info on Ford Super Duty Dana 60 axle - Page 134 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-14-2018, 12:06 PM   #3326 (permalink)
Member # 267321
I have jk calipers and a couple sets of rotors you can have if you are local.
wellstig1 is offline   Reply With Quote Quick reply to this message
Old 06-14-2018, 12:39 PM   #3327 (permalink)
Member # 111955
1/2 ton dodge rams are 5 on 5.5 rotors. 13.5"ish diameter. Twin piston calipers that are bigger than JK too.
tbuff02 is offline   Reply With Quote Quick reply to this message
Old 06-15-2018, 06:41 AM   #3328 (permalink)
caryt's Avatar
Member # 27775
Originally Posted by snowracer View Post
be nice if could use the ultimate 60 inner C with 11-16 knuckles as can buy them cheap from ford and come with ball joints.
MEF-249 | MOTORCRAFT MEF-249 Steering Knuckle
Those don't look like any Ford knuckle...never seen a Ford Knuckle with a window ..
caryt is offline   Reply With Quote Quick reply to this message
Old 06-15-2018, 06:56 AM   #3329 (permalink)
Member # 703953
Been talked about many times in this thread. 09+ have windowed knuckles.
Originally Posted by FORDTECHGURU View Post
05-08 is same, 09-12.5 is the next generation, 12.5-16 is different again. For 250-350 axles. The main change is the outer knuckle castings. 12.5 started the bigger brakes, 09-12.5 had the windowed castings with a slight castor change. 05-08 is what 95% of people are building out there..
eat.sleep.wheel is offline   Reply With Quote Quick reply to this message
Old 06-15-2018, 07:21 AM   #3330 (permalink)
caryt's Avatar
Member # 27775
10-4 missed that..I've seen '05-08's and never noticed the holes on the later ones...guess need to look closer
Old 06-15-2018, 07:55 AM   #3331 (permalink)
Member # 22267
Send a message via AIM to HEEPJEEP
Originally Posted by defbob View Post
I ordered a pair of Spicer Ultimate inner Cs
Thanks!
YJ and Corey-So buy some then. I've always wanted a pony. Ponies are badass. Do I have a pony? No.
HEEPJEEP is offline   Reply With Quote Quick reply to this message
Old 06-15-2018, 07:58 AM   #3332 (permalink)
Member # 22267
Originally Posted by chris demartini View Post
If anyone can get picture comparison of the ultimate 60 inner C to a stock 05-10 inner C, it would be greatly appreciated.
I can try to remember to take these pictures for you. I have an 09 housing sitting in the shop to compare against.
Old 06-15-2018, 07:59 AM   #3333 (permalink)
Member # 22267
Originally Posted by cheapthrillb2 View Post
Where did we end up with the ball joint conversation, I need to replace my Spicer ball joints. I think i got 2-3 years out of the lowers on full hyd locked and 4ds Wheeling and dd'ing. But they won't warranty them. Any "over the counter" parts store options? I don't think moog would have lasted as long. Just reinstall another set of spicers? Who's got the best deal on the big hub seals inside the knuckles?
We have pretty good deals, but I need to get with admins to get vendor status. Trying to just provide tech and answers.
Old 06-15-2018, 09:22 AM   #3334 (permalink)
Member # 196160
Originally Posted by HEEPJEEP View Post
Thanks!
My Inner Cs arrive tomorrow. I’ll have picks and specs by Sunday
1983 Bobbed CJ8 6.0/4L80/Atlas 3.0. UB D60/UB 14bolt, 42” Pitbull Rockers
1946 CJ2A
defbob is offline   Reply With Quote Quick reply to this message
Old 06-15-2018, 12:25 PM   #3335 (permalink)
Member # 181868
I missed the discussion on the windows. What is the purpose?
Project : Amphibious HEMTT
Old 06-15-2018, 12:50 PM   #3336 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
I don't recall there being a purpose. Just a casting change that they made. I guess it makes the knuckle lighter and uses less material?
Old 06-15-2018, 02:53 PM   #3337 (permalink)
Storing Junk
Lincolnman's Avatar
Member # 257906
That was my understanding, it was just an update to save weight and cost.
Casting is casting, it is not like the window is machined out and adds to the process.
Electronics work on magic smoke, don't let it out.
Lincolnman is offline   Reply With Quote Quick reply to this message
Old 06-16-2018, 04:12 AM   #3338 (permalink)
Member # 196160
My inner Cs arrive in a couple hours... I feel like a little kid on Christmas.
1946 CJ2A
Old 06-16-2018, 09:41 AM   #3339 (permalink)
Member # 5326
I'm really curious to see if this works....
Old 06-16-2018, 12:36 PM   #3340 (permalink)
Member # 196160
It's a match
http://www.moparts.com/tim/1.jpeg
http://www.moparts.com/tim/2.jpeg
http://www.moparts.com/tim/3.jpeg
http://www.moparts.com/tim/4.jpeg
1946 CJ2A
Old 06-16-2018, 12:47 PM   #3341 (permalink)
Member # 196160
I'm heading to my storage unit to compare it to the factory inner C and knuckle
1946 CJ2A
Old 06-16-2018, 01:32 PM   #3342 (permalink)
Member # 196160
They match the stock inner C!! I’ll upload the picture when I get home.
1946 CJ2A
Old 06-16-2018, 02:44 PM   #3343 (permalink)
Member # 703953
Go back and edit your previous incorrect post also if you don’t mind.
Looks like a good option to get all new parts for a decent price and not have to mess with sourcing and cutting apart an old axle
Old 06-16-2018, 03:05 PM   #3344 (permalink)
desertCJ's Avatar
Member # 9026
Send a message via AIM to desertCJ
They "Fit" when they are assembled...not when they look like they will fit. I will say that I think they probably will, but Its not done until it's done.
desertCJ is offline   Reply With Quote Quick reply to this message
Old 06-16-2018, 04:39 PM   #3345 (permalink)
Member # 196160
I measured everything. If they are correct, it may have .875 degree positive camber. My measurements could be off, but that is well within “factory tolerance”. They make 2.5degree cams and everywhere in between. The balljoint separation is the same.
1946 CJ2A
Old 06-16-2018, 04:40 PM   #3346 (permalink)
Member # 196160
I tried deleting it but it won’t let me. I’ll see if I can edit it this late.
1946 CJ2A
Old 06-17-2018, 12:16 PM   #3347 (permalink)
Member # 196160
13.05 - .55 = 12.5degree inclination....
The measurement with the ruler is from the top castle nut surface to lower castle nut surface
http://www.moparts.com/tim/8.jpg
http://www.moparts.com/tim/5.jpg
http://www.moparts.com/tim/7.jpg
http://www.moparts.com/tim/6.jpg
http://www.moparts.com/tim/9.jpg
1946 CJ2A
Old 06-17-2018, 01:02 PM   #3348 (permalink)
Member # 1636
Excellent pictures thank you!
chris demartini is offline   Reply With Quote Quick reply to this message
Old 06-18-2018, 05:17 AM   #3349 (permalink)
Member # 21282
[/IMG]
so can you summarize what's going on here in one post?
You ordered brand new inner C's? F350 or F550?
they work with Reid's new knuckles? I thought they were kingpin?
they work with stock 350 or 550 outer knuckles??
part number?
Recommended Stuff:
91blaze is offline   Reply With Quote Quick reply to this message
Old 06-18-2018, 06:27 AM   #3350 (permalink)
Member # 196160
part number?
They are Spicer Ultimate 60 inner Cs. No one was sure if they would work with ‘05 F350 Superduty knuckles.
https://downtofab.com/products/spicer-2023561
1946 CJ2A
