Shortstar Help! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-16-2010, 06:30 PM   #1 (permalink)
Member # 54349
Shortstar Help!
I just replaced the motor in my comp. rig. I am not getting a pulse to my injecters. I changed all sensors, Does start on starting fluid. Went over all wiring many times. All plugs are connected properly. I am running a turn key harness and computer. Any suggestions on what my problem is.
Team Quadratec Stock Mod #832 Special thanks to our sponsors:
Quadratec.com ,Rausch Creek offroad park,Tom woods Drive Shafts, Spidertrax, Mastercraft,Bfgoodrich,Ramsey, Extreme Axle Sales.com, KC Hilites, HI-9, CTM, Bushwacker, Trailready
Shram is offline   Reply With Quote Quick reply to this message
Old 05-16-2010, 06:39 PM   #2 (permalink)
2D EDGE's Avatar
Member # 47600
How did you verify you were not getting pulse, Noid lights? I had similar problems with my northstar and it tuurned out to be junk injectors.
If you truely do not have pulse check power to the injectors with a chassis ground because if I remeber right the pulse is ground controlled.
Geoff
Team 2D EDGE would like to thank
as well as pirate4x4!!\
2D EDGE is offline   Reply With Quote Quick reply to this message
Old 05-16-2010, 06:42 PM   #3 (permalink)
Member # 54349
Definetly not getting pulse. All grounds are hooked up. Its killing me. Spent all day covering my steps.
Old 05-16-2010, 06:51 PM   #4 (permalink)
Member # 108009
Send a message via AIM to RokYota
Kurt, do you have a scan tool ??? Look in live data to see if you have RPM's while cranking........
3800SC Buggy
'67 FJ40
RokYota is offline   Reply With Quote Quick reply to this message
Old 05-16-2010, 08:26 PM   #5 (permalink)
Member # 127251
did you check the coil packs things. I dont know if thats the right term. There is one each side of the motor over the spark plugs. I had one go out a few years ago and there was no spark or pulse.
RocksteadyRacing #246
Shortstar TJ
rocksteadyrobk#246 is offline   Reply With Quote Quick reply to this message
