Air bumps. Inboard or Outboard - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-11-2010, 02:47 PM   #1 (permalink)
Member # 55444
I see a ton of builds with the bumps mounted less than 12" apart, and the more I think about it, as I'm setting up the plans for mine, I'd think they would be better off farther outboard than the coilovers. I realize at slow speeds, that it shouldn't be an issue, but hitting something at a decent speed twisted up, or with a heavy rig flexing against the coilovers bottoming out, most of these rigs aren't touching the airbumps unless it is a straight jump.
With a heavy rig, and a heavier foot, would I not be better off figuring out how to mount my airbumps virtually against the knuckle?
[CENTER]I have Dumb Ideas[/CENTER]
spidr is offline   Reply With Quote Quick reply to this message
Old 02-11-2010, 02:53 PM   #2 (permalink)
Member # 29097
I have wondered about this as well. I see some rigs that when fully articulated the CO will bottom out long before the bump even gets touched. If you bottom out the CO from a jump and land fully articulated the bump will probably be the last thing on your mind at that point.
subscribed
"Those who make peaceful revolution impossible will make violent revolution inevitable."
SoundManCO is offline   Reply With Quote Quick reply to this message
Old 02-11-2010, 05:16 PM   #3 (permalink)
Brink_'s Avatar
Member # 63901
I think it's done because often there are more limits to uptravel in the center. With more room for the tire to go up on each side during single wheel "flex" than just full on whole axle bump. Keeping them in alows the axle to articulate farther than the bumpstop would limit the travel to....this does require it to be setup with some shock still available when you are sitting on the air bumps though. A little scary in that a hard enough landing on just 1 tire might miss the bumps altogether and transfer the force only into the shock as it bottoms out. That's why I didn't go too far in with my bumps.
I've wondered it also though. Be interesting to see others takes and reasoning. I set mine up like stated above. Sitting on the airbumps there's still an 1 1/2" or so of shaft showing. But I use all the shock uptravel on articulation. Don't know how it works yet though....stupid $%#$%%$$#^$^ rig
Brink_ is offline   Reply With Quote Quick reply to this message
Old 02-11-2010, 05:24 PM   #4 (permalink)
Member # 55444
So what about using one in the middle, dead center, and 2 outboarded?
Old 02-11-2010, 05:30 PM   #5 (permalink)
Brink_'s Avatar
Member # 63901
That's kinda neat. 1 center then 2 outboard at a different a height to allow the uptravel on articulation? hmmmmm.....only thing is body roll when coming down anything less than perfectly straight on the single center (it might pich you over to the side you are already leaning towards) plus the added costs...top of my head thoughts anyway.
Old 02-11-2010, 05:59 PM   #6 (permalink)
Member # 15461
You guys are way over thinking it.
What do you want the bump stop to do? For crawling I'd put them inboard of the lower shock mounts so they dont come into play much while crawling but when the axle is moving up and down while going fast they will control it as needed. Put them too far in and you lose effectiveness if the axle isnt perfectly square going up and down.Put them as far apart as you can realistically get them without limiting your low speed suspension travel too much.
$0.02
95geo is offline   Reply With Quote Quick reply to this message
Old 02-11-2010, 06:12 PM   #7 (permalink)
Brink_'s Avatar
Member # 63901
QUOTE=95geo;11014791]You guys are way over thinking it.
$0.02[/QUOTE]
Thought that's what I said in my first pos, maybe not in the exact same way I guess. But it's what I was getting at [
Old 02-18-2010, 03:50 PM   #8 (permalink)
Member # 55444
Any input from the guys that where KOH?
Old 02-18-2010, 04:01 PM   #9 (permalink)
Paying for others
jeepcrazie's Avatar
Member # 38032
You want them as far out as you can get them but not outside the coilovers.
Shady Lady VIP #13
jeepcrazie is offline   Reply With Quote Quick reply to this message
Old 02-18-2010, 05:51 PM   #10 (permalink)
Member # 5110
Right on the outside of the "frame" is a good spot. You don't want them hanging too far off because of how much load goes through them. Be sure you still have some bump travel left in the shocks once the air-bumps are bottomed.
Link to thread on my calculator https://www.pirate4x4.com/forum/showthread.php?t=204893
Triaged is offline   Reply With Quote Quick reply to this message
Old 02-18-2010, 06:32 PM   #11 (permalink)
Member # 50177
I mounted mine outboard of my coilovers. My uptravel is limited by my tire to tube clearance and I wanted to do everything I could to protect my little Toyota axles from bending. For my clearance issues (tire to chassis not axle to frame) mounting the bumps outboard/even with the coilovers actually maximized my up uptravel and articulation travel. On a rig that the up travel is limited by clearance issues at/between the frame you would be better off mouting the bumps further inboard
Toyota Link Suspension Systems, Weld On Beadlocks, Custom Fabrication, and More
________________________________________________
05 GMC 2500HD d-max, 87 4runner, X chassis rock buggy
my buggy build
am4x4 is offline   Reply With Quote Quick reply to this message
Old 02-18-2010, 06:35 PM   #12 (permalink)
MNorby's Avatar
Member # 11448
Send a message via Yahoo to MNorby
here is my setup. criteque if you have ideas.
MNorby is offline   Reply With Quote Quick reply to this message
Old 11-27-2012, 10:36 AM   #13 (permalink)
Member # 36955
A rear drive shaft would be a starting point.
On a side note. Mine (just got some ordered from profender) are going in the rear.
My rear suspension articulates way before my front, but the rates are just about right so I am outboarding them.
If I outboard them then the rear suspension will have to deal with them when it articulates and the front will start to move more and balance the whole thing out.
enigma2y0u is offline   Reply With Quote Quick reply to this message
Old 11-27-2012, 10:44 AM   #14 (permalink)
perfection in plasma
carslut's Avatar
Member # 25823
Send a message via ICQ to carslut
def going to see what everyone is doing with these as i need to makeup my mind where they are going on my truck.
carslut is offline   Reply With Quote Quick reply to this message
Old 11-27-2012, 11:01 AM   #15 (permalink)
MNorby's Avatar
Member # 11448
I would do outboard or even with shocks so they hit at same time in vertical travel or flex travel.
Old 11-27-2012, 11:36 AM   #16 (permalink)
Fl-Krawler's Avatar
Member # 47337
Mine are chassis width, to control bottoming when hitting jumps etc, and they are set up to bottom out with the shock showing 3" of shaft at full compression (18" coilover). I am then running a 3" TJ bumpstop on the shock shaft itself. This way I get bottoming protection for jumping, as well as slow crawling.
Fl-Krawler is offline   Reply With Quote Quick reply to this message
Old 11-27-2012, 11:45 AM   #17 (permalink)
Member # 3007
Responding to a nearly 3 year old thread is almost as retarded as your comment
Bones is offline   Reply With Quote Quick reply to this message
Old 11-27-2012, 11:47 AM   #18 (permalink)
Member # 100827
Send a message via AIM to smewhtguy
Mine are set even with the shocks and hit the links, they make contact during straight uptravel and slight articulation but clear and don't hit at all during extreme flex. This works great to soften the hits during go fast and not limit flex while crawling.
I do math and stuff, on a professional level.
smewhtguy is offline   Reply With Quote Quick reply to this message
Old 11-27-2012, 11:50 AM   #19 (permalink)
Buckon37s's Avatar
Member # 20394
On pure articulation, why would you want the air bump to hit at all?
[I]BUCK[/I] Wild Racing
Team 911
Thank you all for your support
Widia Cutting Tools
Sterling Autosport
PSC
Ruffstuff
Tom Woods Drive Shafts
Buckon37s is offline   Reply With Quote Quick reply to this message
Old 11-27-2012, 12:23 PM   #20 (permalink)
vetteboy79's Avatar
Member # 31621
Send a message via AIM to vetteboy79
I had mine slightly inboard...set it up so everything would just about max out at the same time when articulated, and leave about 1" showing on the shock shaft at full bump.
The Alternative Rocker - Taurus SHO V6-powered, Explorer-framed, TTB-front, RCV'd, YJ-bodied east coast racer
Flying Pig Racing #512
vetteboy79 is offline   Reply With Quote Quick reply to this message
Old 11-27-2012, 12:59 PM   #21 (permalink)
Member # 136758
an ideal setup is mounting them just far enough from center of the axle to where they are just about to touch the bump pad at full articulation. unless you have no choice due to space or setup, its not ideal to be working your bumps from articulation, it momentarily interferes with the design/tuning/spring rate of the coilover.
they are their for hard uptravel hits.
even a non high end coilover is designed to support a rigs weight from articulation. and i would think its almost impossible to get a hard enough hit to where it articulates your axle so much to where it rips your shock off.
heres an example of my rear being setup how i described. this is almost full articulation. 3" bumps. and not that you can see it in the pic but if i were to be at full bump i would still have just slightly over an inch of shock shaft showing.
edit just realized this thread is 3 years old . FML
-Matt- is offline   Reply With Quote Quick reply to this message
Old 11-27-2012, 11:12 PM   #22 (permalink)
Member # 36955
You're right, we should start new threads anytime we someone wants to discuss the same shit over again.
I didn't read the date cause I used the search function and found what I wanted so go fuck yourself.
My bad on making a joke to a three year old post; I will still sleep fine tonight.
