mounting transmission sender for gauge - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-09-2010, 08:11 AM   #1 (permalink)
Member # 21215
Location: Tennessee...The land of high horsepower and low IQ
Is there a simple way to mount the trans sender for this gauge
http://www.summitracing.com/parts/ATM-4457/
without drilling/tapping the pan. I've got a cast alum pan, plus it's freshly filled and installed in my buggy. I'm trying to think of an alternative way to mount the sender that would work. I've got an external cooler that is easily accessible. Wondering what others have done. Thanks
redneckengineered is offline   Reply With Quote Quick reply to this message
Old 08-09-2010, 08:31 AM   #2 (permalink)
rockinfive+2's Avatar
Member # 2592
Send a message via AIM to rockinfive+2
depends on what tranny you have but they all have test ports. The ports will give a reading but most wont do it in P or N. If not autometer sells a block that goes inline of tranny lines that has a port.
Ken Cecchini
Thanks To: RCV Performance, Ruffstuff ,12 voltguy & SFS Industries
rockinfive+2 is offline   Reply With Quote Quick reply to this message
Old 08-09-2010, 09:02 AM   #3 (permalink)
Member # 21215
Forgot to mention that. It's a turbo 400 and running a cooler with -6 tube ends.
Old 08-09-2010, 09:04 AM   #4 (permalink)
thhhpptthh!
sceep's Avatar
Member # 10798
Send a message via AIM to sceep Send a message via MSN to sceep
^^ this.
put it inline.
My mom wrote a kids book!
Originally Posted by USDA forest service website
It is every American's birthright to use the national forests and grasslands in multiple ways, including outdoor recreation in all its forms.
sceep is offline   Reply With Quote Quick reply to this message
Old 08-09-2010, 10:38 AM   #5 (permalink)
Member # 21215
http://www.autometer.com/cat_accesso...st.aspx?pid=40
Looks like they are made for hard line. I'm running all soft on mine. Also, would it be better to run the sender on the outlet from the trans (hot fluid) or return line to the trans (cooled fluid).
Old 08-09-2010, 10:43 AM   #6 (permalink)
thhhpptthh!
sceep's Avatar
Member # 10798
so adapt some hose nipples to the block and hose clamp the soft line to it. this isnt rocket surgery mang!!
gauge on the hot side.
Old 08-09-2010, 10:49 AM   #7 (permalink)
Member # 21215
That's what I figured but thought that would be too ghetto. I guess there isn't really enough pressure in these lines to matter. This may even work better and wouldn't require any nipple rigging
http://www.autometer.com/cat_accesso...il.aspx?vid=49
Old 08-09-2010, 10:49 AM   #8 (permalink)
Member # 1636
put it in one of the test ports.
chris demartini is offline   Reply With Quote Quick reply to this message
Old 08-09-2010, 11:27 AM   #9 (permalink)
Member # 21215
Do you happen to know the pump pressure test port size? The sender I have is 1/8" NPT and I'm thinking that's the size of the port. If so, I could do this with no adapter rigging. Will the fluid reading from there be as accurate as taking the reading from the outlet fitting? My experience with automatics is limited and after grenading one built 400 already I'm not taking any chances.
Old 08-09-2010, 11:49 AM   #10 (permalink)
Fistful of Boomstick
usmcdoc14's Avatar
Member # 13344
Send a message via AIM to usmcdoc14 Send a message via Yahoo to usmcdoc14
Last time I did one it was inline/hot side before the cooler. I ran AN lines so it was easy to plop one in right by the trans.
Doc-14 Tactical Products:
When it absolutely, positively needs to be made from random crap found in the back of my garage.
usmcdoc14 is offline   Reply With Quote Quick reply to this message
Old 08-09-2010, 11:59 AM   #11 (permalink)
Member # 1636
Every test port I've seen was 1/8 NPT. My Dodge has the sender screwed right into the test port.
Old 08-09-2010, 12:03 PM   #12 (permalink)
Member # 21215
Awesome. I've been looking at Earl's fittings and have put together a pretty decent setup in my head that would work for the outlet line and be clean. However, since the test port on the drivers side is 1/8" NPT and pretty easy to get to I can screw the sending unit directly in there. The question is, is there an advantage/disadvantage either way? I did some research and like everything else this has been hashed out on Pirate somewhat. There's a good thread where Keith chimes in and says he runs on the test port
https://www.pirate4x4.com/forum/showp...0&postcount=30
I'm thinking if that's good enough for him that's good enough for me but I'm still interested in hearing technical reasons why.
Old 08-09-2010, 02:49 PM   #13 (permalink)
Pook's Avatar
Member # 3370
I put a T in the line going out to my cooler and put the sending unit in there. You need to add a ground wire to the T. I just used a crimped end and hoseclamp to hold it to the Brass T. Mines all AN-6 fittings as well. I also used that T to add an AN checkvalve to keep the fluid up in the cooler.
Next build I'll machine my own t with a tapped hole for a ground screw and mounting brackets built in.
:grinpimp:
Pook is offline   Reply With Quote Quick reply to this message
Old 08-09-2010, 03:50 PM   #14 (permalink)
One Big Zuk's Avatar
Member # 11145
art carr told me hot line. you want to know when it if getting hot not when it is overheated.
TTC 2010 Competitor #48 Thanks for the votes it was a great time.
Thanks to Micky Thompson Tires,King Shocks,Warn,RCV axles,ARB,Viking Winchline, OMF Wheels for the help to make my junk run.
One Big Zuk is offline   Reply With Quote Quick reply to this message
Old 08-09-2010, 05:32 PM   #15 (permalink)
Member # 4197
Andrew,
I put one in line. I took a chunk of aluminum, one inch thick by 3 inches square, and drilled a passage way all the way through it. Then tapped both ends of this passage to a pipe thread. The made another passage intersecting the original passage like a 'T". Then taped it to a pipe thread and put the sender into the block of aluminum. I then drilled two holes through the block of aluminum,taking care not to hit the passages I drilled through and mounted it to my firewall with two bolts. I used PIPE thread to AN adapters to hook up my soft trans line to the block. Looks exactly like the autometer block except it is polished aluminum instead of anodized..
brian
onetonwillysands10 is offline   Reply With Quote Quick reply to this message
Old 08-10-2010, 07:50 AM   #16 (permalink)
Member # 21215
Haha, Brian you kill me man. That is totally you...custom, clean, and badass. BTW, the pan you sent me was perfect. Fits my chassis great. If I install the sender in my hot line I'll probably just use this little guy instead of the autometer adapter.
http://www.holley.com/991703ERL.asp
Combine that with a couple nipples and I should be good to go. I'm still considering just threading the sender into the pump test port though and trying that.
