profesional balancer.
Old 09-23-2002, 06:40 AM   #6 (permalink)
Member # 8565
We also have a custom "Guard Clearancing" option as well.
We just fit the wheel under the fender and push your rig off the high lift jack.
Old 09-23-2002, 06:42 AM   #7 (permalink)
Member # 8565
Making sure it drops fully on to the tire.
Old 09-23-2002, 06:44 AM   #8 (permalink)
Member # 8565
Then we are done fenders now clear 16/38.5/15s and we have 2" back spacing with custom "Rim Gaps"
Old 09-23-2002, 06:47 AM   #9 (permalink)
Member # 8565
P.S please dont try this at home as we are fully qualified "Bootie Fab Engineers" and have trained for many years to do these types of modifications
Old 09-23-2002, 08:04 AM   #10 (permalink)
Member # 6494
You guys should sell that custom fender clearancing kit
Easy
[SIZE="4"][FONT="Trebuchet MS"][I][COLOR="Magenta"]#914 Pampered Chef Buggy[/COLOR][/I][/FONT][/SIZE]
[SIZE="2"][U][COLOR="Blue"]Companies we're proud to work with[/COLOR][/U][/SIZE]
[COLOR="Blue"]East Coast Gear Supply[/COLOR]
[COLOR="Red"]Reid Racing[/COLOR]
[COLOR="DarkOrange"]RCV Performance Axles[/COLOR]
[COLOR="Sienna"]Rose Grinding & MFG[/COLOR]
[COLOR="DarkOliveGreen"]Single Source Welding[/COLOR]
[B][COLOR="Wheat"]Northern member of MUD DEVILS[/COLOR][/B]
EasyXJ is offline   Reply With Quote Quick reply to this message
Old 09-23-2002, 08:33 AM   #11 (permalink)
TJ99's Avatar
Member # 3717
Post
Job well done
97 Jeep TJ Atlas 4.3 with 38.5 tsl/sx's full cage for when it falls over.
TJ99 is offline   Reply With Quote Quick reply to this message
Old 09-23-2002, 08:48 AM   #12 (permalink)
Member # 2834
You forgot to post a price. Please dont forget the seperate prices for both the rim gaps and the clearanceing.
TyTy is offline   Reply With Quote Quick reply to this message
Old 09-23-2002, 09:46 AM   #13 (permalink)
Member # 10
The funniest part is, all the work making those "rim gaps" was completely unecessary. Once the wheel center was removed, you can get the 2" (or less) backspacing by flipping the shell around, so what used to be the outer bead is now the inner, and vice versa.
Carl Whitmore
I Lean is offline   Reply With Quote Quick reply to this message
Old 09-23-2002, 06:15 PM   #14 (permalink)
Member # 6588
by flipping the SHELL around as you put it, you then put the LARGER bead on the outside, and the inner bead (the one you can't beadlock, with a traditional ring) is NOW on the inside, and the one you hardly ever lose (larger bead) is now on the outside, and if you want to run beadlocks (in the traditional ring style) then you put them on the stronger bead....if you can understand my poor english i think this is what tony has done
my bootie fab bead removal pics are in!!
with my 10" wheels (for my new 42x15, 15TSLs) i needed to get some more backspacing, my current plan is to flip the "shell" and get 0" backspacing, but ruff as always is a few days ahead of me, and with the backing of a large offroad company at his disposal, its any wonder!!
mine is more backyard bootie
[COLOR=yellow]Bj on Roids 1970FJ45, Quad Cam V8, Auto, Broken T-case, H-TEC (traction control and cutting brakes) 42 TSLs.[/COLOR]
[COLOR=green]
[/COLOR]
BJ On Roids is offline   Reply With Quote Quick reply to this message
Old 09-23-2002, 06:23 PM   #15 (permalink)
Member # 6588
well i saw on malcom douglas special on bush survival that by driving across your tyre with no air in it, you can unseat the bead...
well after several funny and uninspiring attempts, and even a thought about going to the local tyre place and spending $5 and saving a few hours, i decided against it....
deciding instead to get the bootie fab handbook out and remove the beads, AUSSIE STYLE, now, step one was to angle grind the tyres off...BUT one of my friends (smithy aka beastmontero/beastpaj) wanted the old tyres so that ruled out that option, option two was to grab a front end loader, weighing in at a whopping....heavier than me, and use HYRO to remove the beads.....
put tyre under fork blades, push down, repeat steps, pull tyre off using screwdrivers and brute force, later realise a better way to do it may have saved an hour or two
then go out drinking and ignore the project for a week
PICSSSS
[COLOR=green]
[/COLOR]
Old 09-23-2002, 06:48 PM   #16 (permalink)
road1will's Avatar
Member # 8871
Send a message via AIM to road1will
lol i love you aussies, always have a sense of humor. kind of like canadians eh?
road1will is offline   Reply With Quote Quick reply to this message
Old 09-23-2002, 06:50 PM   #17 (permalink)
Member # 12482
is there a package deal for both?
Pathmaker is offline   Reply With Quote Quick reply to this message
Old 09-23-2002, 08:02 PM   #18 (permalink)
Member # 6588
1 male kangaroo and 4 female kangaroos, for the wheel package
the guard cutting package is an additional female kanga!
or 2 crocodiles will cover the whole lot (any sex)
this offer is limited
[COLOR=green]
[/COLOR]
Old 09-23-2002, 10:01 PM   #19 (permalink)
Member # 7962
That is the funniest shiat I have read in a long time.
But seriously the rim gaps work awesome and are easy to do (I helped ruff do em) and you can get any backspacing you want without flipping the rim (so that the "long" bead is still on the inside so that you put the beadlock on the outside "short" bead).
And they also run straighter than they did to start with.
Sam
Land Rover SIIa, 302W, NP435, NP205, MOG404s, 42in Swamper TSLs, 112in WB
"An expert is somebody who learns more and more about less and less until one day they know absolutely everything about nothing."
- home of aussie rock crawling.
Strange Rover is offline   Reply With Quote Quick reply to this message
Old 09-23-2002, 10:02 PM   #20 (permalink)
Member # 13627
Send a message via AIM to 1248bullitt
I'm interested. lol
Wes
1248bullitt is offline   Reply With Quote Quick reply to this message
Old 09-23-2002, 10:22 PM   #21 (permalink)
Member # 13731
Bootie Fab is the best!! I can't stop laughing.....
uglyscout is offline   Reply With Quote Quick reply to this message
Old 09-24-2002, 05:28 AM   #22 (permalink)
Member # 8565
Hey dude "Bootie Fab" is not to be laughed at this is some serious shit going on here we are offering a revolutionary, totaly amazing,never been done before new service.
Old 09-24-2002, 05:32 AM   #23 (permalink)
NIC
Member # 2150
Send a message via ICQ to NIC Send a message via Yahoo to NIC
but only if you phone with in the next 15 minutes, and be one of the first 10000000 callers and will we through in free RooNuts, the bootie fab australian version of the trucknuts with that "downunder" appeal.
NICK
someone who has everything has everything to lose. BEN HARPER
www.outerlimits4x4.com
NIC is offline   Reply With Quote Quick reply to this message
Old 09-25-2002, 03:29 PM   #24 (permalink)
Member # 6588
this is no kidding around, its engineering at its finest
[COLOR=green]
[/COLOR]
