info on Ford Super Duty Dana 60 axle - Page 167 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-13-2019, 10:27 AM   #4151 (permalink)
Member # 103621
Originally Posted by wvracer821 View Post
Thatís a great idea
It was a buddy's idea, but yes, its a good idea to have a spare on board.
1982 Toyota - Dirt Squirrel - LQ4/Atlas 4.3, D60/14b w/ Reids & RCVs, 3-link/4-link, 43" stickies
the_white_shadow is offline   Reply With Quote Quick reply to this message
Old 11-13-2019, 10:41 AM   #4152 (permalink)
Member # 24709
Send a message via AIM to CartsXJ Send a message via Yahoo to CartsXJ
Originally Posted by the_white_shadow View Post
if anyone has the cad file handy for the 05+ SD unit bearings or for the steering knuckle, can someone measure the bolt pattern for the unit bearing mounting to the knuckle? Im going to cut out a few plates on the table to mount a spare UB on a spare tire holder. The 4-bolt flange.
tia
Off a 10 lug....but they are the same, sorry the text is small.....but the pattern is a square 4.593" or 116.6mm and 1.81" or 46mm from mounting surface to wheel mount.
"Being a man take years of fightin, screwin, drinkin, and whorin. Then more drinkin and then more whorin...if there's time" -Trippin the Rift
CartsXJ is offline   Reply With Quote Quick reply to this message
Old 11-13-2019, 12:04 PM   #4153 (permalink)
Member # 103621
Perfect. Thank you so much.
Old 11-14-2019, 06:47 PM   #4154 (permalink)
Member # 153241
tia
I just measured an 06 F250 spindle, unit bearing is 4 on 6.5"(center to center diameter), bolt hole size is .595", and the bore size is 5.525".
Greg S is offline   Reply With Quote Quick reply to this message
Old 11-15-2019, 10:39 AM   #4155 (permalink)
Gozuki's Avatar
Member # 3088
Originally Posted by FORDTECHGURU View Post
Well, if a guy wanted to run vacuum hub locks just go snag the dual vacuum solenoid out of a f250. Run source vacuum to it and plumb the other side to the hubs. There is a three wire connector on it, one ground and the other pins are unlock and lock. A simple push button or on off on momentary rocker switch will do the trick. The factory module holds the solenoid on for around 8 seconds and then releases it. So, hold the button or rocker switch down for 8 seconds and your set..
Btw, our 05-up hi steer kits are the only kit in the indusrtry built to allow the vacuum hub locks to be retained if wanted, we machine an oring groove in the arm that seals to the knuckle port, drill and tap a hole and hook your vacuum hose back up and party on..
Does all this apply to the 05+ too? And are the vacuum hubs worth a crap? Be an easy selectable with a front spool.
Sometimes a two foot level is not handy, but usually there's some ground around.
Gozuki is offline   Reply With Quote Quick reply to this message
Old 11-17-2019, 07:32 PM   #4156 (permalink)
hi-steer ninja
FORDTECHGURU's Avatar
Member # 104639
Yes, works the same. The factory lockouts seem to hold up fairly well for trail rigs.
FORDTECHGURU is offline   Reply With Quote Quick reply to this message
Old 12-10-2019, 05:35 AM   #4157 (permalink)
jemarshall's Avatar
Member # 50690
Send a message via MSN to jemarshall
Is there a difference in unit bearings where there is a difference in the back side?
The axles I got seat into the back of the UB, but the KPI is not through the middle of the ujoint. Its pushing the axle into the inside wall of the tube when turning. I am wondering if there is one that would give more room to center up the ujoint.
Has anyone ever added a spacer between the UB and knuckle? Would it be advisable?
It is not letting me attach photos, I keep getting the stupid security token error.
What ever you do, please do not suck start a shot gun.
Stick it up your ass...that way you're likely to hit something vital.
jemarshall is offline   Reply With Quote Quick reply to this message
Old 12-10-2019, 08:00 AM   #4158 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
Text me the photos and I can post them up.
Old 12-10-2019, 08:26 AM   #4159 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
Hereís jemarshallís pictures.
Old 12-10-2019, 08:32 AM   #4160 (permalink)
Member # 603609
I had some laser cut out of 16 ga SS for the 99-04 unit bearing. I have yet to actually use them though. The only issue I see it causing is the relationship between the caliper and rotor, but I have the currie 5 lug brake kit which utilizes spacers and all I have to do to maintain that relationship is space the caliper out the same distance as you shim between the unit bearing and knuckle
Sent from my SM-G950U using Tapatalk
RWassink is offline   Reply With Quote Quick reply to this message
Old 12-10-2019, 08:59 AM   #4161 (permalink)
Jeffh555's Avatar
Member # 3775
What axles do you have? Have you asked the axle manufacturer?
I wheeled twice this year, that might be a personal record.
Jeffh555 is offline   Reply With Quote Quick reply to this message
Old 12-10-2019, 09:48 AM   #4162 (permalink)
Member # 8553
The Super 60 stub shaft is longer than the normal 05+. The unit bearing geometry is the same on both though, the difference is in the knuckle.
05+ standard 60 stubs should be 7" long from center line of joint to end of shaft.
Looks like you have some expensive paperweights...
Ummmm Beer
Satan's_Minion is offline   Reply With Quote Quick reply to this message
Old 12-10-2019, 09:49 AM   #4163 (permalink)
Member # 95025
Impressive.
ΜΟΛΩΝ ΛΑΒΕ
President Trump on building the wall:
"THIS IS WHERE WE HOLD THEM!!! THIS IS WHERE WE FIGHT!!! THIS IS WHERE THEY'RE DEPORTED!!!"
V.P.Pence:
BUILD THIS WALL, BOYS!!!
Fearless Indians:
Awe-Ooo!!!
CDA 455 is offline   Reply With Quote Quick reply to this message
Old 12-10-2019, 02:42 PM   #4164 (permalink)
jemarshall's Avatar
Member # 50690
I built my own caliper mounts. I've already looked into rebuilding them to keep them lined up on the rotor
CTM, I haven't been able to get him on the phone yet
Thanks for the measurement. Not your normal stub shaft since it splines directly into the unit bearing. And they will not be my paperweights....
Originally Posted by CDA 455 View Post
Impressive.
Than you
Old 12-10-2019, 02:44 PM   #4165 (permalink)
jemarshall's Avatar
Member # 50690
Will the super 60 knuckle mount to the normal 05+ C?
Old 12-10-2019, 03:26 PM   #4166 (permalink)
Member # 53528
are the 450/550 1550 stub shafts the same length as the 250/350 stub shafts?
Old 12-10-2019, 06:02 PM   #4167 (permalink)
Member # 267321
No, the balljoint spread is wider and the ball joints are also bigger.
wellstig1 is offline   Reply With Quote Quick reply to this message
Old 12-10-2019, 06:45 PM   #4168 (permalink)
Member # 8553
No.
The splined section into the bearing journal is the same because of the unit bearing, but they are longer from the bearing journal to the joint.
If you have a normal axle you need the 15+ 250/350 1550 shafts part numbers that are all over this thread.
Ummmm Beer
Old 12-10-2019, 06:54 PM   #4169 (permalink)
jemarshall's Avatar
Member # 50690
No.
How much longer are they?
Old 12-10-2019, 07:02 PM   #4170 (permalink)
jemarshall's Avatar
Member # 50690
It would need every bit of a .25 spacer.
Still won't let me upload pics. I'll try hosting instead.
Old 12-10-2019, 08:19 PM   #4171 (permalink)
Member # 53528
No.
so maybe jermashals stub shaft doesnt fit because CTM made it for a f450/550 knuckle/UB?
Old 12-10-2019, 08:45 PM   #4172 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
@jemarshall hereís the pics.
Old 12-10-2019, 08:46 PM   #4173 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
Moar
Old 12-10-2019, 08:49 PM   #4174 (permalink)
jemarshall's Avatar
Member # 50690
Thank you @RANGERROD
First ones are the shims I got in it to get it to be able to rotate the shaft by hand at full crank. It still just barely touches.
And the others are the measurements of the outer stub. Definitely longer than 7", anyone know where there is info that backs that up? Wanting some proof for the upcoming convention.
Old 12-10-2019, 09:59 PM   #4175 (permalink)
Member # 95025
Serious axle pron!
Thanks for sharing.
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
