info on Ford Super Duty Dana 60 axle - Page 166 - Pirate4x4.Com : 4x4 and Off-Road Forum
Register Blogs FAQ Community Calendar Premium Memberships
Old 10-23-2019, 09:47 AM   #4126 (permalink)
Member # 95025
Originally Posted by Bebop View Post
Everything has been answered in the thread before.
Go back to page 1 and read, that how I did to figure it out.
Orrr, you buy another axle and you see what fits and what doesn't.
What's up, dude?!
Hope things are well in your nape of the woods.
On to business:
You are correct.
I've read this thread at least a half dozen times cover to cover.
And 5X that just browsing for answers.
In fact; I'm currently reading it cover to cover again.
FYI: photobucket fucked up the pics; the ones directly from photobucket are fuzzy.
As stated many times in this thread; this needs to be put in 'bible' form just like Bill ďBillaVistaĒ Ansell's 14 bolt bible.
In one month this thread will be ten years old, yet is still very much alive and kicking with updated info etc.
ΜΟΛΩΝ ΛΑΒΕ
President Trump on building the wall:
"THIS IS WHERE WE HOLD THEM!!! THIS IS WHERE WE FIGHT!!! THIS IS WHERE THEY'RE DEPORTED!!!"
V.P.Pence:
BUILD THIS WALL, BOYS!!!
Fearless Indians:
Awe-Ooo!!!
CDA 455 is offline   Reply With Quote Quick reply to this message
Old 10-23-2019, 11:26 AM   #4127 (permalink)
Member # 188843
I'm doing just fine, thank you !
I'm sure that everyone would appreciate if you compile the info and make said Bible yourself
Bebop is offline   Reply With Quote Quick reply to this message
Old 10-23-2019, 11:40 AM   #4128 (permalink)
jgarden1's Avatar
Member # 584
Yes, would be very much appreciated.
Sent from my SM-G973U using Tapatalk
jgarden1 is offline   Reply With Quote Quick reply to this message
Old 10-24-2019, 09:03 AM   #4129 (permalink)
Member # 95025
Does anyone know the bolt pattern, that the DRW adapter bolts to, of the '05+ F-550 Dana (Super)60?
It looks smaller than the WMS bolt pattern (10 on 225).
This is UB/hub assembly:
This is what the DRW adapter bolts to, correct?
Or to put it another way:
If the WMS bolt pattern on the DRW adapter is 10 on 225, what is the UB/hub assembly bolt pattern?
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 10-24-2019, 09:48 AM   #4130 (permalink)
Member # 4243
TIMKEN SP940203 specs say 6.693".
CENTRIC 40265023 specs says 6.692" or 169.9mm
Dodge cobbler... (1stgen cummins theme)
u2slow is offline   Reply With Quote Quick reply to this message
Old 10-24-2019, 11:25 AM   #4131 (permalink)
Member # 95025
Would that make it a 10 on 170 (assuming it's 10 lugs) then?
Thanks for the specs.
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 10-24-2019, 11:39 AM   #4132 (permalink)
Member # 4243
I count 10... but I could be wrong
Old 10-24-2019, 12:32 PM   #4133 (permalink)
Member # 95025
Well there it is; 10 on 170!
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 10-25-2019, 04:25 PM   #4134 (permalink)
Rock Stacker
HydroDynamic's Avatar
Member # 65066
Dumb question
Will said 05+ UB be big enough for the F-550's axle shafts to fit through?
Yes 1550 shafts and joints will fit
IIRC; said F-550 axle shafts are HUGE.
Will I use the F-550's factory lockouts too?
Yes, stock manual or aftermarket manual or slugs are best, auto-lock might be an issue.
Another option(?):
If I simply remove the DRW adapters and use 20" rims with a 10-on-225 lug pattern, will I be good to go then?
Yes you can, but not worth the hassle. The 550 rear axle with matching lug pattern is not usefull based off of limited gearing and locker options. Lug pattern is smaller on the front UB without the adapter. If you use a sterling rear everything will be 8 on 170.
It looks like either way; I'll be spending about $1,400+ ($550 per custom rim, for example).
Unit bearing are almost that much too.
I got my UB online for cheap, just have to search around. Or find a good used set.
THANKS FOR YOUR INPUT!
HydroDynamic is offline   Reply With Quote Quick reply to this message
Old 10-30-2019, 08:09 AM   #4135 (permalink)
Member # 224958
Originally Posted by TrailTamer XJ View Post
Iím 90% sure 2013+ rotors & calipers brakes are direct bolt-on upgrade on 99-04 F250/350ís D50/60. Great upgrade for tow rigs without the need to use F450/550 knuckles. (2013+ caliperís brackets move caliper further to clear the 14.5Ē rotor)
I think your on to something here. It looks like ujoint offroad has something like it....
https://www.youtube.com/watch?v=s1jVGvd_cuk
CarolinaCrawler1 is offline   Reply With Quote Quick reply to this message
Old 11-04-2019, 12:31 PM   #4136 (permalink)
Member # 119511
99-04 KNUCKLES
Does anyone know exactly what needs to be done to run the lower ball joints in the upper position on the 99-04 knuckles. I know I have read about it but cant seem to find any info.
2002a642 is offline   Reply With Quote Quick reply to this message
Old 11-04-2019, 02:03 PM   #4137 (permalink)
hi-steer ninja
FORDTECHGURU's Avatar
Member # 104639
Maching knuckle for larger o.d. ball joint, special machined alignment cams, etc... $$$$
OR, we stock billet steel EMF ball joints for superduty knuckles that are rebuildable in knuckle ( if you ever wear one out) and will be stronger than the lower swap deal anyways.. uses all stock alignment cams, etc..
FORDTECHGURU is offline   Reply With Quote Quick reply to this message
Old 11-04-2019, 04:31 PM   #4138 (permalink)
Member # 267321
Those are what I am buying when my balljoints wear out eventually. I liked being able to add an extra 2 degrees of caster using the upper cams, these are essential for dialing in a vehicle that sees a lot of road miles. Emf designed theirs much better than the dynatrac balljoints, which I believe are just a small uniball inside a housing.
wellstig1 is offline   Reply With Quote Quick reply to this message
Old 11-04-2019, 04:37 PM   #4139 (permalink)
Member # 119511
emfs are big money too. Is there enough material in the alignment cams for the larger ball joint or do the Cs need to machined as well?
Old 11-04-2019, 06:22 PM   #4140 (permalink)
Member # 267321
The taper is much larger, you would have to get custom cams made, I doubt there would be enough material to adjust more than .5 of a degree though.
Old 11-04-2019, 10:16 PM   #4141 (permalink)
Unklhuck's Avatar
Member # 70595
Iíve run XRF lower BJís in the upper slot of my last two 609ís. One had Dodge dually outers and the other is an 05 SD60 outer. Not sure how much meat is there for the 99-04 outer, to be cut for the mod. Itís a pretty easy thing to do.
Weíve got a jig, so itís an easy set up and cut. We also custom cut the cam shims for proper alignment. Iíve put a lot of punishing miles on both of the 609ís. The XRF lower BJís have never let me down/gotten loose.
If thereís room to do it, do it. The mod works well and is very dependable.
Just another Phoenix redneck....
Unklhuck is offline   Reply With Quote Quick reply to this message
Old 11-08-2019, 10:02 PM   #4142 (permalink)
Member # 175478
Has anyone seen a super duty 60 like this? 10 lug and double cardan type u joint?
https://imgur.com/gallery/7f2D4v5
06 Hummer H3- 5.3/4l60e/factory H3 4:1. 3 link front, spring over rear. custom D70 front/Eaton HO72 40in STT pros
2017 invited reader Ultimate Adventure
06 H3 is offline   Reply With Quote Quick reply to this message
Old 11-08-2019, 10:56 PM   #4143 (permalink)
Cotton Farmer
Member # 167491
Send a message via ICQ to jd8420
They are in front wheel drive busses.
jd8420 is offline   Reply With Quote Quick reply to this message
Old 11-09-2019, 10:02 AM   #4144 (permalink)
Member # 175478
Can they be swapped out to stock shafts?
Old 11-09-2019, 11:18 AM   #4145 (permalink)
Cotton Farmer
Member # 167491
Yes
Old 11-11-2019, 06:15 PM   #4146 (permalink)
Member # 208352
Iíve been making the Balljoint Delete kits for a few years now that give you 3* or any combination....catch up lol
06silverback is offline   Reply With Quote Quick reply to this message
Old 11-12-2019, 05:06 PM   #4147 (permalink)
Member # 119511
I didn't say anything about a ball joint delete kit? I don't want a ball joint delete kit. Who needs to catch up?
Old 11-12-2019, 05:33 PM   #4148 (permalink)
Member # 208352
Easy there tiger, hence the ďlolĒ
Old 11-13-2019, 10:13 AM   #4149 (permalink)
Member # 103621
if anyone has the cad file handy for the 05+ SD unit bearings or for the steering knuckle, can someone measure the bolt pattern for the unit bearing mounting to the knuckle? Im going to cut out a few plates on the table to mount a spare UB on a spare tire holder. The 4-bolt flange.
tia
1982 Toyota - Dirt Squirrel - LQ4/Atlas 4.3, D60/14b w/ Reids & RCVs, 3-link/4-link, 43" stickies
the_white_shadow is offline   Reply With Quote Quick reply to this message
Old 11-13-2019, 10:20 AM   #4150 (permalink)
wvracer821's Avatar
Member # 260337
tia
Thatís a great idea
"Today, I broke my own personal record for most consecutive days lived."
wvracer821 is offline   Reply With Quote Quick reply to this message
