info on Ford Super Duty Dana 60 axle - Page 125 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-15-2017, 08:00 AM   #3101 (permalink)
Member # 181868
Originally Posted by TrailTamer XJ View Post
I’m the OP of this thread. I didn’t think this will be a popular topic at the time I made this thread.
Actually, I think this thread should be left alone, beside deleting gibberish at most.
My suggestion; make a “Super Duty Dana 60 Bilble” tech article, basically similar to Billavista’s Dana 60 bible tech article except it’s all about 99+ Ford D60s. AAANNNDDD most importantly! It get updated/corrected as new, correct and reliable info come up, update on axle shaft upgrade manufacturer availability (but thus section will get deleted whenever they finally catch up and everyone make/sell them), new SD D60 generations come up, etc.
Thoughts? I’m willing to work on this as time permits.
This sounds logical. I have to admit when I got my axle, this thread was already going. I went back and read the whole thing. I don't mind the chit chat while doing that. (I even enjoy it) But now, every so often I need to reference something I know is in here, but hard to find sometimes. (Even in search)
Edit, the "bible" could reference this this thread, so people could read it if so inclined.
Project : Amphibious HEMTT
Old 12-15-2017, 09:11 AM   #3102 (permalink)
Member # 140878
I just PM’d some guys on here to get the ball rolling. I’m looking forward to the outcome! I’m sure it’ will be far more informative and more detailed than BillaVista’s original Dana 60 bible.
Edit: we will share a link to the database for public viewing. I’m pretty sure we will ask for some some of your help with pictures to add to the database.
TrailTamer XJ is online now   Reply With Quote Quick reply to this message
Old 12-15-2017, 11:11 PM   #3103 (permalink)
Member # 140878
I'm working on the unit bearing section. I pretty much learned that there's 7 different unit bearings part#s for 05-16 year range.
FYI.... Motorcraft brand unit bearings for a 2017 F350 on Rockauto is dirt cheap when compared to 2016-down unit bearings.... stock up if you have the desire to do so.
Old 12-16-2017, 12:27 AM   #3104 (permalink)
Member # 684754
excellent, glad to see the project is started up, as my 99-04 project started about a month ago!
RMKrawler is offline   Reply With Quote Quick reply to this message
Old 12-16-2017, 02:02 PM   #3105 (permalink)
hi-steer ninja
FORDTECHGURU's Avatar
Member # 104639
Glad to see a tech thread coming, you will find the differences will be abs sensor related mostly. Ford likes to supersede part numbers too.
FORDTECHGURU is online now   Reply With Quote Quick reply to this message
Old 12-16-2017, 04:28 PM   #3106 (permalink)
Member # 140878
Three main types are;
1) DRW & SRW hubs aren’t same (thread length and pitch).
2) two ‘generations’, 05-10 and 11-16. Dimensionally they’re same.
3) F-450 and F-550 have 10 lugs.
4*) not really that matter but, the “Pick Up” (non-C&C) F-450 use their own unit bearing (8 lugs). They use a different part#.
Old 12-16-2017, 04:51 PM   #3107 (permalink)
Member # 206522
what is the part number on em? and do 2017 ub interchange with 8lug 2005-2016?
urmaster85 is offline   Reply With Quote Quick reply to this message
Old 12-16-2017, 04:54 PM   #3108 (permalink)
Member # 140878
So far I haven’t find the dimension on 2017-current D60 unit bearings. Just look up 2017 F350 on rockauto. While you’re at it, look up 2016 F350 and you’ll see what I mean.
Old 12-16-2017, 05:57 PM   #3109 (permalink)
Member # 53528
i do believe that was for 2011-2013 450s, i know the 08-10s pickup 450s had the 10 lugs and good brakes, and i do believe in either 14 or 15 they went back to the bigger brakes and 10 lug
Old 12-18-2017, 01:24 PM   #3110 (permalink)
Member # 208624
I tried combing through, but does anyone know off hand if the 1550 long side assembly has enough meat on the shaft to respline for a rear steer? Would the OEM 1550 assembly hold up in a rear steer application? I'm wanting to build a rear steering axle out of the 05 D60 and D80 I have sitting in my garage...
I'll keep looking for diameters...
Mountain Havoc Alum - '16
3rd place passenger seat ballast and pointer of rocks
93_Fummins is offline   Reply With Quote Quick reply to this message
Old 12-18-2017, 01:54 PM   #3111 (permalink)
Member # 129055
I can take some measurements when I get home later today.
https://www.pirate4x4.com/forum/chevy/2575401-damn-blue-chevy-2003-silverado-build.html
mccustomize is offline   Reply With Quote Quick reply to this message
Old 12-18-2017, 02:11 PM   #3112 (permalink)
Member # 208624
Much appreciated, sir.
Best I can tell, there was a post about Branik resplining some, so maybe it can be done. Looks like the high horse guys stretch the ears and trash the yokes eventually. I'm not high horse, and don't wheel as often as most, so maybe it'll be a low-er cost solution to rear steer until I can afford big bell RCV's or CTM's.
Old 12-18-2017, 05:39 PM   #3113 (permalink)
Member # 135096
I have had 99-04 shafts cut down and resplined 35. Hudlowe in TN
Cat037 is offline   Reply With Quote Quick reply to this message
Old 12-18-2017, 06:01 PM   #3114 (permalink)
Member # 703953
Moser or Hudlow did the cut and spline on some 1480 stock long side a few years ago for a rear steer D70 I had.
Pretty sure Hudlow did the chromos that replaced them too. The axle lives under a Tacoma in Michigan now
eat.sleep.wheel is online now   Reply With Quote Quick reply to this message
Old 12-20-2017, 04:05 PM   #3115 (permalink)
Member # 343466
So why hasn't a single company started making affordable chromolies for these yet? Yukon, g2, Revolution, etc. The options on the market cost as much as a set of RCV's.
wvjeepguy81 is offline   Reply With Quote Quick reply to this message
Old 12-20-2017, 04:43 PM   #3116 (permalink)
Member # 129055
Gah! I completely forgot, I will take the measurements tonight along with a couple pictures for you.
Old 12-20-2017, 04:45 PM   #3117 (permalink)
Member # 185920
Yukon does for the 99-04 atleast.
time2getdirty is offline   Reply With Quote Quick reply to this message
Old 12-20-2017, 06:56 PM   #3118 (permalink)
Member # 343466
Yeah, many companies do. Those aren't desirable for swaps now that we have the 05+ at a good price.
Old 12-20-2017, 08:03 PM   #3119 (permalink)
YotaAtieToo's Avatar
Member # 25632
I hate to ask more questions but I'm not sure how to search this.
I'm thinking about picking up an 05+ Front and narrowing/switching to pass drop. My plan would be to use factory gm 60 shafts. As most know, they work out to 69.5" wms with kingpin outters, what will they work out to with the balljoint/ub outters?
Should work well with a 69" wide 99-04 rear (which I have laying around)
Old 12-20-2017, 11:02 PM   #3120 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
There's 3.87" difference between the total of SD inners vs Chevy. So if you subtract that from the 72.5" width of the 05 axle you get 68.63".
Old 12-20-2017, 11:37 PM   #3121 (permalink)
Member # 25632
Thanks, I guess I could have looked that up. I was thinking about trying to figure out center of u joint to wms.
I'm surprised that it's less on the superduty stuff than the older stuff. Maybe I'll need to figure out a slightly different shaft setup to make it so the front isn't narrower than the rear.
Old 12-20-2017, 11:42 PM   #3122 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
The SD inners are overall wider. But you were talking about making the axle narrower by using the older stuff right?
Here's a screen shot of the spreadsheet I keep to track it all:
Old 12-21-2017, 12:05 AM   #3123 (permalink)
Member # 25632
Not so worried about the width, as much as moving the diff in a little. Looks like the 78-79 Ford short side is the longest option. Or just get some 550 shafts and cut and respline the long side.
Do you have the 450/550 shaft measurements?
Old 12-21-2017, 10:27 AM   #3124 (permalink)
Member # 69441
IIRC the short side 450/550 is 19” end to center of joint
Lj stretched Dana 80s 47s coilovers 5.8 aodw 203 205
99grandtj is offline   Reply With Quote Quick reply to this message
Old 12-21-2017, 05:20 PM   #3125 (permalink)
cheapthrillb2's Avatar
Member # 108736
I run the chevy/dodge long inner on the passenger side, narrowing the housing Right side 4"s. Works well matching to my 14bolt in my LJ.
cheapthrillb2 is offline   Reply With Quote Quick reply to this message
