General metal fabrication - Page 15 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-03-2011, 06:29 PM   #351 (permalink)
WA-HCRC's Avatar
Member # 39184
Originally Posted by J Bruce View Post
A quick smack on the floor If you tap the outside of the bend on a hard surface it will open up the bend a little. Don't hit it hard enough to deform the tube - just hard enough to release some of the pressure from the bend. Works best with bends over 45-60 degrees.
Do you make your cages out of Exhaust tubing?
I put a peice in my bender backwards to pull some bend out of it, Kinked it.
Dont overbend shit
WA-HCRC is offline   Reply With Quote Quick reply to this message
Old 03-03-2011, 06:41 PM   #352 (permalink)
JR
OG13 King
JR's Avatar
Member # 8524
A receiver hitch on a truck also works.
JR is offline   Reply With Quote Quick reply to this message
Old 03-03-2011, 07:35 PM   #353 (permalink)
redtruggy's Avatar
Member # 107862
this works great or when my bender stand was mounted to the floor i welded a few 4 in peices of diff size tube to the floor plate just stick end of tube with bend in the right size tube on floor and pull
im the reason for spellcheck
if you dont like my crap build your own!
redtruggy is offline   Reply With Quote Quick reply to this message
Old 03-04-2011, 11:00 AM   #354 (permalink)
AxleIke's Avatar
Member # 51681
Did that one. Ended up smacking myself in the chest when it came loose. Good to know I'm not the only one doing it that way though!
cool idea!.
Unfortunately I have hydro and no place to mount it down.
So rule number one is, don't over bend it, and two is, start working out a lot cause its just a matter of muscling it back into position if you do over do it.
Thanks!
99 4Runner.
AxleIke is offline   Reply With Quote Quick reply to this message
Old 03-04-2011, 11:02 AM   #355 (permalink)
AxleIke's Avatar
Member # 51681
Originally Posted by WA-HCRC View Post
Dont overbend shit
Funny
This is like when my buddy ran his f350 outta diesel, and he checked the owners manual in the truck and looked under, "what to do if you run out of fuel". Answer: "Don't run out of fuel".
99 4Runner.
Old 03-31-2011, 05:53 PM   #356 (permalink)
JR
OG13 King
JR's Avatar
Member # 8524
Bracket die
The female die started with a piece of sc 40 pipe. The male is 2" tubing. The disk are are left over pieces from hole saw cuts.
When I weld stuff like this I don't worry about appearance, I just push the rod in like toothpaste.
Took about 45 minutes to make the die set.
Old 03-31-2011, 05:57 PM   #357 (permalink)
JR
OG13 King
JR's Avatar
Member # 8524
Nothing fancy. I made my reservoir brackets from .090" 4130
Old 04-21-2011, 01:17 PM   #358 (permalink)
Member # 102887
Bump for the best thread ever! Keep them coming!
We all would rather have a mill, but eh here is another way to use a router on aluminum. I used a 1/4" 4 flute end mill bit and grinders grease. Just turn the speed down all the way and let the cutter do the job and worked great!
Oh yeah and EARMUFFS!
Dustin Crawford is offline   Reply With Quote Quick reply to this message
Old 04-21-2011, 04:33 PM   #359 (permalink)
Member # 96014
JR, your's are fancy compaired to mine. I just welded some lock collers together.
V
The American Indians found out what happens when you don't control imagration.
Milky is offline   Reply With Quote Quick reply to this message
Old 04-21-2011, 06:40 PM   #360 (permalink)
Member # 139330
Originally Posted by AxleIke View Post
God I love this thread. However, I have a question for those who bend a bunch of tube. I'm just starting off, and what have you guys used to spread tubes in the event you bend too far, and just need to go back a few degrees?
Use a V shaped tree outside in the summer, A vise on a heavy bench in the winter, and When I'm feeling lazy I have my fat friends stretch em out...
MNtal is offline   Reply With Quote Quick reply to this message
Old 04-21-2011, 07:05 PM   #361 (permalink)
SlamBone's Avatar
Member # 136717
When ever I get a new tube die I first Cut 2 36" pieces and chuck them up in a lathe and make an index mark 6 inces from the end and bend one to a 90 and one to a 180 for templates. Name:  ImageUploadedByTapatalk1303433968.721714.jpg
" look up and live "
85 cj 7 60's 40" stickys, lq9 6.0 ,t-18,built dana 300 (look up and live)
SlamBone is offline   Reply With Quote Quick reply to this message
Old 04-21-2011, 07:16 PM   #362 (permalink)
SlamBone's Avatar
Member # 136717
This is my home made press I built. It started it's life as a 25 ton oil filter crusher that the garage at my place of employment threw away because they got a newer model. So I took it apart and built a frame and re wired it and it kicks ass!!!Name:  ImageUploadedByTapatalk1303434557.590076.jpg
This here I have got to give all the credit too my buddy Fc ( don Fc fab ) I copied his set up and it works great. I can bend up to 3/8 plate to 90 no prob. I mostly use it on 1/4 and smaller. Thicker material I take the midle tube out. Then material I keep the tube in. Name:  ImageUploadedByTapatalk1303434415.089354.jpg
Size:  44.9 KBName:  ImageUploadedByTapatalk1303434352.006821.jpg
Size:  53.7 KBName:  ImageUploadedByTapatalk1303434481.689551.jpg
Old 04-21-2011, 07:21 PM   #363 (permalink)
SlamBone's Avatar
Member # 136717
These work great for holding up tube for doing cage work. They are adjustable, I want to make two more half that size for tighter spots. Another great idea I got from Fc. Name:  ImageUploadedByTapatalk1303435088.168755.jpg
Old 04-21-2011, 07:25 PM   #364 (permalink)
SlamBone's Avatar
Member # 136717
Just a adjustable roller
this is one of my favorite and most used tools when found tube work. I got it a harbor freight for $100 and it kicks ass!Name:  ImageUploadedByTapatalk1303435389.481008.jpg
Old 05-11-2011, 06:51 PM   #365 (permalink)
SlamBone's Avatar
Member # 136717
Just made this stand for outside use. Name:  ImageUploadedByTapatalk1305161399.103327.jpg
Old 05-11-2011, 07:03 PM   #366 (permalink)
Member # 115241
Send a message via AIM to varsis
anyone got any good tips for getting something perfectly square on a frame, when it's not on a straight portion? Like I can get it very close but i prefer exact if possible. Im recessing into the frame with some 3.5x3.5 1/4" wall tube. I only have certain fab tools at home. I drew a line but I can only get it so accurate with an angle grinder. Any tips? or should I make a jig of solid square pipe and use that?
1997 Dakota, 4x4 green almost on 38's with 5.38 gears! and shift kit, with 5.9L mag. 64" deavers rear.
varsis is offline   Reply With Quote Quick reply to this message
Old 05-13-2011, 05:45 AM   #367 (permalink)
Wish it was my job!
foley's Avatar
Member # 2134
Send a message via AIM to foley
diamond measure off a reference point that you trust, or get to a part of the frame where the rails are parellel and measure off a T square.
I swear hell is full of cedar, scorpions and flat hot non-alcoholic beer.
foley is offline   Reply With Quote Quick reply to this message
Old 05-13-2011, 10:24 AM   #368 (permalink)
SpineTx's Avatar
Member # 1499
V
did these come in the exact size you needed or did you have to modify the ID's? Great idea and looks great too.
Pain is your Mind Failing you;
Body Damage is your driving ability failing you
SpineTx is offline   Reply With Quote Quick reply to this message
Old 05-13-2011, 07:47 PM   #369 (permalink)
Member # 96014
Thanks. I just got some that matched the OD of the shock hoops and OD of the shock revs. then welded them together. You can buy the lock collers in just about any ID you need.
V
Old 05-24-2011, 12:14 PM   #370 (permalink)
AxleIke's Avatar
Member # 51681
Another question for the guru's.
I recently got a set of Dimple Dies. Love em. But, I don't think they'll handle much over 1/8", or so I've read.
For gussets on suspension or link mounts, etc..., is dimpled 1/8 going to cut it, or should I forget trying to save some weight and make the gussets 1/4, which is what the brackets are made of? Or, to be a little more clear, I am making all of the link brackets out of 1/4. Is 1/8" dimpled going to be enough to brace them?
99 4Runner.
Old 05-24-2011, 01:11 PM   #371 (permalink)
Member # 7086
Link boxing can be thinner. I use .120 4130 for the lower brace, .090 4130 for the top. Link tabs are .250 4130 with weld washers
NO LIMIT CREW
CA_YJ is offline   Reply With Quote Quick reply to this message
Old 05-24-2011, 02:51 PM   #372 (permalink)
Wilson's Avatar
Member # 7233
I've dimpled 1/4" takes about 90 tons
Old 05-24-2011, 04:18 PM   #373 (permalink)
K5runner@hotmail.com's Avatar
Member # 96153
What trick do you guys use when you use the dimple dies? I drilled a bunch of holes and after I was done with the die the sheet metal (.120) ended up in a U shape. I have herd of just flipping the dies around and giving it a slight press, but that just made the dimples less dimpled. I'm using a hand pump 20 ton bottle jack, and pumping till I can't with a 12" bar. I'm think that I need to reinforce my press if I need to add more pressure. Do the dies need to press after its dimpled to flatten the rest of the metal? Pics
Offroad Design ♦ Atomic MC ♦ Jantz Engineering
K5runner@hotmail.com is offline   Reply With Quote Quick reply to this message
Old 05-24-2011, 04:19 PM   #374 (permalink)
Member # 96153
I had to hammer the fuck out of the back side on my bench to get it back to flat.
Old 05-24-2011, 04:22 PM   #375 (permalink)
Jeepman14wheel's Avatar
Member # 46071
Pretty common for the metal to deflect when using Dimple Dies.
Instagram @mike_fought
Jeepman14wheel is offline   Reply With Quote Quick reply to this message
