info on Ford Super Duty Dana 60 axle - Page 165 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-20-2019, 08:14 PM   #4101 (permalink)
Member # 208352
Innovative Machining Solutions is also making kits I believe
06silverback is offline   Reply With Quote Quick reply to this message
Old 09-23-2019, 08:04 AM   #4102 (permalink)
Member # 21215
Location: Tennessee...The land of high horsepower and low IQ
Originally Posted by chris demartini View Post
I like the axle seal in the bearing cup. Makes so much more sense from a servicing standpoint to have it there than at the differential side.
Yep and eliminates the cost/headache of sourcing an inner axle seal solution which can be a pain.
https://
https://www.facebook.com/diddysbigblockraceshop/
redneckengineered is offline   Reply With Quote Quick reply to this message
Old 09-24-2019, 10:18 AM   #4103 (permalink)
Member # 95218
Has anybody put the ruff stuff radius arm kit on to the factory control arm bushing mounts of the 05 and up d60 axle in their crawler? How well does it Flex with that kit? Seems like minimal labor and cost for a lot of strength.
Im considering this for a 90 bronco crawler build that will get street driven so on road manners need to be addressed so id rather not do a 3 link.
Sent from my LG-H700 using Tapatalk
87xjmike is offline   Reply With Quote Quick reply to this message
Old 09-24-2019, 03:07 PM   #4104 (permalink)
Member # 267321
Originally Posted by pennsylvaniaboy View Post
Originally Posted by jonzer12 View Post
I can't remember where but I remember see at least 2 offroad covers that are superduty specific and claim to clear the stock tie rod. Keep looking they are out there.
all of those companies make a super duty specific cover, all good companies, just curious if any had the edge...
At least from personal experience, I would skip the motobilt as they do not machine them flat, both of mine came pretty warped and I had to put them on a big disc sander to get them to sit flat on the diffs. That's what I get for trying to save a few dollars. Ruff stuff, ballistic fab and great lake offroad all make superduty specific covers as well. Ballistic even makes a specific shave kit now as well.
wellstig1 is offline   Reply With Quote Quick reply to this message
Old 09-24-2019, 03:37 PM   #4105 (permalink)
Member # 267321
Busted knuckle now has a brake kit that would work well for streetable and lightweight brakes. Price is very nice too.
https://bustedknuckleoffroad.com/SUP...akepackage.htm
Old 09-25-2019, 08:34 AM   #4106 (permalink)
Member # 24709
Send a message via AIM to CartsXJ Send a message via Yahoo to CartsXJ
Nice!!! It looks like they are using a rear rotor....so replacements should be easy to source.
"Being a man take years of fightin, screwin, drinkin, and whorin. Then more drinkin and then more whorin...if there's time" -Trippin the Rift
CartsXJ is offline   Reply With Quote Quick reply to this message
Old 09-25-2019, 10:54 AM   #4107 (permalink)
Member # 267321
I cant figure out what application the rotor from, since the one they are using a 1.25" thick one to work with the dynalite calipers. All the superduty rotors from 1999 on up that I could find are 1.5" thick.
Old 09-25-2019, 11:09 AM   #4108 (permalink)
Jeffh555's Avatar
Member # 3775
Look at a REAR rotor. They are 1.18 thick, but I bet the .07 difference in thickness isn’t an issue.
I wheeled twice this year, that might be a personal record.
Jeffh555 is offline   Reply With Quote Quick reply to this message
Old 09-25-2019, 02:09 PM   #4109 (permalink)
Member # 24709
The 1999-2003 rear rotors are 1.18" while the 2005-08 are 1.34", so I imagine they are using the early rotors. But that is a great option for the lighter rigs, I wonder if you could still run the stock size master TJ/XJ with the wilwoods? Instead of having to swap to a dodge master for volume.
Old 09-25-2019, 02:58 PM   #4110 (permalink)
Member # 53528
i wonder why he hasnt addressed the the different years of caliper sizing on that link to the product description, im guessing his fits for 2005-2012? im sure fordguru knows the years they changed the caliper mounting on the knuckles
i know reids super kingpin knuckles take 2005-2012 calipers
Old 09-25-2019, 08:29 PM   #4111 (permalink)
Member # 267321
The piston area of those calipers are less than the oem, so your pedal would still feel close to factory.
Old 09-25-2019, 08:34 PM   #4112 (permalink)
Member # 267321
I talked to the owner on the phone, he wasn't aware that those 2013+ knuckles had the wider caliper spacing. He said he would correct the web page and will be getting a 2013+ knuckle in so he can make brackets for them.
Old 09-29-2019, 09:52 PM   #4113 (permalink)
hi-steer ninja
FORDTECHGURU's Avatar
Member # 104639
05-12' is the same, 13-16' is bigger, 17-20' is tooooo.. caliper brackets i mean..
FORDTECHGURU is offline   Reply With Quote Quick reply to this message
Old 09-30-2019, 04:28 PM   #4114 (permalink)
Member # 196160
ECGS did the same on my unit bearing 14 bolt rear, except he machined the tube for the seal
https://youtu.be/Yg1v2RLyu8c
1983 Bobbed CJ8 6.0/4L80/Atlas 3.0. UB D60/UB 14bolt, 42” Pitbull Rockers
1946 CJ2A
defbob is offline   Reply With Quote Quick reply to this message
Old 10-07-2019, 11:52 AM   #4115 (permalink)
Newbie
Member # 613210
Does anyone have the CAD file for the 05+ unit bearings? I'm looking to use the 05" Super Duty Unit Bearings for an IFS setup.
2000 4Runner Limited "BeerRunner"
AssBurns is offline   Reply With Quote Quick reply to this message
Old 10-08-2019, 07:21 AM   #4116 (permalink)
Member # 83301
Originally Posted by mudtruck44 View Post
The factory tie rod location has a lot of Ackerman. This gets you closer to neutral, like a lot of the kingpin 60 arms. Also, moving the tie rod out a little further gives you room for the single ended ram behind it. It's hard to design a "do it all" steering arm. In my opinion they should be custom for every vehicle, but obviously that's not practical. The tie rod location is 7.9" from the pivot, so almost identical to a Chevy 60.
can you describe this more...isnt ackerman good? im considering high steer kit, but also toying with a mild high steer in the stock holes.
'79 chevy k30 vortec 350/sm465/205/205/5.13's 40" NITTO trail grapplers on dirtylife beadlocks.
Old 10-14-2019, 10:27 PM   #4117 (permalink)
Member # 95025
Are the coil spring mount distances/measurement the same on an '06 F-550 as it is on an '06 F-350?
ΜΟΛΩΝ ΛΑΒΕ
President Trump on building the wall:
"THIS IS WHERE WE HOLD THEM!!! THIS IS WHERE WE FIGHT!!! THIS IS WHERE THEY'RE DEPORTED!!!"
V.P.Pence:
BUILD THIS WALL, BOYS!!!
Fearless Indians:
Awe-Ooo!!!
CDA 455 is offline   Reply With Quote Quick reply to this message
Old 10-15-2019, 06:29 AM   #4118 (permalink)
Member # 95025
Originally Posted by CDA 455 View Post
If I pick up a 'Super 60' from a '10 F-450, could I swap out the dually hubs for SRW hubs?
Anyone?
Bueller?
Anyone?
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 10-15-2019, 07:11 AM   #4119 (permalink)
TrailTamer XJ's Avatar
Member # 140878
Anyone?
Bueller?
Anyone?
Unit wheel bearing & rotor swap may be all you need to do to convert it to SRW 8 lugs (or just unbolt the adapter to turn it into 10 lug SRW)
TrailTamer XJ is offline   Reply With Quote Quick reply to this message
Old 10-18-2019, 11:15 PM   #4120 (permalink)
Member # 95025
Will the bolts be long enough?
Are they the same lugs?
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 10-22-2019, 06:14 PM   #4121 (permalink)
Rock Stacker
HydroDynamic's Avatar
Member # 65066
You will need 05+ F250/350 unit bearings and 2013+ F250 rotors with F550 calipers. The F550 calipers only clear 20” wheels though.
HydroDynamic is offline   Reply With Quote Quick reply to this message
Old 10-22-2019, 07:17 PM   #4122 (permalink)
Member # 95025
Fuck; that's a lot for this simpleton...
Dumb question:
Will said 05+ UB be big enough for the F-550's axle shafts to fit through?
IIRC; said F-550 axle shafts are HUGE.
Will I use the F-550's factory lockouts too?
Another option(?):
If I simply remove the DRW adapters and use 20" rims with a 10-on-225 lug pattern, will I be good to go then?
It looks like either way; I'll be spending about $1,400+ ($550 per custom rim, for example).
Unit bearing are almost that much too.
THANKS FOR YOUR INPUT!
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 10-22-2019, 07:51 PM   #4123 (permalink)
wvracer821's Avatar
Member # 260337
Dumb question:
Another option(?):
Spend another $300 and get another donor axle from a pickup to rob the unit bearings from. Everything else should go together without much fuss.
"Today, I broke my own personal record for most consecutive days lived."
wvracer821 is offline   Reply With Quote Quick reply to this message
Old 10-22-2019, 08:19 PM   #4124 (permalink)
Member # 95025
Didn't think of that!
Thanks!
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 10-23-2019, 09:05 AM   #4125 (permalink)
Member # 188843
Dumb question:
Another option(?):
Everything has been answered in the thread before.
Go back to page 1 and read, that how I did to figure it out.
Orrr, you buy another axle and you see what fits and what doesn't.
Bebop is offline   Reply With Quote Quick reply to this message
