Inphobic's Early Bronco Rebuild and Rehash - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-28-2009, 11:35 AM   #1 (permalink)
inphobic's Avatar
Member # 8422
Send a message via AIM to inphobic
I bought my second bronco in 1997. I was actually looking for a new tub for my 1976 when I came across a 1971 basket case project. It was completely dissambled, but it had an Arizona tub, two set's of axles, 2 engines and three transmissions. Plus all the cool parts sourced for a really nice build. After 6 months of HARD AT IT frame off it was up and running. The first test was a trip to Colorado in the summer of 98 to check out the new fuel injected mustang engine. It was awesome! I could run all the mountian passes with out messing with the carburator!
Jake Good
inphobic is offline   Reply With Quote Quick reply to this message
Old 10-28-2009, 11:45 AM   #2 (permalink)
inphobic's Avatar
Member # 8422
Around 2000 I had been saving for gears and lockers and finally bit the bullet and ordered 4.56 gears, a detroit for the rear and an EZ Locker for the front. Of course that didn't last long with 33's. After my first trip to Disney Oklahoma I came home and bought 36" SX's. I did the spring hinge plate thing under the rear springs and a 5.5" lift coil for the front. It was scary.... I sawpped in some 5.5 lift leafs in the back and that help quite a bit. I also went from wheels spacers to try to make it stable to full width half ton 9" and Dana 44. Gearing was improved with a 4:1 Klune and a NP 205 transfer case. I traded my AOD for a C4 with the right adapter. I got laid off so I went to work linking the suspension. Front recieved a wristed arm style with a single lower on the passenger and the rear was a wishbone upper 3-link.
Jake Good
Old 10-28-2009, 11:55 AM   #3 (permalink)
inphobic's Avatar
Member # 8422
I swapped to 38.5" SX's and full hydro steering for a number of years. My driving style was fairly conseravative and the D44 survived quite well for many years. 2005 came with the Ultimate Adventure adn the bronco saw some new sheetmetal and a quick facelift for the trip. This also brought the switch to BFG Krawlers in the 37" size. But as with most things you keep pushing the limits and the spidertrax housings were becoming popular so I built a Junkyard "609". Scott Angell and I did an Exo-Cage on a Toyota pick up in exchange for a dana 60. At that point I swapped to a triangulated lower fourlink and reused my old lower links for upper links.
(I'm not sure what pictures I have here since I can't see flickr at work.)
Originally Posted by inphobic
Getting ready to weld the inner c's All the brackets are welded and ready to go.
here's a pic showing the mock-up of the four link. Took a bit of work to get the driveshaft and steering to clear.
Jake Good
Old 10-28-2009, 12:02 PM   #4 (permalink)
inphobic's Avatar
Member # 8422
Also a new cage was built since I was tired of getting hung up on the "C hoop" of the old cage. The bronco has been to the Hammers, Moab, Colorado, Katemcy, Hot Springs, Flat Nasty, SMORR, Tellico, Black hills and many places in between. The rear axle is getting pretty tired, still with 31 spline shafts and the body is due for another round of straighting.
Jake Good
Old 10-28-2009, 12:03 PM   #5 (permalink)
fenderbmxer86's Avatar
Member # 55521
Im in the process of a EB build so more pics the better.
fenderbmxer86 is offline   Reply With Quote Quick reply to this message
Old 10-28-2009, 12:10 PM   #6 (permalink)
Member # 3007
I have liked this rig since I got into wheeling and met you in Disney IIRC. You've had this a loooong time.
Bones is offline   Reply With Quote Quick reply to this message
Old 10-28-2009, 12:12 PM   #7 (permalink)
inphobic's Avatar
Member # 8422
Well my first order of business is the rear axle because once I move the rear axle back another 2" to 99" of Wheelbase I will move the opening around to make it look "right". I know one thing that after owning two spidertrax housings, one here and one in the comp rig, I want one for the rear. Being tired of tearing out u-bolts straps out of the low pinion 9" I definitely wanted a High Pinion 9. Of course with two kids an unstable job market I just couldn't do a Tru-High 9 like I wanted so I set about finding a more fitting redneck way.... It'll be cheaper right?
I posted up on a 4wd forum local to Fort Riley, KS Military base in search for some H1 portal boxes. Not long after I had a set of 4 boxes, hopefully I won't need spares but I have two if I do! I sought after these because they had a little less lift than a unimog and in turn a little better gear ratio with only a 1.92:1 vs the mogs 2.13. This way I can try to keep it as streetable as possible and cut the body as little as I can.
With some help from D and D Machine in Belton, Mo and Harley0706 we have the adapter plate designed and ready to be milled. I will be switching to 8-lug chevy outers on my 609 front axle in order to match the 8 bolt rear H1 pattern.
Jake Good
Old 10-28-2009, 12:29 PM   #8 (permalink)
inphobic's Avatar
Member # 8422
Haha I have so many wheeling pictures you wouldn't beleive it.
http://www.flickr.com/photos/good-photos
http://www.angelfire.com/ks/broncostuff/
Is the website I had when I started building the bronco. The last update was around 98.
It's been quite a while since you sold the yota! Maybe one of these days we'll get back on the trails together again! Maybe I could get a moped and run single tracks...
Jake Good
Old 10-28-2009, 12:34 PM   #9 (permalink)
Member # 3007
I am sure I can provide you with a suitable ride. Me getting another rig is not going to happen with my location and zero desire to build anything. I enjoy going to events and helping where I can.
Old 10-28-2009, 12:45 PM   #10 (permalink)
Member # 8990
Holy shit Jake, clean up your garage and for those that read this whole thing he "can't" just get a Hi9 like he wants so he is doing this portal thing. He wants to be like JR and Lee with a EB and some sort of portal 9 combo.
RubberBellyRacing
Special Thanks To The RBR Crew
"Be more concerned with your character than your reputation because your character is what you really are, while your reputation is merely what others think you are"
John Wooden
Jeff Knoll: What do you need to see anyway, the spotter is driving, your just a monkey at that point, the only thing you need is to follow orders, and have brass balls.
wheatfield is offline   Reply With Quote Quick reply to this message
Old 10-28-2009, 01:13 PM   #11 (permalink)
inphobic's Avatar
Member # 8422
Don't forget one of the coolest crusier owners Nolen Grogan
Jake Good
Old 10-28-2009, 01:28 PM   #12 (permalink)
Moderating Midget
wngrog's Avatar
Member # 1154
Send a message via AIM to wngrog
Nolen Grogan
2016 4Runner TRD Pro
1998 Land Cruiser
1984 FJ-60
2013 RZR-XP4
USAF Veteran 1988-1998 GOD Bless America
wngrog is offline   Reply With Quote Quick reply to this message
Old 10-28-2009, 01:48 PM   #13 (permalink)
inphobic's Avatar
Member # 8422
Originally Posted by wngrog View Post
Hey Nolen, what are your thoughts on the portal since you've had both?
Jake
Jake Good
Old 10-28-2009, 01:53 PM   #14 (permalink)
Moderating Midget
wngrog's Avatar
Member # 1154
It was a cool deal never diffing out. Really cool. I don't think I would want one in the front because you would have to build it up so high to clear the axle and the engine.
Overall, the expense is not really worth the cool factor to me.
Nolen Grogan
1998 Land Cruiser
1984 FJ-60
2013 RZR-XP4
Old 10-28-2009, 02:18 PM   #15 (permalink)
inphobic's Avatar
Member # 8422
Yeah I already have oil pan to steering ram clearance issues so there is no way to move the front axle up 4" and keep the same ride height. The front will not change except for a 5.13 ring and pinion and 8 lug hubs. The rear will be like putting the axle back in the stock location...
A couple of things that are going to keep it lower budget for me is I plan to use 31 spline shafts in the rear and a factory 9" center section. At least to start. I have broke several factory housings but maybe the portal hub might buy me some time with it.
Jake Good
Old 10-28-2009, 05:32 PM   #16 (permalink)
Vertical Limits
blacksheep10's Avatar
Member # 26443
Very cool Jake, I need to get by and see it sometime.
Kelly Kaiser
Vertical Limits Inc
blacksheep10 is offline   Reply With Quote Quick reply to this message
Old 10-28-2009, 06:08 PM   #17 (permalink)
Take a Knee
Mudinyeri's Avatar
Member # 44531
After having a TJ with portals, I agree 100%. Not on a full body rig. On a buggy where you have more latitude to move things around ... maybe.
Edit: Cool EB. Can't believe you didn't list Tuttle Creek as one of the many places you've wheeled it.
Medium Speed, Some Drag
Mudinyeri is offline   Reply With Quote Quick reply to this message
Old 10-28-2009, 07:05 PM   #18 (permalink)
braxton357's Avatar
Member # 14685
Send a message via AIM to braxton357
Same here. I've had that second set of pics saved for quite a few years now. Has always been a cool bronco, can't wait to see what's next.
Did you ever have problems with the big hoop b-pillar hanging up too?
In vino veritas
73 linked 5.8efi Bronco
braxton357 is offline   Reply With Quote Quick reply to this message
Old 10-28-2009, 08:22 PM   #19 (permalink)
Member # 26616
I wouldn't say it got hung up but it had lots of scrapes and scratches on it. It is now different and slides better He surely has a new picture of it.
94 Jeep Wrangler
http://www.rubberbellyracing.com
rubberbelly is offline   Reply With Quote Quick reply to this message
Old 10-28-2009, 08:38 PM   #20 (permalink)
kbebs's Avatar
Member # 16271
Looking good as always. Nice "upgrades" !!! Hopefully we can get you to come to the southeast again sometime. Now we will have to take you to either Ky. or Tn since Tellico is closed. Either place we like to ride is 3.5 hrs from the garage. Hint, Hint.........
Karl
KBEBS
a few ebs, a few mods
kbebs is offline   Reply With Quote Quick reply to this message
Old 10-28-2009, 08:48 PM   #21 (permalink)
inphobic's Avatar
Member # 8422
Yeah actually there is a tree on the four fingers trail in Hot springs Ar that caught the b-pillar. It fits nicely in the dent the quarter panel has.... Went back after the new cage and it does not hit the body at all now.
Karl
Yeah you guys have so many places to wheel over there now it is unreal. Keep me in mind I'd love to join ya sometime!
Jake
Jake Good
Old 10-30-2009, 08:39 AM   #22 (permalink)
SIRJR's Avatar
Member # 46338
I'm crushed that I wasn't in any of the OCBR 09 pics. You better hurry up your plans for our trip in a couple of weeks.
77 Bronco with a little attitude & 76 Bronco Buggy and a Jimmy's Rig with a LOT of ATTITUDE!
SIRJR is offline   Reply With Quote Quick reply to this message
Old 10-30-2009, 09:41 AM   #23 (permalink)
inphobic's Avatar
Member # 8422
It will start coming apart once I get back. Of course we have the comp rig to get ready for next season too!
Jake Good
Old 10-30-2009, 10:16 AM   #24 (permalink)
KyleQ's Avatar
Member # 83837
Very cool Bronco man!
74' Bronco - Fi-Tech Injected 357W - Locked D60, Powr-Lok 70U - Twisted Demon C4 -Atlas2 3.8 - PSC Full Hydro - 5.5" lift - Cage Arms - 43" TSL SX on H1 Beadlocks
KyleQ is offline   Reply With Quote Quick reply to this message
Old 11-08-2009, 10:33 PM   #25 (permalink)
Member # 31763
Cool EB...looking forward to this round of mods.
craigellis77 is offline   Reply With Quote Quick reply to this message
