info on Ford Super Duty Dana 60 axle - Page 157 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-30-2019, 03:21 PM   #3901 (permalink)
Member # 196160
I have a set of warns on order
1983 Bobbed CJ8 6.0/4L80/Atlas 3.0. UB D60/UB 14bolt, 42 Pitbull Rockers
1946 CJ2A
defbob is offline   Reply With Quote Quick reply to this message
Old 05-31-2019, 06:32 PM   #3902 (permalink)
Member # 196160
I got my selectors in today. They appear very well made. The gears are chromoly, the selector is aluminum, but the spring retainer is.... plastic. I don’t think it is load bearing at all or else they would have made it out of metal. The Yukon Hardcores I installed in my friend’s d44 seem beefier, but Yukon does not make a SD one yet. I’ll see if these live with 42s. Most likely will. The gears are very nice in these.
1946 CJ2A
Old 06-07-2019, 04:56 PM   #3903 (permalink)
Member # 196160
https://www.instagram.com/timmybilt/...=1cjaeewoob23y
1946 CJ2A
Old 06-09-2019, 09:27 AM   #3904 (permalink)
Member # 95025
Originally Posted by brokenFSJ View Post
Just for comparrison, here is a similar pic of an 05' and up super 60 (f450/550):
[IMG][/IMG]
The Super60's are a little bigger in some area's than the regular 05' and up 60's. Here are a few more pics of a super60 that I am converting to 8 lug (metric):
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Yes they do have 1550 ujoint's
[IMG][/IMG]
These axles are very wide though. Even after converting it to single wheel 8 lug wheel hubs, it will still be about a 79 wms.
Very interesting/informative.
ΜΟΛΩΝ ΛΑΒΕ
President Trump on building the wall:
"THIS IS WHERE WE HOLD THEM!!! THIS IS WHERE WE FIGHT!!! THIS IS WHERE THEY'RE DEPORTED!!!"
V.P.Pence:
BUILD THIS WALL, BOYS!!!
Fearless Indians:
Awe-Ooo!!!
CDA 455 is offline   Reply With Quote Quick reply to this message
Old 06-09-2019, 09:40 AM   #3905 (permalink)
Member # 95025
Originally Posted by Pro Form Fabrication View Post
Another option for these axles is use the 92-97 Ford Ball Joint knuckles and you will get rid of the unit bearings and have the 8x6.5 bolt pattern. We have converted 3 axles so far using the knuckles out from those years.
Another option bolt pattern wise, Currie is redrilling the unit bearings and rotors on these to 8x6.5 pattern. I don't know the cost as we haven't had one done as of yet but a customer was telling me about it.
If you are content with unit bearings, ORU makes a high steer knuckle for the Super Duty axles that goes for $259.00. Most of the unit bearing failures are from high speed, dedicated trail rigs usually don't have those issues. The only people who will suffer with the unit bearings will be the rigs that pull double duty between trail and daily driving.
Derek
Originally Posted by brianZ71 View Post
I thought you could only use the 92-97 knuckles on the 99-04 axles, but I could be wrong.
Also, why is everyone so intent on getting rid of the 8x170? Carry your own spare(s) and you'll never have an issue. Yeah wheels are a little harder to find, but it's less effort and money than swapping out everything and then re-converting to 35 spline outers.
Good info fo moi!
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 06-09-2019, 09:50 AM   #3906 (permalink)
Member # 95025
[QUOTE=GreatWhiteXJ;14073652]
Originally Posted by 92solidaxlechevy View Post
Wrong. Theres tons of was to identify it without tearing it appart. First, theres a sticker on the lond side tube. In the corner it will either say 248 or 229. 248 is the measurment of the ring gear in milimieters. 248 mm=9.75 inches. Which is the diameter of a Dana 60 ring gear. You can also tell by the pinion nut. 1 5/16 is D60.....1 1/4 is D50. You can also tell by the diff itself. The 60 measures about an inch longer than a 50.
I are lovin' this thread!
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 06-09-2019, 10:02 AM   #3907 (permalink)
Member # 95025
Originally Posted by mcamish01 View Post
This is what I mean by SHORT. OEM '05+ SD D60 stub.
Though, once the OEM lockouts are removed there is room to use longer, custom stubs for ease of machining and full hub spline engagement. Here are some custom Yukon 4340 stubs I had made.
And finally, just for the sake of getting some pics in this thread, here are some of my high steer set up and hubs (redrilled 8x6.5)
Very nice!
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 06-09-2019, 10:21 AM   #3908 (permalink)
Member # 95025
Originally Posted by ILF150 View Post
Can you put the 10" super 60 gears in the 99-04 housings?
Originally Posted by FORDTECHGURU View Post
yep.. the 03-04 v10's with 4.30 gears were the 10" gear....
Will these super 60 gears be labeled 'super 60' when ordering them from R&P companies?
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 06-10-2019, 12:27 AM   #3909 (permalink)
Member # 95025
Originally Posted by FguyTJ View Post
I know its been asked, and going back through I don't see anywhere that its been answered... what is the wms-wms of the 05+ axles vs that of the 99-04?
Originally Posted by pcoplin View Post
I think my front 03 60 was 69, the rear 01 10.50 was 68, if that helps.
Good to know.
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 06-10-2019, 01:18 AM   #3910 (permalink)
Member # 95025
Originally Posted by mudtruck44 View Post
I'm about to release a "do it yourself" weld on high steer kit for the 99-04 Super Duty stuff, $165. Also selling caliper brackets to use Trail Gear/Spidertrax 14" rotors and Wilwood calipers for $45.
Very nice!
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 06-10-2019, 09:06 AM   #3911 (permalink)
Member # 95025
Originally Posted by patooyee View Post
Took apart a 2015 F-450 Monobeam today. The knuckle has a giant freeze plug to seal the back side:
The UB is not a 4wd UB. The area where someone earlier thought that Rocksolid was machining for splines is not thick enough for that. That or they are using some other UB that is:
The 05 F250/350 8-lug UB bolts in place where the 2WD 10-lug was just fine:
'05 250/350 inner C on left, '15 450/550 inner C on right:
Outer knuckles side by side. I don't know what my camera is doing in the first pic because it makes them look about the same size when the 450/550 is much bigger. The second pic is more accurate:
Can you update these pics, please?!
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 06-10-2019, 09:19 AM   #3912 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
Sorry, no. I guess I deleted them at some point.
Old 06-10-2019, 09:30 AM   #3913 (permalink)
Member # 95025
No prob.
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 06-11-2019, 07:44 AM   #3914 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
For anyone looking, rock auto just got the long side 1550 shafts in again. (10013778). Still waiting on the short side.
Old 06-11-2019, 06:41 PM   #3915 (permalink)
Member # 95025
Originally Posted by GreatWhiteXJ View Post
In short.....find a broken BJ knuckle.
To every 1 balljoint 60 knuckle failure you can find, you'll find 1,000 cracked or broken KP knuckles.
The knuckles on my 02' BJ 60 make KP knuckles look like 44 knuckles. I am yet to find a single failure of my type of knuckle. The 05'+ knucks are even bigger. I cant offer any conclusive facts but I SERIOUSLY doubt you'll break one.
Good info.
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 06-12-2019, 07:58 AM   #3916 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
I take this back. They just sent me an email saying their inventory was wrong.
Old 06-12-2019, 08:02 AM   #3917 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
And now they just sent me an email saying the short side was in stock. (10013781) Maybe they will be right this time?
Old 06-12-2019, 10:55 AM   #3918 (permalink)
Member # 188843
I doubt it :
https://www.pirate4x4.com/forum/rock...r-service.html
Bebop is offline   Reply With Quote Quick reply to this message
Old 06-12-2019, 11:05 AM   #3919 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
Haha, thanks.
Old 06-12-2019, 11:15 AM   #3920 (permalink)
arse_sidewards's Avatar
Member # 256962
Originally Posted by Bebop View Post
I doubt it
Take yer swing!
Old 06-12-2019, 11:42 AM   #3921 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
Well they just sent me a tracking number on 10013781 so maybe I got lucky. We'll see what's in the box when it arrives I guess.
Old 06-12-2019, 06:38 PM   #3922 (permalink)
Member # 95025
Originally Posted by twoslo4five0 View Post
Four wheel supply the cheapest place to buy unit bearings that are bored and re-drilled for the 99-04 axles?
Originally Posted by eat.sleep.wheel View Post
But what brand bearings are they?
You can get some DIRT cheap china crap. I'd make sure they are a legit brand before purchasing.
Good info.
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 06-12-2019, 07:39 PM   #3923 (permalink)
Member # 95025
Been doing a little work on my axle. Excuse the raw mock up pics, still have some cleaning up/ reinforcing to do. First pic is 02 axle, 2"x.250 tie rod with offset tie rod ends and. 2.5 ag ram because I'm cheap lol. Ballistic cover and everything clears barley. Second pic is of the 4 whee supply timken UBs re drilled and bored. If anyone is looking they are 20% off this weekend with free shipping.
Awesome!
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 06-12-2019, 09:01 PM   #3924 (permalink)
Member # 95025
For the record, I bought a set of stock rotors and opened the holes up to .750 easily in the drill press and they slid right on to my 8x6.5 UB's. You never have to worry with having the rotor oriented correctly this way (the way I see it), I know I'm not breaking any new ground here.
That's my plan as well.
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 06-13-2019, 08:55 AM   #3925 (permalink)
Member # 95025
Originally Posted by sleepsontoilet View Post
Stock until I can afford Branik or similar.
nOOB question:
Is the Branik brake set up adequate for a towing road vehicle?
I have a '94 Bronco that I'm going to both tour the lower 48 as well as travel the backcountry.
Visit Moab and similar places as well.
I'll be towing a HMMWV trailer with a 1,000lb truck pop-up camper.
I have an '87 Sterling dually axle for the rear (with stock brakes).
My plan for the front is a stock '05 Dana 60 with Branik (or equivalent) UB 8 on 6.5s.
I'm guessing my other option (probably way cheaper too) is to drill out stock rotors to accept said 8 on 6.5s.
Thoughts/suggestions?
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
