Home made LS1 oil pan - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-12-2010, 06:43 AM   #1 (permalink)
tmaddox4x4's Avatar
Member # 108799
Thinking about cutting down my gen 3 truck oil pan. I got the plasma and welder to do it. Anyone here done that yet? Not trying to be cheap, jut like doing things myself. Plan on cutting with plasma and welding pan with spool gun. Going to tig the pick up. Pros and cons? What would be a good baffle design for off road?
tmaddox4x4 is offline   Reply With Quote Quick reply to this message
Old 03-12-2010, 07:53 AM   #2 (permalink)
whypave's Avatar
Member # 28177
Not to overstate the obvious but you should search.
https://www.pirate4x4.com/forum/showthread.php?t=870000
thread in the last few days about basically this topic with pictures of how people modified pans and how for the most part they still didn't work
whypave is offline   Reply With Quote Quick reply to this message
Old 03-12-2010, 03:09 PM   #3 (permalink)
tmaddox4x4's Avatar
Member # 108799
I did search and found nothing on cutting an old pan down to gain ground clearance. Great info on oil control, just nothing on cutting and welding truck pan.
Old 03-12-2010, 04:26 PM   #4 (permalink)
THE VOICE OF REASON
imagineer's Avatar
Member # 50419
Google
Cutting the truck pan would work fine, but you wont have a ton of oil capacity because the sump is so small .
http://ls1tech.com/forums/conversion...-oil-pans.html
Murphy's Law Motorsports #816
Check us out on
OPTIMA BATTERIES, YUKON GEAR, RACELINE WHEELS, GRIFFIN , FLEXCON, BAJA DESIGNS, FOX RACING SHOX, HOWE PERFORMANCE, B.F. GOODRICH, MITCHELL DIFFERENTIAL, PRP SEATS, FIREBALL HEAT TREATING, JET LUBE, PAC RACING SPRINGS, KESSLER MACHINE.
imagineer is offline   Reply With Quote Quick reply to this message
Old 03-12-2010, 04:48 PM   #5 (permalink)
Member # 84593
This.
If you just chop the pan to make it shorter you lose the capacity. On an LS motor the pan is shorter, but the sump is longer.
HardcorewannabeXJ is offline   Reply With Quote Quick reply to this message
Old 03-27-2010, 10:33 AM   #6 (permalink)
Member # 18540
Send a message via AIM to YJ_OVER_SJ
I went ahead and cut a couple inches off the bottom of a truck pan and flattened it out. dropped capacity from 6.5qts to 5.25qts. I did this rather than a new pan because of the way my exhaust is currently routed under the pan, wouldn't have worked with an aftermarket. and because I'm broke.
I plan on building trap doors and a lip towards the back of the sump(replacing windage tray) to hold more volume during inclines. I'll let you know how it turns out. btw, it was a PITA to weld even though it was cleaned thoroughly right before the TIG job. had to be welded on the inside and outside. guessing the issue was due to the porosity of the metal absorbing oil over time.
If it doesn't work, I'll get a kevko and redo the exhaust.
"OBie"
CalRocs 2010 #5150
YJ_OVER_SJ is offline   Reply With Quote Quick reply to this message
Old 03-27-2010, 11:05 AM   #7 (permalink)
Member # 13012
I cut mine down on my old buggy, its easier to just use a cut off wheel and will produce a better fit when you put the plate on the bottom. I tigged mine so I wanted to make sure there were no gaps. I never had any problems with oiling, but I only had the rig on the trails 5 or 6 times before I sold it. Looking at all the LS oiling threads now I would have just bought an aftermarket pan and an accumlator for piece of mind.
lincontaco is offline   Reply With Quote Quick reply to this message
