aluminum 4 link arms? good idea or bad - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-19-2010, 11:18 PM   #1 (permalink)
bturton's Avatar
Member # 90506
so i work at an aluminum extrusion plant and can have any size tube made out of aircraft aluminum for cheap and ive seen some rock buggys with aluminum 4-link setups. so what are your thaughts on it? would it hold up on a lighter rig 5000 lbs or less with with a v6 and 40" tires
bturton is offline   Reply With Quote Quick reply to this message
Old 07-19-2010, 11:30 PM   #2 (permalink)
Member # 55444
They aren't running tube, they're running solid stock, drilled and tapped.
[CENTER]I have Dumb Ideas[/CENTER]
spidr is offline   Reply With Quote Quick reply to this message
Old 07-20-2010, 07:30 AM   #3 (permalink)
bturton's Avatar
Member # 90506
i can have that made too, is it worth my time to make my rear 4-link out of aluminum or just buy dom tube
Old 07-20-2010, 07:46 AM   #4 (permalink)
Trail Tampon
rajincajingt's Avatar
Member # 27333
no,
in my OPINION aluminum is a fad.
racers are breaking their aluminum links right where the threads stop.
use DOM save some cash and paint em silver if you want.
EDIT: if you really want to blow some cash and save some weight, get heat treated chromo links.
05 LJ stock
1976 C30 3+3 12V/47RH
instagram: LunchBoxFab
rajincajingt is offline   Reply With Quote Quick reply to this message
Old 07-20-2010, 08:01 AM   #5 (permalink)
Member # 7086
Originally Posted by rajincajingt View Post
no,
Ding Ding Ding Ding
Everyone jumped on the wagon because a few big names did it. If you sit down and look at the properties is makes no sense.
If you want links that will never fail heat treated 4130 are the way to go because you gain tons of yield strength and it gives the material amazing memory. (it will remember if you talk shit and will make the other parts of the car fail)
NO LIMIT CREW
CA_YJ is offline   Reply With Quote Quick reply to this message
Old 07-20-2010, 08:04 AM   #6 (permalink)
assman's Avatar
Member # 35661
Here you go
http://www.hereticfab.com/store/merchant.
New buggy in the works
assman is offline   Reply With Quote Quick reply to this message
Old 07-20-2010, 09:09 AM   #7 (permalink)
BadAZYj's Avatar
Member # 6815
meh, ht cromo is probably the best option now, but al is not bad. i run solid 2"7075 lowers and 1.5" uppers, got a good deal on them from letzrolloffroad and havent had a problem with em yet, the oldest ones ive got are probably 4+ years old(my rear links) and at that time it was dom or aluminum, i bent 1.75 .250 wall dom pretty good, and didnt want the weight of 2" dom so i chose al and havent been disappointed.
BadAZYj is offline   Reply With Quote Quick reply to this message
Old 07-20-2010, 09:40 AM   #8 (permalink)
bturton's Avatar
Member # 90506
im not looking in to doing this as a fad, im just asking because i can have these made for me for the cost of around .50 cents a pound to 1.25 a pound and i can have access to spares if they do bend or break
Old 07-20-2010, 09:58 AM   #9 (permalink)
howyadoin's Avatar
Member # 84132
IMHO, as Scott said above, 2" 7075-t6 solid with quality 1.25" heims...pretty damn bulletproof in my experience.
Debating economics with Screwloose is like asking a homeless dude for stock advice.
howyadoin is offline   Reply With Quote Quick reply to this message
Old 07-20-2010, 03:27 PM   #10 (permalink)
Member # 1636
Same here but with 1.25" johnny joints.
chris demartini is offline   Reply With Quote Quick reply to this message
Old 07-20-2010, 04:41 PM   #11 (permalink)
Member # 127459
2nd that..... I have beat mine to death. Still holding up.(the same as above)
ECUELITE is offline   Reply With Quote Quick reply to this message
Old 07-20-2010, 04:53 PM   #12 (permalink)
Member # 20276
Hell how much can you get a stick of Solid 2.25 dia 7075 t-6 for. I can drill and tap a set of links for you for a stick. Just a idea!
I have the tap and drill in my toolbox draw. I like 2.25 OR 2.5 dia with 1.25 dia heims, gives you over.500 wall thickness.
01 RAM 2500 24V CUMMINS DD/Krawlerhauler
85 Yota Buggy 4.3/tb350/x2ler/2.5tons/42"s
Ramrock is offline   Reply With Quote Quick reply to this message
Old 07-20-2010, 05:28 PM   #13 (permalink)
Member # 80873
if i was building a trail rig id run aluminum for lowers and uppers if i was building a ultra 4 or racer id build trailing arms for lowers and aluminum uppers. if you have acess to the aluminum and can build a couple spares for cheap why not?
bushauler is offline   Reply With Quote Quick reply to this message
Old 07-20-2010, 06:33 PM   #14 (permalink)
Member # 5110
The problem with most aluminum links is that they are solid. Tube is a much more efficient use of material. If you can make some stupid-thick-wall 7075-t6 links go for it. Make them with the right ID so you can just tap them out without doing any drilling.
Link to thread on my calculator https://www.pirate4x4.com/forum/showthread.php?t=204893
Triaged is offline   Reply With Quote Quick reply to this message
Old 07-20-2010, 06:39 PM   #15 (permalink)
Member # 151427
if you put them on the bottom and dom on top it's a good mix. the aluminum will allow some bending if it hits rocks and the dom on top will keep things nice and strong.
postaldave is offline   Reply With Quote Quick reply to this message
Old 07-20-2010, 06:45 PM   #16 (permalink)
howyadoin's Avatar
Member # 84132
Wut?
Old 07-20-2010, 07:04 PM   #17 (permalink)
Member # 12225
X2....this would be rad!!
I used to have 1.75 7075 lowers and killed them almost instantly.....for the last year I've been running 2" 7075 T-6 lowers and they are still straight....you can't run your hand on them without being cut but they are still goin strong. Midwest Control 7/8-3/4 heims attach them to the axles and chassis
jeepmauler is offline   Reply With Quote Quick reply to this message
Old 07-20-2010, 07:11 PM   #18 (permalink)
Member # 5110
Wut?
https://www.pirate4x4.com/forum/showthread.php?t=874715
Old 07-20-2010, 08:11 PM   #19 (permalink)
Corey Young's Avatar
Member # 21622
I have a picture somewhere of a hollow aluminum upper link that broke in the middle at KOH and put the team out of the race.
Old 07-20-2010, 08:29 PM   #20 (permalink)
the glassman's Avatar
Member # 33365
Send a message via MSN to the glassman
im not an engeneer....hell i cant even spell that...
but i do understand metal fatige sum....
to me common sence would say .....
solid bar stock all. would fatige less...(slower) than a hollow tube.....
due to the fact that the tube is going to flex and "move" around more than the solid.......
walk a mile in someone elses shoes. then you'll be a mile away and have their shoes.
the glassman is offline   Reply With Quote Quick reply to this message
Old 07-20-2010, 09:26 PM   #21 (permalink)
Member # 5110
If you took 2 pieces; one solid and another of the same weight but a tube the tube would flex, move, and fatigue less. The drill size for a 1.25-12 rod end is 1.172. If he had a tube that was 2.313 OD and 1.172 ID it would be about the same weight as a 2.000 OD solid bar but would be about 67% stronger/stiffer/fatige(sic) less. The reason no one uses aluminum tube is because it isn't readily available in sizes we would want (like the stupid thick example above). The OP can make whatever random size he wants.
If you read the post I linked to you will see that I'm not a big fan of aluminum upper links...but that isn't to say they can't be made to work especially with custom extrusions. I wouldn't run steel if I worked in an aluminum extrusion plant that would let me make cool stuff for myself I would also make some money by selling some to the guys on pirate...
Old 07-20-2010, 09:27 PM   #22 (permalink)
Member # 5110
Well; let's see it.
Old 07-20-2010, 09:40 PM   #23 (permalink)
Member # 21622
Well; let's see it.
Its at my friends house.
Old 07-20-2010, 10:39 PM   #24 (permalink)
bturton's Avatar
Member # 90506
thanks for the info, and not bashing me, i will see what size dies are in the die shop tomorrow, when i have it made i would have to use a whole slug witch is 2 feet long x 9 or 7" wide depending on witch press is used, meaning ther'll be about 30-40 feet of it made roughly, would anyone be interested in 2.25 or bigger 7075 t6 solid pieces if not i will scratch up the extra and probally put it into the scrap pile at work, i will find out prices tomorrow too
Old 07-21-2010, 05:39 AM   #25 (permalink)
BadAZYj's Avatar
Member # 6815
in thanks
Well this sucks...
