2 Ton GM axles? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-24-2010, 09:40 PM   #1 (permalink)
JF
Member # 133890
2 Ton GM axles?
There are a set of "GM 2 ton axles" on my local craigslist. I searched but I couldn't find any info on them. Can someone give me the low down? I am guessing they aren't that great since there doesn't seem to be much info on them.
JF is offline   Reply With Quote Quick reply to this message
Old 07-24-2010, 09:48 PM   #2 (permalink)
Member # 111310
If they are from the 50's gmc 2 ton trucks.
The third comes out, and can be swapped front to rear, which means the front spins backwards. Special t-case without low range to do this.
I wouldnt run them, I gave a set away.
chevycrew is offline   Reply With Quote Quick reply to this message
Old 07-24-2010, 10:34 PM   #3 (permalink)
Corey Young's Avatar
Member # 21622
Looks like WW2/ Korean War era military axles.
Old 07-24-2010, 11:21 PM   #4 (permalink)
DWT
DWT's Avatar
Member # 19850
Brittle shafts that aren't as tough as stock rockwells but hell if the price is right go for it.. Yes the front diff spins backwards, no problem all you have to do is flip it over and you can run a normal t case with it.
'89 auto x toyota pickup, most fun I've ever had with my clothes on.
Taiwanese Garbage should stay in Taiwan.
DWT is online now   Reply With Quote Quick reply to this message
Old 07-25-2010, 12:16 AM   #5 (permalink)
Member # 55444
There is actually a ton of info about them out there, and there is usually a "how good are GMC 2.5ton axles" thread, at least once a month between the mud section and the chevy section.
[CENTER]I have Dumb Ideas[/CENTER]
spidr is offline   Reply With Quote Quick reply to this message
Old 07-25-2010, 03:51 AM   #6 (permalink)
Member # 15354
Send a message via AIM to iniviate
depends.... there are severl different ones. the fine spline ones are supposed to be stronger than stock rockwells.
i ran a set on 49" v-treads without issue.
02 S10 - LS1, 4L80, 2.5 tons, 14.9-24 R1's - In Progress.
88 YJ - 350, 1 tons, 40's
iniviate is offline   Reply With Quote Quick reply to this message
Old 07-25-2010, 07:20 PM   #7 (permalink)
JF
Member # 133890
I searched but the search engine won't include "2" so it only brought up a million threads including "ton" in the title. And the dude doesn't have them listed as 2.5, he has them as 2 ton ... IDK if it's listed wrong or not.
What were you doing for lockers? Just welded?
Are the any numbers such as a BOM that would offer more info?
Old 07-25-2010, 07:22 PM   #8 (permalink)
Member # 55444
They sure look the same as every 2.5 ton GMC axle that's been asked about. Try that.
Old 07-26-2010, 03:22 PM   #9 (permalink)
JF
Member # 133890
Looks like you're right, the pics from the ad are pretty shitty but I found this one of a set of 2.5 tons advertised for sale on here (for $1400 ) and the diff cover looks to be the same.
In searching further I also found some more info from iniviate
i ran them on 49" tires without breakage...
there are 3 versions. 6.17 gears, 6.67 gears, planetaries.
i only know of one person with the planetary style. they're holding up fine to 65" tires.
6.67 should be course spline shafts. this is the weakest design.
6.17 should be fine spline shafts. these are supposedly stronger than a toploader. all i know is i never broke mine. there is a "ring" on the end of the axle shaft, which makes them easy to identify without disassembly.
you don't need to run the special transfer case.
if you want a drivers side drop, you can spin the housing around and swap knuckles. you'll need to clearance the diff cover for the tie rod. other than that, no modifications. just moving things around.
if you want a passenger side drop, you'll need to spin the chunk. this will require clearancing the housing. it will become obvious when you pull the chunk. you will also need to shorten one axle shaft.
if you can get them cheap, run them. don't pay toploader prices for them though.
The ad was for $500 obo ... so far I don't think I want them that much. I am looking for info regarding grafting the knuckles onto a 14 bolt. If I could haggle and get the front for ~$100 and then pick up a couple 14b rears for ~$100 ea it might be worth the effort.
So if you have info on chopping the knuckles link it up.
iniviate- I am interested to know what you did for lockers and brakes. Thanks
Old 07-26-2010, 05:32 PM   #10 (permalink)
Member # 15354
welded, but i think somebody makes a locker for it.... i can't remember who though and i'm sure they'll be proud of it.
i ran a pinion brakes. there are some with factory disc brakes. i'll go see if i can dig up pics.
Old 07-26-2010, 05:35 PM   #11 (permalink)
Member # 15354
ok... this is all i was able to find. looks like you would need to fab up your own caliper mounts.
http://chuckstrucks.iforumer.com/vie...trucks#1222752
(yes, i just posted a tech link to chucks trucks. )
Old 07-27-2010, 09:46 AM   #12 (permalink)
Member # 84172
They look like M135 axles.. Identical to the ones on my dads 56 M135 GM 6x6.
SO I would start by searching on Steel Soldiers and see what they have for information.
BENNY87 is offline   Reply With Quote Quick reply to this message
