GM 12 Bolt Disk Brake conversion - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-29-2010, 08:58 PM   #1 (permalink)
Member # 159321
I am in the process of building my first buggy and running a GM 12 bolt and a Dana 44. I want (and have heard) about using the "cadillac" method of converting from drum to disk. My question is that my axles are the 6 Bolt pattern, and everything i have seen and read about uses the 5 bolt pattern. So i was wondering what brake rotor are yall using on the GM 12 bolt rear end to complete this conversion ????
DieselDoctor4you is offline   Reply With Quote Quick reply to this message
Old 04-29-2010, 09:06 PM   #2 (permalink)
Member # 1792
On my last rig.I used the stock D44 backing plate,rotor,and calipers.
CJJuggy.FI406/465/205/D60/14bolt FF on 39.5 Swampers. Kid's '70 Jeepster D44/14bolt FF.
Cheepin is online now   Reply With Quote Quick reply to this message
Old 04-29-2010, 09:46 PM   #3 (permalink)
Madzooki's Avatar
Member # 13569
Send a message via AIM to Madzooki Send a message via Yahoo to Madzooki
Use the light duty rotor from the front of a 1990 Chevy half ton 4x4. If I remember correctly the part number from carquest is a 5568. But I would double check that. It will be the thinner of the two listings. Then you have to get the inside index opened up to fit over the end of the axleshaft. The part that originally centered up the drum. I used a holesaw to open mine up after I centered it up very carefully on my drill press. It was slightly oversized, but it actually worked out very well. Then just order up some weld on metric caliper brackets, and decide if you want ebrake calipers or non ebrake calipers.
Paul
"If it doesn't fit, get a bigger hammer"
Madzooki is offline   Reply With Quote Quick reply to this message
Old 04-30-2010, 05:15 AM   #4 (permalink)
Member # 159321
Thank you Paul....
Old 04-30-2010, 09:53 AM   #5 (permalink)
Madzooki's Avatar
Member # 13569
No problem.
