info on Ford Super Duty Dana 60 axle - Page 87 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-14-2016, 09:47 AM   #2151 (permalink)
Member # 127171
Originally Posted by patooyee View Post
Trail Gear Housings. The stock tube is too large ID to bore for a 3" OD tube. It would work with a 3.5" tube though. Front axle uses a Detroit and stock 2006 F-350 shafts, is a hair under 70" WMS. Rear uses 2006 F-350 stubs with standard Chevy 60 inners, ARB, is 68" WMS. I've got some dimensional drawings I can post later if you are interested.
Picking up some 3" housings and was wondering if you could share how you came up with the cut for Chevy inners? Planning to weld on some Cs and swap out my Chevy 60 front. It would be nice to just buy a 3rd and swap everything over that I already.
sleepsontoilet is offline   Reply With Quote Quick reply to this message
Old 05-14-2016, 09:52 AM   #2152 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
I modeled everything up in Solidworks to get my cut lengths. Other people do it other ways. Is that what you are asking?
Old 05-14-2016, 09:59 AM   #2153 (permalink)
Member # 127171
I don't have solidworks. I was just curious it there was a simple way of knowing exactly where to cut the tubes for the correct lengths. When I built my semifloat rear I just used the shaft measurement plate ruffstuff sells, guessed with my bearing cups and the Currie outer drawing they sent me to measure for shafts. If there's way more to it, I'll just drop the Cs and housings off at a shop.
Old 05-14-2016, 10:11 AM   #2154 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
I don't think there's an "easy" way. I just measured like 80 times, had a buddy come over and throw a fresh set of eyes on it to redo all my measurements. It was stressful.
I started a thread looking for a calculator of some sort:
https://www.pirate4x4.com/forum/gener...lculation.html
Basically I think there are so many possible combinations with a Ford 9" that it would make the task of designing a calculator immeasurably complex.
Old 05-14-2016, 07:38 PM   #2155 (permalink)
Member # 175478
noob question. I searched but didnt find. On heim steering I am using weaver fab's adapter bushing for the pass side for 3/4in bolt. for the driver side do u guys just drill it out? It looks like the bottom taper is larger then 3/4in though.
06 Hummer H3- 5.3/4l60e/factory H3 4:1. 3 link front, spring over rear. custom D70 front/Eaton HO72 40in STT pros
2017 invited reader Ultimate Adventure
06 H3 is offline   Reply With Quote Quick reply to this message
Old 05-15-2016, 08:01 AM   #2156 (permalink)
Member # 206522
those gnarlu ub cups look overkill. more info please
urmaster85 is online now   Reply With Quote Quick reply to this message
Old 05-16-2016, 10:27 PM   #2157 (permalink)
Member # 38880
Just picked up a 60 from a 2007 F350. Im going to use Artec truss and run 4 link any real reason not to build a bracket for the coil over to mount to the top of the inner c where the coil spring was mounted, other then moving the shock up. Thanks
3/4ton62gmc is offline   Reply With Quote Quick reply to this message
Old 05-17-2016, 06:22 PM   #2158 (permalink)
pcoplin's Avatar
Member # 17986
A friend has a 2005+ front axle, and this weekend broke an outer, and spit a clip on the other side.
Anyone planning on making chromoly shafts for these soon?
98 TJ LQ4/TH400
FullStack MotorSports
pcoplin is offline   Reply With Quote Quick reply to this message
Old 05-17-2016, 09:56 PM   #2159 (permalink)
Member # 5632
Beat me to it dude.
John
Off Track Motorsports #4580. KOH EMC 2017 Top 10 Finisher.
Avanteone is offline   Reply With Quote Quick reply to this message
Old 05-17-2016, 10:19 PM   #2160 (permalink)
Member # 197428
Originally Posted by Avanteone View Post
Beat me to it dude.
John
Rcv not count?
Go Dawgs
Mortalis5509 is offline   Reply With Quote Quick reply to this message
Old 05-18-2016, 04:45 AM   #2161 (permalink)
Member # 206522
did he break a 1480 or 1550 ujoint outer?
Old 05-18-2016, 07:58 AM   #2162 (permalink)
Member # 5632
Originally Posted by Mortalis5509 View Post
Rcv not count?
Not a real RCV fan.
Old 05-18-2016, 08:02 PM   #2163 (permalink)
pcoplin's Avatar
Member # 17986
Beat me to it dude.
John
Just doing what I can! Hope there's an answer soon. Or else I'd ditch the whole thing for your other axle.
98 TJ LQ4/TH400
Old 05-19-2016, 07:11 AM   #2164 (permalink)
Member # 21282
call Branik
Recommended Stuff:
91blaze is offline   Reply With Quote Quick reply to this message
Old 05-19-2016, 07:37 AM   #2165 (permalink)
Newbie
Bugs713's Avatar
Member # 400697
I heard from Artec that they have an SD 60 truss/bracket kit coming out for the TJ by the end of June? This will make my build of these axles much easier!
Bugs713 is offline   Reply With Quote Quick reply to this message
Old 05-19-2016, 08:02 AM   #2166 (permalink)
Member # 385330
Best news I've heard all week!
Sent from my SM-N900W8 using Tapatalk
Broke Back Pocket is offline   Reply With Quote Quick reply to this message
Old 05-20-2016, 10:02 AM   #2167 (permalink)
Member # 7624
Send a message via AIM to offroadman83
So been looking forward to this.................of course I have been giving them hell to get it out already. They keep focusing too much on JK junk.
2000 tj with stuff
offroadman83 is offline   Reply With Quote Quick reply to this message
Old 05-20-2016, 10:14 AM   #2168 (permalink)
huntingman2706217's Avatar
Member # 133776
I use shock conversion brackets (for like a XJ or TJ) and have built 3 this way with no issues... i forget what brand i used though... TMR maybe??? they are much thicker so plenty strong.
90 MJ Truggy on 06 SD axles, 5.38's, H1's and 4D's
huntingman2706217 is offline   Reply With Quote Quick reply to this message
Old 05-20-2016, 10:19 AM   #2169 (permalink)
Member # 133776
I have been following this thread for awhile and see tons on the 60 front... i am curious about the sterling though... ive looked all over and found one guy that mentioned it but never found out if he succeeded... Is it possible to use the front 60's inners on the sterling and build a rear steer setup on the sterling? same bolt pattern... same splines... same axle tube size... only difficult part is machining the sterling for the SD axle seals... shafts i would probably go custom or use two long side 60 shafts and cut them down and resplining... what am i missing to have not seen it done already?
Old 05-20-2016, 10:27 AM   #2170 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
I wouldn't machine for seals. I would just use aftermarket tube seals. The outer seals would go in the inner C's just like stock.
Sent from my XT1585 using Tapatalk
Old 05-20-2016, 10:33 AM   #2171 (permalink)
Member # 133776
This is how i have been doing my steering the last two axles... honestly havent researched if anyones came up with anything yet to make it easier... but works well and cheap... long as you know how to weld to cast...
I drill the drivers side to 3/4in... the pass side i drill to 1in and have some 3/4ID 1inOD DOM i got off ebay and just use a safety washer on the heim from ruffstuff which is wider than 1in... washer on the bottom... plenty strong with zero issues so far...
Old 05-20-2016, 10:35 AM   #2172 (permalink)
Member # 133776
the shaft would have to be cleaned up well then in that location... would help with keeping mud out though...
Old 05-20-2016, 10:36 AM   #2173 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
Not really. Look for the dana 60 seal thread describing the seals. This is all discussed there. I'll try to find it but I'm on my phone ...
Old 05-20-2016, 10:38 AM   #2174 (permalink)
Member # 133776
search never works right on my phone... will while im at work right now though... havent seen that thread...
Old 05-20-2016, 10:40 AM   #2175 (permalink)
Member # 133776
have you got anything more for me to search off of?? 60 seal bring up like 5 million threads lol... was it for the SD axle or 60s in general or?
