info on Ford Super Duty Dana 60 axle - Page 136 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-22-2018, 07:53 PM   #3376 (permalink)
Member # 189367
Originally Posted by sleepsontoilet View Post
Does anyone have a good source for a quality 05+ lower balljoint?
Dynatrac. Expensive, but strong and rebuildable
I had good life from ACDelco Professional ball joints.
betarocker is offline   Reply With Quote Quick reply to this message
Old 06-22-2018, 09:13 PM   #3377 (permalink)
Member # 196160
Originally Posted by desertCJ View Post
Seems like you should still be able to get a very wide axle with a 35" blank? How wide are you trying to get?
I’m retaining the 05+ Superduty width. I’m just moving the pumpkin over. So instead of a 38.93” long shaft and 16.69” short, my housing takes a 36.6” and a 19”.
1983 Bobbed CJ8 6.0/4L80/Atlas 3.0. UB D60/UB 14bolt, 42” Pitbull Rockers
1946 CJ2A
defbob is offline   Reply With Quote Quick reply to this message
Old 06-24-2018, 09:15 AM   #3378 (permalink)
TrailTamer XJ's Avatar
Member # 140878
OEM BJs not good enough?
If not, I’ll definitely give TTX BJs a shot
https://www.rockauto.com/en/moreinfo...411&cc=1432130
TrailTamer XJ is offline   Reply With Quote Quick reply to this message
Old 06-24-2018, 02:06 PM   #3379 (permalink)
Member # 196160
Spicers not good enough? You can get a Spicer set (upper and lower) for $70 a side.
Spicer #708238
1946 CJ2A
Old 06-24-2018, 02:26 PM   #3380 (permalink)
mj
Member # 1919
when they make a proper bible for this a list of the kits available from spicer for servicing should be included.
mj is offline   Reply With Quote Quick reply to this message
Old 06-24-2018, 04:58 PM   #3381 (permalink)
Member # 127171
Stock BJs were shot, so I need a set of lowers for all 4. I'm ok with cheap as long as it isn't gonna fall apart every 6 months.
EDIT: Just found them for that price
http://www.drivetrainamerica.com/708...350-2005-2012/
sleepsontoilet is offline   Reply With Quote Quick reply to this message
Old 06-25-2018, 05:49 AM   #3382 (permalink)
Member # 208624
Hijack: How are you stretching the short side? I want to do the same thing but on the fence between splicing with a sleeve or just retubing the short side.
Mountain Havoc Alum - '16
3rd place passenger seat ballast and pointer of rocks
93_Fummins is offline   Reply With Quote Quick reply to this message
Old 06-25-2018, 09:22 AM   #3383 (permalink)
Member # 196160
I cheated, I ordered a brand new custom housing from ECGS
1946 CJ2A
Old 06-26-2018, 03:30 PM   #3384 (permalink)
Member # 196160
ECGS just sent me pics of my housing. And my driver side knuckle showed up.
http://www.moparts.com/tim/12.jpg
http://www.moparts.com/tim/11.jpg
http://www.moparts.com/tim/10.jpg
1946 CJ2A
Old 06-26-2018, 08:58 PM   #3385 (permalink)
desertCJ's Avatar
Member # 9026
Send a message via AIM to desertCJ
Looks like a Dana Ultimate 60 "Builder" housing or whatever they call it?
desertCJ is offline   Reply With Quote Quick reply to this message
Old 06-27-2018, 02:46 AM   #3386 (permalink)
Member # 196160
The center is, but the tubes are 1/2” wall instead of .370. It is also wider and the pumpkin is 1” outward vs an Ultimate 60
1946 CJ2A
Old 06-27-2018, 02:53 AM   #3387 (permalink)
Member # 196160
EMWest, Fusion4x4, and ECGS all use the Spicer center but use their own tubes. They are welded better too, no spinning the tubes...
1946 CJ2A
Old 06-27-2018, 05:26 AM   #3388 (permalink)
Member # 208624
Very nice!
Are you able to share cost of that setup, by chance?
Old 06-27-2018, 07:19 AM   #3389 (permalink)
Member # 196160
Very nice!
About $1500 total. Even with all new parts, I figure I should have an assembled front axle with a detroit locker for $3700.
1946 CJ2A
Old 06-27-2018, 07:47 AM   #3390 (permalink)
Member # 208624
Awesome! Thanks. /hijack
Old 07-01-2018, 11:24 AM   #3391 (permalink)
Member # 267321
Is there anybody currently making chromoly 1550 inner shafts in 35 or 40 spline? Or stubs in chromoly/300m? I talked to dynatrac and they sell 40 spline 1550 shafts for their xd60 axles the guy I talked to a guy who wasn't really sure about pricing/availability to get a set made to custom length. I'm assuming some company is making the forgings for them so somebody must have access to them.
wellstig1 is offline   Reply With Quote Quick reply to this message
Old 07-01-2018, 12:24 PM   #3392 (permalink)
Member # 196160
Branik’s 2pc will be ready by the end of July. Dynatrac told me they will not sell custom inner shafts, only entire axle assemblies.
1946 CJ2A
Old 07-01-2018, 02:05 PM   #3393 (permalink)
Member # 267321
Did Branik hint as to what they are looking at for pricing?
Old 07-01-2018, 03:41 PM   #3394 (permalink)
Member # 196160
$530 per 2pc shaft in 4340 Chromoly. About $2120 for all 4 shafts minus u-joints. Didn’t ask about 300m
1946 CJ2A
Old 07-04-2018, 10:41 AM   #3395 (permalink)
Member # 135096
Dana / Spicer parts #2013558-2 is listed as a 7.03 stub 1550 joint and 19" inner.
Is there a OEM Ford part # for this combo?
Cat037 is offline   Reply With Quote Quick reply to this message
Old 07-04-2018, 04:16 PM   #3396 (permalink)
Member # 196160
19.31” inner.
But the F550 LH inner shaft is 19.12”
https://fortwayneclutch.com/product/...sku-2013340-2/
1946 CJ2A
Old 07-04-2018, 04:17 PM   #3397 (permalink)
Member # 196160
Found this on an earlier page
Originally Posted by patooyee View Post
I do see these though, all use a 1550 joint with the shorter stub shaft:
Stub #2006099, 7.03" long
Spicer #2013563-1
Inner shaft #2013554-1, 41.54" long
Spicer #2013563-2
Inner shaft #2013554-2, 19.31" long
Spicer #2013558-1
Spicer #2013558-2
Inner shaft #2013551-2, 19.31" long
They both add a little more width over even the previously discussed 550 shafts.
Maybe one of those is what MNTal has pictured? Dana's site does not list an application for it ... maybe they are a special option 350 of some sort?
1946 CJ2A
Old 07-04-2018, 05:09 PM   #3398 (permalink)
Member # 135096
I saw that as well. I am needing a 7.03 stub, 15.50 joint and a 19.1 or a 19.3" inner shaft length. Spicer #2013563-2 is fine just looking for a Ford part # as they seem to be more cost effective.
Old 07-05-2018, 04:26 PM   #3399 (permalink)
Member # 196160
I know this isn’t exactly “Superduty” haha
Ultimate Super 60 pictures
1946 CJ2A
Old 07-05-2018, 09:40 PM   #3400 (permalink)
Member # 11928
so a little off subject, but what has been found for master cylinders for manual brakes for the 05+ brakes? I might have overlooked it trying to read all of this.
BUCKWILD 66 BRONCO F/W 60'S 538'S ARB DETROIT
BUCKWILD is offline   Reply With Quote Quick reply to this message
