Spicer Dana 44 ball joints - Page 4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-12-2018, 09:39 AM   #76 (permalink)
PIG
2indapink&1indastink
PIG's Avatar
Member # 4502
Originally Posted by 06silverback View Post
Iím in the process of developing an upper balljoint delete kit for the D44ís due to requests. Iíve got a 99-04 and 05+ D60 kit for the Sper Duty Fords and this is next on the list.
Upper BJ "DELETE"....? Got pics of what you are doing?
USE CODE: PIRATE10 FOR 10% SAVINGS ON YOUR NEXT ORDER!!!
COOL STUFF FOR YOUR BUGGY, JEEP, DODOGE 2500/3500
PIG is offline   Reply With Quote Quick reply to this message
Old 11-12-2018, 10:33 AM   #77 (permalink)
Member # 208352
Yes sir. Take a look here:
https://www.pirate4x4.com/forum/axle...elim-kits.html
06silverback is offline   Reply With Quote Quick reply to this message
Old 11-13-2018, 03:48 AM   #78 (permalink)
SnailMan's Avatar
Member # 79690
I’m in the process of developing an upper balljoint delete kit for the D44’s due to requests. I’ve got a 99-04 and 05+ D60 kit for the Sper Duty Fords and this is next on the list.
That would be Kick-Ass! I'm definitely interested in some info!!
Keep up the fight for this life, we only do it once! Wheel on buddy! - "T"
Rest in Peace Buddy!!
SnailMan is offline   Reply With Quote Quick reply to this message
Old 11-13-2018, 04:02 AM   #79 (permalink)
SnailMan's Avatar
Member # 79690
Originally Posted by RANGERROD View Post
Older 44’s or?
I’m kinda with Bray d. I’ll run mine see what happens. I’m still 10 months out when the truck will be done.
I'm going to start with the JK stuff and the Ford HP44 since those are most popular. I know some use the same ballpoint and will fit more than one application, but starting with those.
I'm fairly certain the Ford HP Dana 44 Ball joints are the same as the GM Dana 44 BJ's so I'm definitely in for info!
Old 11-13-2018, 06:23 AM   #80 (permalink)
Member # 208352
The Super Duty knuckles are machined for the uni ball cup to be welded in, but they are cast steel. The older stuff is mostly cast iron which would require pre/post heat with Ni rod so I'm leery of doing them the exact same way so we'll see what progresses.
Old 11-26-2018, 08:27 AM   #81 (permalink)
Member # 100050
I just wanted to bump this to document that I now have the Spicer joints installed. We'll see how long they last.
I kept my old Moog Problem Solvers as well so I can cut them up for the sake of science.
96 Ranger-2012 4WOR Ultimate Adventure Invited Reader
Bray D is offline   Reply With Quote Quick reply to this message
Old 12-20-2018, 04:16 PM   #82 (permalink)
Member # 10063
I know this Thread is Ancient but i wanted to add that I have found AC-Delco is making the exact same Ball Joints as the Raybestos Blue Boot BJs
ACDelco 45D0070 Professional Front Upper - 30.78 (On Amazon Today - 11/9/2018
ACDelco 45D2156 Professional Front Lower - $20.54 (On Amazon Today - 11/9/2018
They Carry the same Numbers on the bottoms as both the Raybestos and Napa BJs but are sold at significantly lower prices
Hope this helps people as much as it helped me when searching today!!
Also anyone have an update on how the Blue Boot BJs are holding up 5 years later? lol
I've had Spicer Pro-Grade joints on my Ranger's D44 since way back in 2003 (labeled under the "Spicer" name). They just won't die, still no slop whatsoever last I checked about 3K miles ago (I grease them about every 10K).
I put Raybestos Pro-Grade ones on my BII's D35 in 2008 (the ones I pictured earlier in post #8... pic fixed now, I hope). Also still great.
Both have maybe ~60K miles (and of course lots of offroad/crawling, cycling of the steering back & forth).
A couple years ago however Federal Mogul (maker of Moog) bought out Affinia Group (maker of Raybestos), so I can't say whether any blue/gold joints made today are the same quality as ones of 5+ years ago.
I also did have someone recently report to me that they had great luck with Mevotech "TTX" joints after having constant issues with Moog (the TTX line appears to have green boots). No personal experience though.
'90 Bronco II, 2.9L, Dual T-case, 5.13s, 35x12.50s
http://www.supermotors.net/22445
4x4junkie is offline   Reply With Quote Quick reply to this message
Old 02-21-2019, 07:59 PM   #83 (permalink)
SnailMan's Avatar
Member # 79690
So I recently found Ball joints made by ProGrade. They're supposed to be Heavy Duty and according to their website the stud is 4140 Chromoly and the Housing is 1045 (I don't actually know how that compares to other Ball joints lol)
From their website
1,000,000 MILE WARRANTY. You can install our ball joints with confidence knowing that every part we sell is backed by our industry-leading 1,000,000 mile limited warranty. We can offer this because our parts are engineered, tested, re-tested, and subject to strict quality control procedures - our quality is second to none.
CRAZY STRONG BALL JOINTS. Proforged ball joints are built using some of the toughest steel on the planet. Forged SAE4140 chromoly steel studs are enclosed in forged SAE1045 housings, heat treated for strength and durability, and every fit surface is CNC machined for precision fit and finish. Each unit is sealed with specially-designed CR-rubber boots for ultimate durability.
Also their very reasonably priced and available on Amazon
For my Chevy Dana 44
Proforged 101-10149 Greasable Front Upper Ball Joint - $30 https://www.amazon.com/dp/B008VMNLGO..._Oj3BCbDC93REZ
and
Proforged 101-10150 Greasable E-Coated Front Lower Ball Joint - $27 https://www.amazon.com/dp/B008VQLMVG..._sk3BCbKEKNTT9
I'm curious how these would hold up since Raybestos was bought out by Moog.
Sent from my SM-N950U using Tapatalk
Old 05-09-2019, 02:13 PM   #84 (permalink)
SnailMan's Avatar
Member # 79690
Awesome info! I just bought some spicers and they are shit. I havenít ran the rig yet but Iím planning on swapping them pretty quick.
Well I took a chance and bought the Spicer Pro-Grade Balljoints and sure enough all 4 balljoints were loose. Shanks spin freely and could even move the shank in the socket with minimal force. All by hand. So returned and going to order the AC Delco ones. When they arrive ill let you guys know how the quality is. Ordering through Amazon so if they're crap now since Moog bought them I can return them easily. Theres also a guy R&Ding Balljoint Eliminators for our style Dana 44s. Well see what he comes up with.
Old 05-09-2019, 09:20 PM   #85 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
If that doesnít work out. Blue boot Napaís. Premium line.
Old 05-09-2019, 09:32 PM   #86 (permalink)
SnailMan's Avatar
Member # 79690
The AC Delco ones are the same as the Blue Boot Napa's but they're $10 cheaper than the Napa Line.
Old 05-15-2019, 07:33 PM   #87 (permalink)
Member # 40966
Send a message via AIM to EndlessMtnFab Send a message via MSN to EndlessMtnFab Send a message via Yahoo to EndlessMtnFab
The Delco ones are shorter than the original Spicers I pressed out for a customer.
So the clips don't get installed on the lower balljoints. Measured it up too --- so I *know* it wasn't a seating issue.
What the fuck anymore.
EndlessMtnFab is offline   Reply With Quote Quick reply to this message
Old 05-15-2019, 07:42 PM   #88 (permalink)
SnailMan's Avatar
Member # 79690
You must have gotten a bad run I guess.
My Delco Blue Boots are the exact same height as the Spicer ones I took off.
Old 05-15-2019, 08:07 PM   #89 (permalink)
Member # 40966
Ordinarily, I would agree with you.
But just spent a bunch of time searching other forums Ö. it's becoming more common. Consolidate parts & pieces Ö save money Ö. who gives a shit about the customer?
Old 05-15-2019, 08:12 PM   #90 (permalink)
SnailMan's Avatar
Member # 79690
Will maybe I got lucky with mine lol
I can tell you it won't new an issue with just AC Delco Blue Boots though. It will be with them Napa and Raybestos Blue Boots too. They're all made by the same pant.
Old 05-15-2019, 08:20 PM   #91 (permalink)
Member # 40966
Bought 'em about 2 months ago Ö just getting around to installing now.
Old 05-15-2019, 09:40 PM   #92 (permalink)
SnailMan's Avatar
Member # 79690
Yeah just bought mine this week. Really is weird. My buddy is running a set and he hasn't reported any issues. Glad mine are right. Hopefully it's just a bad run and you can. Swap em out for the correct length ones.
