info on Ford Super Duty Dana 60 axle - Page 148 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-18-2018, 05:23 PM   #3676 (permalink)
Member # 196160
Originally Posted by jemarshall View Post
Could you please get a measurement from the back side of the C, to the face of the knuckle where the unit bearing mounts?
If possible, also the the mounting face of the unit bearing?
I havenít havenít been in this thread in a while. Iíll get the measurements this weekend for you.
1983 Bobbed CJ8 6.0/4L80/Atlas 3.0. UB D60/UB 14bolt, 42Ē Pitbull Rockers
1946 CJ2A
defbob is offline   Reply With Quote Quick reply to this message
Old 12-18-2018, 05:34 PM   #3677 (permalink)
jemarshall's Avatar
Member # 50690
Send a message via MSN to jemarshall
What's out there to mount the wilwood calipers, or is everyone running them just building their own mounts?
What ever you do, please do not suck start a shot gun.
Stick it up your ass...that way you're likely to hit something vital.
jemarshall is offline   Reply With Quote Quick reply to this message
Old 12-18-2018, 05:56 PM   #3678 (permalink)
TrailTamer XJ's Avatar
Member # 140878
Originally Posted by FORDTECHGURU View Post
99-15 f250 350 is same ball joints..
99-04 f450 550 is same bj as f250, same spacing also.
05-up f250 350 larger spacing than 99-04
05-up f450 550 larger yet and larger ball joints
Picture of 99-04 250, 99-04 450 and 05Up 250 left to right
Originally Posted by Black Sheep View Post
Could only find 05+ specs.
Are the 99-04 F450/550 2wd mono tube knuckles the same as 4x4 ?
Should be same, excluding center section, shafts and different unit bearings. I think, anyway. But, the 99-04 F450/550 knuckles are a little different, to move calipers outward for the >14Ē rotors.
TrailTamer XJ is offline   Reply With Quote Quick reply to this message
Old 12-18-2018, 06:00 PM   #3679 (permalink)
wvracer821's Avatar
Member # 260337
Not sure whatís involved but I stumbled across this today in my internet travels.
http://www.pmfsuspension.com/2005-12...its_p_155.html
Today, I broke my own personal record for most consecutive days lived
wvracer821 is online now   Reply With Quote Quick reply to this message
Old 12-18-2018, 06:24 PM   #3680 (permalink)
jemarshall's Avatar
Member # 50690
2005-12 Ford F-250/350 4wd Wilwood Big Brake Kits
Thanks.
Is it just my tendency to overbuild things, or does the caliper mount bracket look chincy?
Old 12-18-2018, 06:26 PM   #3681 (permalink)
jemarshall's Avatar
Member # 50690
I don't need it anymore, already got rid of the others I had and went with the SD outers.
Old 12-18-2018, 08:09 PM   #3682 (permalink)
Fl-Krawler's Avatar
Member # 47337
Jesse Haines was selling brackets for the wilwood calipers
Fl-Krawler is offline   Reply With Quote Quick reply to this message
Old 12-18-2018, 09:42 PM   #3683 (permalink)
Member # 127171
Branik is making a Kit
sleepsontoilet is offline   Reply With Quote Quick reply to this message
Old 12-19-2018, 06:53 AM   #3684 (permalink)
E-Locker or Bust!
DMANbluesfreak's Avatar
Member # 163019
Originally Posted by 6gun View Post
Building my axles so that I can SAS my '99 Ranger and I wanted to get opinions. Part of my goal with this build is "Build it once" so here's my question. 06' axle came with the 1480 joints and they are in pretty good shape. Would it be worth the $375 or so to go ahead and buy the 1550 joints?
Specs for the rig are fairly mild 4.0(to be upgraded to 5.8 in the future), AT, 1354 TC, 5.38 gears, Truetrac ft/Grizzly locker rear, 39-42" tires.
Rig will be used for exploring, and what most of you would consider mild wheeling. Kind of a big gay mall crawler that can survive being used without falling apart. I can't see ever being able to break 1480 joints but........
You'll be fine with the 1480s if you're not going to beat on it in the rocks, more than likely. If the joints ever do go bad, I'd spend the $380 on the 1550 shafts since they come with fresh spicer joints and knuckle seals.
2001 Z71 Silverado, Ext. Cab, 5.3L V8 -
Shortened 17" w/Bed, AAM 14B FF w/ Grizzly, Dana 60 HP, Anti-Wrap Bar
4L80e, EcoBox/205 Doubler, 40" ProComps, Rock Sliders, Hidden Winch, Hydro Assist
DMANbluesfreak is offline   Reply With Quote Quick reply to this message
Old 12-21-2018, 02:21 PM   #3685 (permalink)
snowracer's Avatar
Member # 141697
so has anyone been able to fit a 16.5 or even a 16 inch wheel on a 05+ diff? can i swap brakes to clear them or am i stuck with the 04 and older stuff?
PLAN-B F250 on 44s
snowracer is offline   Reply With Quote Quick reply to this message
Old 12-21-2018, 02:44 PM   #3686 (permalink)
Member # 481466
Some 16.5 wheels fit with a little clearancing on the calipers
LS-YJEEP is online now   Reply With Quote Quick reply to this message
Old 12-21-2018, 02:51 PM   #3687 (permalink)
Member # 166616
16.5 h1 wheels with 2" spacers. I had to shave off about 1/8" on the caliper.
Justdhutch is offline   Reply With Quote Quick reply to this message
Old 12-21-2018, 02:54 PM   #3688 (permalink)
snowracer's Avatar
Member # 141697
re centered h1 or stock with spacers?
PLAN-B F250 on 44s
Old 12-22-2018, 10:51 AM   #3689 (permalink)
Member # 196160
The Reid SD unit bearing mount face to the inner weld point of the Spicer Ultimate inner C is 10.25Ē
1946 CJ2A
Old 12-22-2018, 05:22 PM   #3690 (permalink)
Member # 686858
I have recentered H1ís with pressed centers and they clear the calipers fine with no clearancing required.
DZ Fab is offline   Reply With Quote Quick reply to this message
Old 12-22-2018, 07:08 PM   #3691 (permalink)
Member # 21215
Location: Tennessee...The land of high horsepower and low IQ
I thought this was mildly relevant to this thread. This will be hands down the easiest, most cost effective way to build a full 40 spline rear axle.
300m kit - https://www.markwilliams.com/50265.html
4340 kit - https://www.markwilliams.com/50255.html
3.5" floater cups - https://www.markwilliams.com/50290.html
4 floater cups - https://www.markwilliams.com/50295.html
MW is telling me they are dedicated to growing this offroad market. Just recently they carved out an off-road section of the website to keep things from getting buried in their plethora of street parts.
https://www.markwilliams.com/off-road.html
The bartender only serves brown liquor in hell, and that sure sounds like heaven to me.
redneckengineered is offline   Reply With Quote Quick reply to this message
Old 12-23-2018, 08:01 AM   #3692 (permalink)
Member # 166616
Stock so I have 5" BS
Old 12-23-2018, 08:06 AM   #3693 (permalink)
mcutler1's Avatar
Member # 167368
That's terrific. And competitively priced. I believe unit bearings on 4 corners are definitely the way to go. Never drop a wheel bearing in the frozen creek on grapevine (Harlan ky) again...
Sent from my SM-G892A using Tapatalk
90's throw back manche build
Last buggy Build thread;
LS2, th350, atlas 3.0, spidertrax 9's, 39's.
mcutler1 is offline   Reply With Quote Quick reply to this message
Old 12-23-2018, 10:16 AM   #3694 (permalink)
sterlingfire's Avatar
Member # 232666
That's exactly where i want to go. 14 bolt rear with sd unit bearings. Spindle bearings suck ass in water and mud. Everyone i tell that's what i want to do with my rear axle says im stupid and unit bearings are worse than spindle bearings.... the only issue i see is having the units drilled for 8x6.5, but if the dodge units will work, that is a very viable solution imo
Originally Posted by 03f350
... Well first off FUCK JEEPS..
sterlingfire is offline   Reply With Quote Quick reply to this message
Old 12-23-2018, 04:34 PM   #3695 (permalink)
Member # 1636
If you're running them on all four corners, why redrill? Plenty of beadlocks available in 17" for 8x170 lug pattern.
chris demartini is offline   Reply With Quote Quick reply to this message
Old 12-23-2018, 06:55 PM   #3696 (permalink)
MOORETOYX4's Avatar
Member # 112499
Got a couple of questions. Iím running 99-04 outers on a set of fabricated 9Ē housings. Iím running first gen tundra brakes (rotors and calipers). The calipers mount the same as earlier Toyota ifs calipers, and I thought I read in here somewhere that Wilwood calipers were basically the same as far as mounting holes. I have some brackets that bolt to the knuckles and the caliper then mounts to that bracket. The brackets I have were made on a plasma table and I was wondering if anyone made a bracket for this already? Next question is on the rear axle Iím using TG pockets for the unit bearings with the same brakes. I was wondering if the caliper brackets TG sells would work for Toyota calipers, if they are in fact the same as a wilwood caliper.
The next issue I have is my drive slugs. I have ecgs drive flanges on the front and rear. When they are all bolted up there is some play in the cap not letting them seal completely. Basically the slug inside is all the way against the cap and canít go any tighter, is that normal? Thanks in advance, hopefully this stuff hasnít already been asked, this thread is super long yet very helpful.
BFR Grunt Buggy
MOORETOYX4 is offline   Reply With Quote Quick reply to this message
Old 12-23-2018, 07:14 PM   #3697 (permalink)
Member # 232666
Because of what i currently have. I doubt with the big changes im making that I'll be able to afford a new set of beadlocks along with all the other stuff
Old 12-23-2018, 07:40 PM   #3698 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
Redrill them using @patooyee Ďs drill jig.
https://patparts.com/products/sd60-m...ug-drill-plate
Old 12-23-2018, 09:39 PM   #3699 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
I see that stated everywhere as well. I don't know how that rumor got started but it's not true. I make a Rockwell pinion brake kit that uses the toy callipers you speak of as well as one that uses a wilwood. When I designed the wilwood I specifically spoke with my wilwood rep trying to find a caliper that matched the Toyota bolts. (So that I could use the same bracket.)
At the time they did not make one, which I confirmed using their website as well. I assure you that the Toyota bracket and wilwood bracket that i manufacture are different.
Now I know nothing about tundra brakes, but if they're the same as old mini truck mounting dimensions then wilwood doesn't make a direct swap caliper.
Old 12-23-2018, 09:42 PM   #3700 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
Redrill them using @patooyee ‘s drill jig.
Thank you!
But I'm with Chris. If you're using them on all 4 corners just stay with 8x170.
