info on Ford Super Duty Dana 60 axle - Page 135 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-18-2018, 09:12 AM   #3351 (permalink)
Member # 1636
Did you disassemble the 09 axle and/or cut the inner C's off yet?
chris demartini is offline   Reply With Quote Quick reply to this message
Old 06-18-2018, 09:38 AM   #3352 (permalink)
Member # 196160
I only cut the radius arm brackets off
1983 Bobbed CJ8 6.0/4L80/Atlas 3.0. UB D60/UB 14bolt, 42 Pitbull Rockers
1946 CJ2A
defbob is offline   Reply With Quote Quick reply to this message
Old 06-18-2018, 04:23 PM   #3353 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
Originally Posted by 91blaze View Post
so can you summarize what's going on here in one post?
You ordered brand new inner C's? F350 or F550?
they work with Reid's new knuckles? I thought they were kingpin?
they work with stock 350 or 550 outer knuckles??
part number?
Thank you. I was afraid I was the only one who was unable to follow along.
Old 06-18-2018, 08:52 PM   #3354 (permalink)
supersize75k5's Avatar
Member # 29341
Originally Posted by defbob View Post
Im building an Aqualu bodied CJ/LJ. Im using my Reid knuckles. Im actually no longer using anything off of my 09 Superduty axle. Im still going to use the rear Sterling though. Im going to use the stock rims with rock guards at first then later on switch to deep backspacing beadlocks. Trailready makes an 8.75 rim with 6bs. Im also going to use my 12 Ram 3500 steering box too. Im trying out a few things that are out of the norm.
I cant be the only one lost but other than the knuckle/steering, what is the benifit of any of this?
supersize75k5 is offline   Reply With Quote Quick reply to this message
Old 06-18-2018, 09:09 PM   #3355 (permalink)
Member # 703953
Reid makes f250/350 size ball joint knuckles now (in addition to the Super Kingpin knuckles & Cs which are essentially 05+ F250/350 size but use old 60 kingpin parts)
eat.sleep.wheel is offline   Reply With Quote Quick reply to this message
Old 06-19-2018, 02:43 AM   #3356 (permalink)
Member # 196160
Exactly. The only thing was Reid doesnt make an inner C for the balljoint knuckle. No one did until Spicer released their Ultimate 60 builder parts. Now you have two cheaper options on building a custom axle to take 1550. Reid Superduty knuckles or the Spicer Ultimate 60 outer kit. The Superduty is obviously the cheapest.
1946 CJ2A
Old 06-19-2018, 02:47 AM   #3357 (permalink)
Member # 196160
Im building an axle with the pumpkin in a more desirable location. With theses parts, someone could build a passenger drop Superduty axle or a Fab9 or 14 bolt with 1550 joints. It just adds options to people.
1946 CJ2A
Old 06-19-2018, 06:01 AM   #3358 (permalink)
Member # 1636
A Junkyard local-ish to me sells 05+ outer knuckles with unit bearings on them for $100 a side. Add these knuckles and I can build a 609 without having to drag a whole housing home, cut the inner C's off, have them machined then throw out the rest of the axle.
Old 06-19-2018, 06:58 AM   #3359 (permalink)
Member # 208624
They are Spicer Ultimate 60 inner Cs. No one was sure if they would work with 05 F350 Superduty knuckles.
https://downtofab.com/products/spicer-2023561
Awesome! I've been waiting for U60 builder parts to show up.
Mountain Havoc Alum - '16
3rd place passenger seat ballast and pointer of rocks
93_Fummins is offline   Reply With Quote Quick reply to this message
Old 06-19-2018, 06:59 AM   #3360 (permalink)
TrailTamer XJ's Avatar
Member # 140878
This.
TrailTamer XJ is offline   Reply With Quote Quick reply to this message
Old 06-19-2018, 07:03 AM   #3361 (permalink)
Member # 140878
Originally Posted by TrailTamer XJ View Post
Ultimate Dana 60 is a product sold by Dana Aftermarket. Theyre a direct bolt in for JKs.
https://downtofab.com/collections/ul...-dana-60-parts
https://danaaftermarket.com
Read this link on how to look up Ultimate Dana 60 stuff on Dana Aftermarket website.
http://media.spicerparts.com/cfs/fil...store=original
Yeah, for real, U60 inner Cs & steering knuckles are reasonably priced but their wheel end kits seem to be really expensive, though.
Old 06-19-2018, 07:45 AM   #3362 (permalink)
Member # 208624
I'm mainly excited by the ultimate shafts: 1550, 4340 and they offset the diff in further (best I can tell). But, yeah, they are set up for the "live spindle" wheel end kit, which I'm not sure is worth it or not. Might just run the inners, shorten the long side tube, retube the short side, and throw on OEM stubs to just use the stock unit bearings. Or at least that was my daydream intention... I'm wanting to run SD60s in a CJ8 and every inch of diff offset I can get will help immensely, especially with off the shelf parts.
Old 06-19-2018, 01:46 PM   #3363 (permalink)
Member # 196160
Ultimate 60s have a pinion offset of about 8” from center of axle
1946 CJ2A
Old 06-19-2018, 01:59 PM   #3364 (permalink)
Member # 208624
Ultimate 60s have a pinion offset of about 8 front center of axle
Sweet! Thanks!!!
Old 06-19-2018, 05:45 PM   #3365 (permalink)
Member # 140878
Sweet! Thanks!!!
Did you read the link in my post? (3364)
Old 06-20-2018, 04:59 AM   #3366 (permalink)
Member # 208624
Yes, I did. Also very helpful. I'm not sure how I missed all these builder axle program things. I had previously been trying to communicate with Dynatrac on sourcing the JKU60 inner axles and inquiring about the "live" hub conversion as I thought it was proprietary to them, but their sales department wasn't much help. Didn't realize until now that it was available through Dana. Awesome news to me either way.
Old 06-20-2018, 10:06 AM   #3367 (permalink)
Member # 208352
Originally Posted by cheapthrillb2 View Post
Where did we end up with the ball joint conversation, I need to replace my Spicer ball joints. I think i got 2-3 years out of the lowers on full hyd locked and 4ds Wheeling and dd'ing. But they won't warranty them. Any "over the counter" parts store options? I don't think moog would have lasted as long. Just reinstall another set of spicers? Who's got the best deal on the big hub seals inside the knuckles?
Originally Posted by sleepsontoilet View Post
I'm still looking for a suitable lower BJ solution to go with those.
I am the only one (as far as I know), producing a ballpoint delete kit for the 99-04 Ford SD axles. Been doing it for over a year and have quite a few kits out there beating them. Zero failures thus far. Just sent out a DIY kit last week. My kit works best with the JHF hi-steer kits.
06silverback is offline   Reply With Quote Quick reply to this message
Old 06-20-2018, 11:54 AM   #3368 (permalink)
Member # 208624
Sorry, for clarification, NO I did not read your post or links when you first posted them, but I'm catching up on the thread now. Lots of awesome info I somehow missed in my brief PBB hiatus. The Dodge brake bit was handy too, so thanks for that! Just wish the 8x6.5 stuff wasn't super high, like you alluded to...
Old 06-20-2018, 02:01 PM   #3369 (permalink)
Member # 196160
Originally Posted by mj View Post
iis there a crush sleeve eliminator kit available for these d60s?
For those wanting to use the Super 60 10” gears and do away with the crush sleeve. I just got my mine in the mail today.
Yukon Dana 60 Crush Sleeve Eliminator # RPSSPD60-.539
Yukon D60 shim pack # SK34801
1946 CJ2A
Old 06-20-2018, 05:55 PM   #3370 (permalink)
Member # 96496
Location: Flowery Branch, GA (yes.. like a branch with f**kin pretty pink flowers on it...)
I just setup a set of those Nitro 10 gears last weekend. Really dont know why theyd go with a crush sleeve.
The 4:56 set was also not a 32/7 tooth count like listed on their website. Normal 41/9.
My Cummins makes enough power to break a NV271...
mrdrinksalil is offline   Reply With Quote Quick reply to this message
Old 06-21-2018, 06:51 PM   #3371 (permalink)
Member # 196160
If someone needs an F550 inner shaft with 1550 joints to narrow for any custom width housing requiring a shaft 37.875” or shorter, part #EC3Z-3219-D. My Spicer F350 long shaft came in and I realized that it necked down to 1.450” after the splines for about 1.5” before going back to 1.590” diameter. So I cancelled the second one and ordered a ‘15 F550 shaft since they start out at 41.375” long. The F350 shaft is 38.93” long, but is only 35” long before necking down. The F550 shaft is 37.875” before necking down.
1946 CJ2A
Old 06-22-2018, 03:00 PM   #3372 (permalink)
desertCJ's Avatar
Member # 9026
Send a message via AIM to desertCJ
Seems like you should still be able to get a very wide axle with a 35" blank? How wide are you trying to get?
desertCJ is offline   Reply With Quote Quick reply to this message
Old 06-22-2018, 04:24 PM   #3373 (permalink)
Member # 127171
Does anyone have a good source for a quality 05+ lower balljoint?
sleepsontoilet is offline   Reply With Quote Quick reply to this message
Old 06-22-2018, 07:53 PM   #3374 (permalink)
Member # 189367
Dynatrac. Expensive, but strong and rebuildable
I had good life from ACDelco Professional ball joints.
betarocker is offline   Reply With Quote Quick reply to this message
Old 06-22-2018, 09:13 PM   #3375 (permalink)
Member # 196160
I’m retaining the 05+ Superduty width. I’m just moving the pumpkin over. So instead of a 38.93” long shaft and 16.69” short, my housing takes a 36.6” and a 19”.
1946 CJ2A
