info on Ford Super Duty Dana 60 axle - Page 172 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-20-2020, 07:44 AM   #4276 (permalink)
TrailTamer XJ's Avatar
Member # 140878
Originally Posted by Baron85 View Post
https://www.pirate4x4.com/forum/axle...r-knuckle.html
I found this thread from Reid saying they have these bolts to allow the tierod to be flipped on top but I don't know how that would work. I assume you would have to ream the drivers side knuckle to fit the taper of the passenger side tierod end and use that bolt with the taper coming from the bottom. On the passenger side maybe the drivers side tierod end has the same taper and just drops in??? I'm going to try and pull it apart this weekend and see what it looks like. Anyone know what taper reamer I would need to fit the passenger side bolt through tierod end?
I would like to use the factory super duty parts since they are so beefy and easy to find.
have anyone ever figured out what taper 2005+ D60's tie rod ends use??? I will like to use their steering linkages into different applications as they're really beefy and a true cross-over
TrailTamer XJ is offline   Reply With Quote Quick reply to this message
Old 02-20-2020, 11:20 AM   #4277 (permalink)
Member # 267321
I'm not sure if any of you guys noticed, but ecgs is now selling 05+ 1550 stub shafts in 35 and 40 spline and inners in whatever length you want.
wellstig1 is offline   Reply With Quote Quick reply to this message
Old 02-20-2020, 01:06 PM   #4278 (permalink)
Member # 4243
I want to say this has been stumbled on a few times... but maybe not in this thread yet.
I ran major/minor diameters into this calculator some time ago.
Taper and angle calculation
Got similar to what this guy is saying:
Originally Posted by t120r View Post
The 2005+ Superduty is NOT the same as the 1-1/2" "1-ton" taper out there. It's a 1.8045 taper. I believe that is 8 degrees roughly.
https://www.pirate4x4.com/forum/ford...l#post41441057
Dodge cobbler... (1stgen cummins theme)
u2slow is offline   Reply With Quote Quick reply to this message
Old 02-22-2020, 04:55 AM   #4279 (permalink)
UPNO4's Avatar
Member # 111323
OK so this is a super long busy thread and this could have been answered but has anyone had the Lower Ball Joint Taper get to big? In other words for clarity I can not get the lower to actually tighten up.
UPNO4 is offline   Reply With Quote Quick reply to this message
Old 02-22-2020, 05:40 AM   #4280 (permalink)
Member # 119773
Its probably in this thread...but I can't seem to find it. How many degrees does the 05 and up steer in stock setup? What is the max angle when the stock steering stops hit the C's? I just finished up a rear steer axle using 05 and up outers with a 14B center and RCV big bells, I can't post up pics but if any one is willing id be happy to email them to someone so they can post.
Thanks
rockdigging601 is offline   Reply With Quote Quick reply to this message
Old 02-22-2020, 08:43 AM   #4281 (permalink)
Member # 181868
Thanks
Someone will probably correct me, but Im pretty sure it's 45*.
Project : Amphibious HEMTT
Old 02-22-2020, 09:29 AM   #4282 (permalink)
Member # 1056
I am looking at narrowing my front SD60 to the same width as a C and C 14 bolt, 63" WMS to WMS. I want to keep the drivers side stock as there is little room there right now.
Is there a chart of axles that fit the inner length on this axle? I have seen it for older axles. I am just wondering if there is an OEM axle that would interchange.
Maybe I just need to buy new which is fine, or get one shortened.
ToyotaJeep is offline   Reply With Quote Quick reply to this message
Old 02-26-2020, 08:56 PM   #4283 (permalink)
D60
Member # 6398
Originally Posted by [486] View Post
rattle it tight enough to get good bearing preload, then stake the nut
standard procedure for doing a pinion seal is to reuse the same crush sleeve
Thanks. Got it done, got what I thought was about 15 in lbs bearing preload (apparently used bearings should be less than new of 20-25 anyway)... but on a whim after my first drive I felt the pinion snout and it was warmer than I'd expect. I was in 2wd but hubs locked.
Anyway I'm gonna just barely back off the (new) nut and see if it runs cooler.
Originally Posted by D60 View Post
This got me thinking I should replace the pinion seal on my '11.
Parts listings suggest the old school 60 seal of 42449 fits but the latest seal appears to be a 2009802.
I already have a 42449 sitting here from an old 60 install kit . Is there a compelling reason to order a 2009802?
Quoting myself....the 42449 fits fine. It's a bit harder to drive in than the flat-faced 2009802, but a block of wood worked for me.
I will say, the 2009802 has an internal cavity behind that pretty flat face, and mine was full of rusty crap. If you swamp your rig much I'd almost argue the older 42449 is a better choice.
I'd post a pic but I tired of being forced into a PP automatic payment (and then digging thru my PP acc to figure out how to turn it off) every year so I can't upload attachments anymore (which is fine)
You know it gets better, so of course it gets worse.
D60 is offline   Reply With Quote Quick reply to this message
Old 02-26-2020, 09:40 PM   #4284 (permalink)
Member # 53528
https://postimages.org/
free no signup needed
Old 02-27-2020, 07:25 AM   #4285 (permalink)
UPNO4's Avatar
Member # 111323
I would never back off a Pinion nut especially with a crush sleeve. Taking a big risk there. 10-15 is good for used bearings and they do run warmer than expected. just my opinion.
Old 02-27-2020, 09:26 AM   #4286 (permalink)
rapier46's Avatar
Member # 165420
Anyone running a stock sd60 with sticky 42s? What’s gonna break haha. Aside from my tcase probably giving up the ghost first, I’m thinking probably shafts before the diff or balljoints let go. Low power, gentle driver.
Get some
rapier46 is offline   Reply With Quote Quick reply to this message
Old 02-27-2020, 10:15 AM   #4287 (permalink)
Unklhuck's Avatar
Member # 70595
Originally Posted by rapier46 View Post
Anyone running a stock sd60 with sticky 42s? Whatís gonna break haha. Aside from my tcase probably giving up the ghost first, Iím thinking probably shafts before the diff or balljoints let go. Low power, gentle driver.
Water usage & Brand of 42ís will play into the fusible link equation, quite a bit.
Just another Phoenix redneck....
Unklhuck is offline   Reply With Quote Quick reply to this message
Old 02-27-2020, 12:05 PM   #4288 (permalink)
rapier46's Avatar
Member # 165420
No water, 5400lb Tacoma. Trepadors
I have the 1480 shafts. And a spare complete left and right shaft as well as an extra 1480 ujoint just in case
Get some
Old 02-27-2020, 05:08 PM   #4289 (permalink)
Member # 192237
this
if you don't burn yourself, it's cool enough
run synth 75w90, thicker oils run hotter
Old 02-27-2020, 08:01 PM   #4290 (permalink)
Unklhuck's Avatar
Member # 70595
My prediction, with that combo and your mention of being mellow with the pedal, is that they will last longer than you think.
Old 02-28-2020, 06:46 AM   #4291 (permalink)
paradisePWoffrd's Avatar
Member # 56831
Send a message via AIM to paradisePWoffrd
If my searching is correct; the 05+ long side is 41 3/8" and WMS is ~72". To get to 63, you would want a ~32 3/8" inner.
The closest factory 35 spline inner would likely be 78-79 Ford at 34.5". That would give you ~65" wms.
The earlier fords had shorter long side, but aftermarket shafts seem to be non existent.
Ben
Big Dixie Boggers________________MudProMetalworks.com
paradisePWoffrd is offline   Reply With Quote Quick reply to this message
Old 02-28-2020, 11:23 AM   #4292 (permalink)
Member # 53528
fwiw youre gonna regret making that d60 63" wide if you ever go bigger tires, i made my 14b front 63" and when i went to 43" stickies it was too narrow, wish i had made it 67"
Old 02-28-2020, 12:24 PM   #4293 (permalink)
Member # 7903
I run a 34.55" 78/79 F250 shaft and my front axle is 67.625" with no trimming to driver's side.
JohnnyJ is offline   Reply With Quote Quick reply to this message
Old 03-01-2020, 09:20 AM   #4294 (permalink)
Member # 1056
I thank you all for your help. I hear you on the width thing. I just would like to keep it "sorta" street legal as far as width goes. I do like the idea of just getting a spare set of axles and not having custom stuff. It is for a build down the road so no hurry at this point.
Old 03-03-2020, 10:40 PM   #4295 (permalink)
Member # 22267
Send a message via AIM to HEEPJEEP
UD60 shafts are the same length as the 78-79 Ford, dirt cheap chromo 1550, and "people" keep them in stock. The new 1550 chromos in whatever custom length you want these same "people" have in stock for 05+ and can get in about 2 week lead time for custom.
YJ and Corey-So buy some then. I've always wanted a pony. Ponies are badass. Do I have a pony? No.
HEEPJEEP is offline   Reply With Quote Quick reply to this message
Old 03-04-2020, 05:44 AM   #4296 (permalink)
Member # 1056
Just to clarify, as I am new to this model of axle:
1. What is a UD60? What application?
If I could buy new assembled shafts that were 1550 sized and a little shorter on the long side that would be sweet. I'd buy some spares and not worry about it.
Thank you for your input. That helps.
Old 03-04-2020, 05:48 AM   #4297 (permalink)
E-Locker or Bust!
DMANbluesfreak's Avatar
Member # 163019
Ultimate Dana 60.
https://spicerparts.com/en-emear/par...-60-front-axle
2001 Z71 Silverado, Ext. Cab, 5.3L V8 -
Shortened 17" w/Bed, AAM 14B FF / Grizzly, Dana 60 HP / Chromos, Anti-Wrap Bar
4L80e, EcoBox/205 Doubler, 40" Mickey's, Rock Sliders, Hidden Winch, Hydro Assist
DMANbluesfreak is online now   Reply With Quote Quick reply to this message
Old 03-04-2020, 06:10 AM   #4298 (permalink)
Member # 1056
Ok. I need to get to work but a quick search shows an assembled UD60 inner with 1550 joints etc. is $180 and 33.75.
That is probably as close as I am going to get, and it should get me down to 66" wide plus or minus.
Thank you so much. Now time for more research.
Old 03-04-2020, 12:00 PM   #4299 (permalink)
Blase's Avatar
Member # 63692
Lots of pages of great information here!! I searched and could not find the answer i'm looking for.
My question: What is the weight difference between 99-04 and 05+?
Specifically if I build a 9" using only the inner knuckles out which would weigh more assuming everything inside the knuckles is exactly the same.
[QUOTE=JR;13666387]:laughing: You know, Ifs is kinda like a vagine. It's soft,sexy and expensive.[/QUOTE]
Blase is offline   Reply With Quote Quick reply to this message
Old 03-04-2020, 12:09 PM   #4300 (permalink)
Gozuki's Avatar
Member # 3088
Everything is bigger on the 05+, so it's going to weigh more.
Sometimes a two foot level is not handy, but usually there's some ground around.
Things are moving to fast for waterhorse.
Gozuki is offline   Reply With Quote Quick reply to this message
