Who can make custom shafts? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-05-2010, 05:02 AM   #1 (permalink)
GreatWhiteXJ's Avatar
Member # 103442
Send a message via AIM to GreatWhiteXJ
Without the long drawn out story...I can now make SEVERAL of the parts I need for my jeep rather than buying them.
Unfortunatly we cant do anything with splines. And that puts a big delay in a home brew doubler build.
So I need a mid shaft for a 231/300 kit. I can make everything else. All I need is the mid shaft. I've emailed Duffy and Mad Rooster in regards to selling the midshaft seperate. No replies after a few weeks now.
So who can make me a 231/300 midshaft?
Also, I do not have a 231 right now. So Im not gonna lie, I have no idea what the exact measuremnts are. Can anyone help me out there?
Edit: And yes, I realize anyone who makes shafts can probably do this. BUT...I've never had to source out anything like this so I dont have a clue even where to start looking.
XJ Buggy. RoXJoX
GreatWhiteXJ is offline   Reply With Quote Quick reply to this message
Old 08-05-2010, 05:44 AM   #2 (permalink)
Banned
DrVic723's Avatar
Member # 46226
So can you turn the blank then have the heat treat and splining outsourced? That would save you some $$$ and I could point you to some great companies.
Jeff
DrVic723 is offline   Reply With Quote Quick reply to this message
Old 08-05-2010, 08:50 AM   #3 (permalink)
Member # 12686
Send a message via AIM to CGuava
Hit up Scott up at Rockstomper, at least you're in CO so is he.
The Guava Runner.
CGuava is offline   Reply With Quote Quick reply to this message
Old 08-05-2010, 08:58 AM   #4 (permalink)
Member # 21215
Location: Tennessee...The land of high horsepower and low IQ
Axle Jack at CTM did the midshaft between my Klune and Atlas out of 300m after I broke the stocker. His price was fair and turnaround was quick. Branik also quoted the job and was a little cheaper but I needed the part quicker than they could get to it. So, those would be two companies to try for sure.
redneckengineered is offline   Reply With Quote Quick reply to this message
Old 08-05-2010, 09:08 AM   #5 (permalink)
Member # 104243
Send a message via AIM to asp87
I plan on making my own out of a ax-15 output shaft and a 231 output shaft. I'm going to cut the input of the 231 output off and bore a hole into it. Then I'm going to take the ax-15 output shaft and cut off its output, turn down part of it to press fit into the 231 output shaft. Then bevel the crap out of both, press them together, and weld it together. I ran some quick #'s about how much torque this shaft should see and I think it will be strong enough. Criticisms are welcome.
asp87 is offline   Reply With Quote Quick reply to this message
Old 08-05-2010, 09:11 AM   #6 (permalink)
Member # 55444
I've seen some welded shafts, never seen one let go in a 231 crawl box.
Sent you a PM greatwhitexj
[CENTER]I have Dumb Ideas[/CENTER]
spidr is offline   Reply With Quote Quick reply to this message
Old 08-05-2010, 03:31 PM   #7 (permalink)
Member # 103442
Jeff
Yes, I could definatly do that. Point away.
Hmmmmm....not a bad idea. I could tig the shafts...have eveything else I need to fit them correctly.... I might look into this. Appreciate the feedabck.
PM replied! And VERY appreciated!
XJ Buggy. RoXJoX
Old 08-05-2010, 03:37 PM   #8 (permalink)
Banned
DrVic723's Avatar
Member # 46226
There are some good HT sources here on the board (heretic), send the splining to Gerhardtgear.com out of California. They are basically awesome.
Jeff
Old 08-05-2010, 03:50 PM   #9 (permalink)
Member # 103442
Thanks Jeff!
XJ Buggy. RoXJoX
Old 08-05-2010, 04:11 PM   #10 (permalink)
Wilson's Avatar
Member # 7233
66cjdean can do it all
Old 08-20-2010, 01:32 PM   #11 (permalink)
Member # 940
I have made one of thoes befor so no problem. Like stated you can do all the turning and all I do is cut the splines or I can do it all.
Deep Cryogenic Tempering Service
[b][SIZE="5"]Find all my products at[/SIZE][/b]
[b][SIZE="4"]916-434-6978
Custom Sway Bars and Axles built to order. [/SIZE][/b]
[b][SIZE="5"]Got 40 spline? I have the hubs, spindles, and axles you need to kickass![/SIZE][/b]
Custom Hummer wheels and centers
Axle Resplining
66CJdean is offline   Reply With Quote Quick reply to this message
Old 08-20-2010, 01:53 PM   #12 (permalink)
Member # 95678
Another good word for Branik, all USA made 300M.
D.T.Starr is offline   Reply With Quote Quick reply to this message
Old 08-24-2010, 02:38 PM   #13 (permalink)
Member # 72951
Maybe check out Jeds Machining. I know they do resplining of stock np203 shafts for the 203/205 doubler and it was only around $70 with supplying the stock shaft.
I bet they could fix you up.
04 Ram 1500 qc KPD60 AAM11.5 4.88's bilstein 9300s
Hemi 40" Nitto Trails
mudskipper4x4 is offline   Reply With Quote Quick reply to this message
Old 08-24-2010, 06:37 PM   #14 (permalink)
Member # 103442
Few PM's sent.
Biggest problem with persuing this right now is I have no idea what size the shaft needs to be. I still do not have the 231 so Im shooting in the dark completly.
Does anyone have the measurements or a shaft out they could be so generous as to measure for me?
XJ Buggy. RoXJoX
Old 08-24-2010, 08:17 PM   #15 (permalink)
michigander's Avatar
Member # 8402
x2
Inviscid Motorsports #9009
Thanks to; Ironman Offroad - Motorcity Machines - Branik Motorsports
michigander is offline   Reply With Quote Quick reply to this message
Old 09-12-2010, 04:27 PM   #16 (permalink)
Newbie
xxxxxxxxxxxweedinhop's Avatar
Member # 145388
231/300 doubler shaft
Hey man I think I can help you out with the length of the shaft you need. I have a 231/300 doulber in my rig now, I made all the parts myself including the shaft. I'm a toolmaker my trade and so I made my own cutter and did all the splining myself. So I don't know if my set up will be the same stack height as what yours is, but if you interested I'll send you some pics of it and if it looks the same, I'll give you all the dimensions you need. Both the 231 and the 300 are flipped, and so I made clocking rings for both as well. The whole doubler is in my rig right now being mocked up, but I'll be pulling it out in the next week, so like I said if this sounds like what your needing let me know and I'll post some pics and dimensions.
xxxxxxxxxxxweedinhop is offline   Reply With Quote Quick reply to this message
Old 09-28-2010, 07:46 AM   #17 (permalink)
Member # 104243
It turns out that the output shaft of an ax-15 is hardened all the way through. The 231 output shaft is case hardened, too. My grandfather's small Logan just couldn't handle the hardened parts and I don't have a way to broach the splines on a blank. Looks like I need to buy one.
Greatwhite, what did you end up going with on this one?
Edit: If I heat the shafts up to a deep glowing red and let them cool slowly, that should remove the heat treatment, right? I mean, I have torches and could try it...
Old 09-28-2010, 03:28 PM   #18 (permalink)
Member # 103442
ASP... I have not persued this any further at this point. Not because I've lost intrest, but because its Halloween season and I have a major role in Denver's premier haunt, City of the Dead.
I can tell you everyone Ive spoken with in regards to either a shaft ready to go, or heat treat or spline cut, nets the shaft total around 230-300 bones. With a long way to go on the build, I've put off the t-case for now and am focusing on other things.
The way Im seeing it is, Box4Rox is 525 everything ready to go....all in need to do is turn wrenches.
I build my own means, still figuring out the shaft, then making the nessicasry plates. With the figures Ive got right now, to build my own would net me near 425. So, not to be lazy, but it really is almost easier just to order a kit. I dont know, its still up in the air.
I can tell you though, if in fact I can find someone who will do shafts without costing me my left testicle and 3 fingers, there's potential for a new doubler kit to hit the market. BUT, that is an "IF"....
XJ Buggy. RoXJoX
Old 09-29-2010, 07:02 AM   #19 (permalink)
Member # 104243
Hahaha, Have fun with Halloween season
I too have a long way to go in the build, I just really want to get my driveline squared away early on.
Last night I heated the ax-15 output shaft up until it was glowing orange and I let it cool in ambient air. I'll check its hardness tonight with the file trick.
Good luck on your junk. I'll let you know if I have any break throughs or find any dirt cheap shafts...
