Wire rope retainer? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-12-2010, 08:12 PM   #1 (permalink)
Member # 73492
Wire rope retainer?
So the Crappy terminal end on my warn 12K just pulled out!!
Where can i get one of the retainers that clamps the rope on to the side of the drum??
88 Sub, 6" Lift 44F,14R Olive drab, 37" Military OZ's On Stazworks H1's
widmayer123 is offline   Reply With Quote Quick reply to this message
Old 05-12-2010, 08:21 PM   #2 (permalink)
Union Fab Works
carwash's Avatar
Member # 21939
Send a message via AIM to carwash Send a message via Yahoo to carwash
warn.
carwash is offline   Reply With Quote Quick reply to this message
Old 05-12-2010, 09:19 PM   #3 (permalink)
ProMod #22
95rokrunner's Avatar
Member # 97376
Pulled out??
You mean to tell me that the retainer on the end of the winch cable cant even hold up to 12,000lbs of pull??
Keep a couple move raps on the drum next time
Team DuraLine rock crawling
2012 W.E.ROCK National Champions
2013 W.E.ROCK Western Series Champions
4522 Trail-Gear F-Toy
95rokrunner is offline   Reply With Quote Quick reply to this message
Old 05-12-2010, 09:27 PM   #4 (permalink)
Gunmetalcruz's Avatar
Member # 6569
splice that end,girth hitch drum specific to direction of pull. your done.
Team FOH# 321
Gunmetalcruz is offline   Reply With Quote Quick reply to this message
Old 05-12-2010, 10:56 PM   #5 (permalink)
Member # 24859
explain what a girth hitch is gawd damit, the rest of us are stupid.
Mellonhead
peesalot is offline   Reply With Quote Quick reply to this message
Old 05-13-2010, 12:43 AM   #6 (permalink)
Member # 145218
go to the electrical section of your local autoparts store and get a battery cable crimp and have at it
johny5.0 is offline   Reply With Quote Quick reply to this message
Old 05-13-2010, 12:57 AM   #7 (permalink)
Corey Young's Avatar
Member # 21622
I shortened the cabe on my M15000, the original end looks like an automotive battery cable lug crimped on. My girlfriend took it to a store that makes custom battery cables, they wouldnt put an end on it because it was a winch cable. She took it to a winch cable store for an end and they wouldnt do it because part of the cable was a little flattened. She ended up getting a bolt on end for a house ground cable.
Old 05-13-2010, 09:32 AM   #8 (permalink)
AnySevenOffroad's Avatar
Member # 145175
Battery cable crimp lugs are what we put on our lines if people want them. They aren't for pulling, just for starting to wrap the line around the drum.
We build stuff
AnySevenOffroad is offline   Reply With Quote Quick reply to this message
Old 05-13-2010, 09:41 AM   #9 (permalink)
thhhpptthh!
sceep's Avatar
Member # 10798
Send a message via AIM to sceep Send a message via MSN to sceep
Originally Posted by 95rokrunner View Post
Pulled out??
^this.
hell just tie a good knot in the end.
My mom wrote a kids book!
Originally Posted by USDA forest service website
It is every American's birthright to use the national forests and grasslands in multiple ways, including outdoor recreation in all its forms.
sceep is online now   Reply With Quote Quick reply to this message
Old 05-13-2010, 10:31 AM   #10 (permalink)
Member # 43587
Send a message via AIM to TBItoy
I just use duct tape to start my syn line.
Tape the end to the drum then flip the tape over and wrap the drum with the sticky side up, flip the tape back over, stick it down and tear it off.
I find that helps if your syn line gets loose and tries to spin on the drum.
The Gremlin - small ugly linked beater Toyota
TBItoy is offline   Reply With Quote Quick reply to this message
Old 05-13-2010, 10:58 AM   #11 (permalink)
Member # 99437
Send a message via Yahoo to CTD NUT
I'd like to see the guy that ties a knot in a piece of 3/8" wire rope!
'80 CJ7-MPFI 454, 60's, linked, locked, C/O'd, bagged, tubed, Doublered, 111" WB, 44" TSL/Boggers
CTD NUT is offline   Reply With Quote Quick reply to this message
Old 05-13-2010, 11:19 AM   #12 (permalink)
Member # 6569
I am using a piece of accessory cord instead of winch rope for demo. Pretend it has a eye splice like your working end of your winch rope. Couple things why I don't like thimble's in the end of your splice as well. You can use the rope like i am showing in the picture to instantly start winching to someone's bumper or hitch etc. without using any shackle or anything that will come flying back and catch you in the teeth. So a girth hitch is when you run your eye around the drum and run the tail threw the eye. It will lock down per direction of pull. if its's backwards it will spin. The option of duct taping it intially is good for the first few wraps in addition. Its just a much better way then the crimp garbage.
Team FOH# 321
Old 05-13-2010, 04:26 PM   #13 (permalink)
Member # 73492
Went to my Local ACE, they had the Terminal, Just for the Record, I had over 10 Wraps on it!!
Old 05-13-2010, 04:31 PM   #14 (permalink)
ProMod #22
Member # 97376
HAHA, just figured I would say it before someone else did
Old 05-13-2010, 05:13 PM   #15 (permalink)
DiscoDino's Avatar
Member # 15296
Clove hitch, some tape on the first 3-5 wraps, and you should be good.
One other reason I like the M8274-50s I have, they have a hole to place the rope through and tie a figure 8 and then do the tape trick...good stuff.
Nadim
'83 D130: 54" TTCs or 42.5" Boggers, OEM RW2.5s, Stazworks, LQ4, Atlas, dual M8274-50s, mid-mounted 9.5xp-s, dual 16" ORIs, PRP seats, etc...
'91 D110: 36" Iroks, R380, 2wd conv, underdrive, ARBs, 30 spl front, Sal D60 rear, caged, Fox remote reservoirs, M8274-50, and P&P exo-cage, etc...
DiscoDino is offline   Reply With Quote Quick reply to this message
Old 05-19-2010, 06:54 AM   #16 (permalink)
Member # 73492
So .... It pulled out on the first pull!!!
Im gonna Cut a slot in the drum, abd weld in a tube with a set screw!!
Old 05-19-2010, 09:09 AM   #17 (permalink)
Member # 4878
Send a message via ICQ to Travis Waldher Send a message via MSN to Travis Waldher Send a message via Yahoo to Travis Waldher
It pulled out on the first pull?
You likely failed then. Either at keeping enough wraps on the drum or by NOT loading the cable on the drum under tension before using it.
Travis Waldher is offline   Reply With Quote Quick reply to this message
