5.7 Vortec Idle Issues - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-20-2010, 03:07 PM   #1 (permalink)
Moderator
RustyNailJustin's Avatar
Member # 8568
This thing had performed flawless for the last 5 years. Early 1999 5.7 in my Cruiser Buggy. Starts quick and easy runs great. The issue is when the motor reaches operating temp and is shut off then restarted while it is still hot. It starts fine but has a very low idle and dies sometimes. Once it runs for about 1 min it's right back to normal and running perfect. My first guess is IAC but I don't want to go guess changing everything. There are no codes stored in the computer. Any thoughts on what may be causing this?
KOH 2009 Team 435
KOH 2010, 2011,2012,2013,2014, 2015 Team 4431
EMC 4619 2014,2015,2016
TLCA# 5305
RustyNailJustin is offline   Reply With Quote Quick reply to this message
Old 02-20-2010, 10:52 PM   #2 (permalink)
Moderator
Member # 8568
Maybe I should have named this "KOH Vortec". 28 views in 7 hours... Marketing was never my thing
KOH 2009 Team 435
TLCA# 5305
Old 02-20-2010, 11:00 PM   #3 (permalink)
4xflyin's Avatar
Member # 48209
Does it have a catylitic converter? If so maybe clogged. Or clogged fuel filter. Had both happen to me.
4xflyin is offline   Reply With Quote Quick reply to this message
Old 02-20-2010, 11:02 PM   #4 (permalink)
Moderator
Member # 8568
No cat and I just changed the fuel filters. The filters were my first guess too
KOH 2009 Team 435
TLCA# 5305
Old 02-21-2010, 05:14 AM   #5 (permalink)
Member # 43040
Try removing and cleaning the IAC. I had the same problem in my car and was like you not wanting to just change parts. I pulled it, cleaned it and the throttle body and its been running fine since.
95 S-10, one tons, 44's, 7lb pulley
Joshinator is offline   Reply With Quote Quick reply to this message
Old 02-21-2010, 08:39 AM   #6 (permalink)
87yjtoy's Avatar
Member # 25994
I know you will get all the "this is what fixed mine" replies. So here is another one. Vacumn leak. very small but still will cause the symptoms you describe. Good luck chasing gemlins.
87yjtoy is offline   Reply With Quote Quick reply to this message
