What happened to the Walbro Pickup thread??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-21-2010, 05:49 PM   #1 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
I've had this hyperlink saved for like a year. I just checked in on it a week or two ago and it was there. But now that I finally need it its gone! What happened? It doesn't turn up in a search either.
https://www.pirate4x4.com/forum/showthread.php?t=727695
J. J.
Old 07-21-2010, 06:07 PM   #2 (permalink)
Pto
Pto's Avatar
Member # 87197
its a long shot, but here is the one I have bookmarked, from 5/09
Camos:
Linky
https://www.pirate4x4.com/forum/showthread.php?t=786737
some good info - hope it helps
88 YJ SBC/T350/D300/4:1/D44s/35s
Tellico Rally#47 - JV Rally#262
Pto is offline   Reply With Quote Quick reply to this message
Old 07-21-2010, 06:20 PM   #3 (permalink)
lowlock116's Avatar
Member # 67517
J. J.
If your looking for a place to buy them, Liquid Iron has been carrying them for a little while now.
[COLOR="Lime"]You gotta wont it![/COLOR]
[COLOR="lime"][COLOR="Lime"]Lock Motor Sports [/COLOR]possible thanks to:[/COLOR]
[COLOR="lime"]
Maxxis, FOA Shocks,Twisted Stitch Seats, LetzRoll Offroad, Capturing Time Photography[/COLOR]
lowlock116 is offline   Reply With Quote Quick reply to this message
Old 07-21-2010, 07:53 PM   #4 (permalink)
lxh0318's Avatar
Member # 82770
This is where I got mine. I got 3 normal and one with the bleed hole like recomended.
http://www.autoperformanceengineerin...l/pickups.html
lxh0318 is offline   Reply With Quote Quick reply to this message
Old 07-21-2010, 07:54 PM   #5 (permalink)
K^2
kirbyiv's Avatar
Member # 49704
what do you need to know about them JJ?
Walle Crawler
Benz Buggy
Slinky Blue Ballz
kirbyiv is offline   Reply With Quote Quick reply to this message
Old 07-22-2010, 08:03 AM   #6 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
There was just some good tech in that thread that I wanted to go over before buying.
J. J.
Old 07-22-2010, 08:48 AM   #7 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
Has anyone found a more affordable source for the submersible fuel line? $23/foot is insulting.
J. J.
Old 07-22-2010, 08:57 AM   #8 (permalink)
lowlock116's Avatar
Member # 67517
J. J.
I got mine from Liquid Iron & it was $20/ft.
They were talking about getting some that
was only $15/ft. I don't know if they did get
any or not. Their under the vendor
miss. thread & you can order off their website
or call them.
[COLOR="lime"]
Old 07-22-2010, 09:02 AM   #9 (permalink)
Member # 44856
Send a message via AIM to DownNDirty
I picked mine up a while back. Should have just ponied up for the submersible line from the vendor. Now I have to pay the same if not more and find it.
DownNDirty is offline   Reply With Quote Quick reply to this message
Old 07-22-2010, 09:35 AM   #10 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
Timmay just reduced his price to $15/ft.
J. J.
Old 07-22-2010, 11:52 AM   #11 (permalink)
Liquid Iron Ind.
Timmay's Avatar
Member # 52894
J. J.
Sure did, finally! The Gates stuff is great but the fact that I can only buy it in 1 foot sections really sucked. Not to mention the pricing I was getting was insane.
A good bit of research led me to this Eaton line that does the same thing for quite a bit cheaper.
In the near future I will start offering in tank pickup kits that include absolutely everything needed to put this setup in the common fuel cells.
Tim Diekmann
Liquid Iron Industries, LLC
(856)-336-2639
Molten Motorsports #4343 "Fred"
Timmay is offline   Reply With Quote Quick reply to this message
Old 07-22-2010, 12:10 PM   #12 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
I'm designing my setup in my brain right now and will be buying shortly. Thanks again.
J. J.
Old 07-22-2010, 01:05 PM   #13 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
I have used Russell twist lock hose in tank a few times without issue.
& Blaine
:tank:
Old 07-22-2010, 01:30 PM   #14 (permalink)
BTF1's Avatar
Member # 25253
X2 I am running what the KING said to run
Bent and Twisted Fabrication
Ness City, Ks 67560
BTF1 is offline   Reply With Quote Quick reply to this message
Old 07-22-2010, 01:40 PM   #15 (permalink)
lxh0318's Avatar
Member # 82770
I used solid line because I couldn't find in tank line locally.
Old 07-22-2010, 02:21 PM   #16 (permalink)
Liquid Iron Ind.
Timmay's Avatar
Member # 52894
Loren,
Did you just run the "stock" JAZ pickup tube to that barb fitting?
That's exactly what my kits are going to look like. The hardline holds the pickups in the bottom of the cell a lot better when there is no foam in the tank.
Tim Diekmann
(856)-336-2639
Old 07-22-2010, 03:11 PM   #17 (permalink)
Member # 103621
I went to O-Reilly's and pick up some submersible fuel safe fuel line. It was around $8 for 18'' of it and they had several sizes. I used 5/16'' for my 4.3L.
The lines have only been in use for 4 months or so and seem to be holding up perfectly fine. I also used APE to get the pickups as well.
1982 Toyota - Dirt Squirrel - LQ4/Atlas 4.3, D60/14b w/ Reids & RCVs, 3-link/4-link, 43" stickies
the_white_shadow is offline   Reply With Quote Quick reply to this message
Old 07-22-2010, 03:53 PM   #18 (permalink)
Gravity Works!
Landslide's Avatar
Member # 25608
OK crazy question here but... How would this setup stop from just picking up air when the fuel level is very low and the rig is at an extreme angle?
Peg Leg Fab Lab
Landslide is offline   Reply With Quote Quick reply to this message
Old 07-22-2010, 03:57 PM   #19 (permalink)
Member # 84361
Attachment 536924
Thats what those pickups are designed to do. Read one of the linked threads.
Toy, 4.3, 4l60, d300, tons, 38's, Trail Slut
JHF GB Chassis in progress.
crazybluerider is offline   Reply With Quote Quick reply to this message
Old 07-22-2010, 04:17 PM   #20 (permalink)
Pook's Avatar
Member # 3370
J. J.
I'm using a clear hose from a place called Newline. www.new-line.com
Pm if you want more info I can call and see what kind of hose it is.
They said its commonly used for clear fuel hose on custom choppers. Its all one piece so its gas resistant inside and out and I got 5' for $20 or so. Been in use for 6-7 months and no issues yet.
:grinpimp:
Pook is offline   Reply With Quote Quick reply to this message
Old 07-22-2010, 04:18 PM   #21 (permalink)
Pook's Avatar
Member # 3370
Used that on my ftoy for 2 years and had no issues.
:grinpimp:
Old 07-22-2010, 04:34 PM   #22 (permalink)
Member # 99513
In for the tech
Question, How do you secure the pickups to the bottom of the cell? It would think that all that rockin and rolling, jumping, would cause the pickups to rattle around? I my self plan on going with a JAZ cell for my build, but thinking how to securely hold down the pickups at the bottom of the cell? Or is there something about JAZ cells I abviously don't know about?
thanks.
Swapping Front ends:
Motorcycle stuff.
[SIZE="5"][COLOR="Red"][B]NEW BEGINNINGS:[/B][/COLOR][/SIZE]
jpfrk2001 is offline   Reply With Quote Quick reply to this message
Old 07-22-2010, 06:08 PM   #23 (permalink)
K^2
kirbyiv's Avatar
Member # 49704
Originally Posted by jpfrk2001 View Post
In for the tech
thanks.
my foam holds them down
Walle Crawler
Benz Buggy
Slinky Blue Ballz
Old 07-22-2010, 08:34 PM   #24 (permalink)
lxh0318's Avatar
Member # 82770
Loren,
Yeah, stock pickup tube. I raced one race without foam and didn't have any problems but the week before KOH I paniced about tech and ordered the ATL foam. Funny thing is I probably have more money in my set up that if I ordered on of the nice ATL cells from the get go.
Old 07-22-2010, 11:14 PM   #25 (permalink)
Member # 99513
Got it. Order cell with foam, remove foam, install pick ups, reinstall foam on top of pic ups, Make sure a hole is hollowed in foam for feed line.
I assumed thats the reason for all the bolts at the top of the JAZ cells. So its also save to assume, its easy to apply coating also? Or install a custom ballistics proof cell liner within it? Makes it easy to apply future upgrades easily?
Motorcycle stuff.
