6.0 Skidplate Needed - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-15-2010, 08:21 PM   #1 (permalink)
Chubby Chaser
Mustard Dog's Avatar
Member # 7889
Send a message via AIM to Mustard Dog
Does anyone make a bolt on skidplate to cover the cast oil pan on a 6.0? I noticed there's a few good size threaded holes at the bottom of the block I figured could be used for mounting.
Eric Anderson
TIN BENDERS
Hendrix XR Chassis #001
Ultra4 #66 4Wheel Parts, Raceline, PSC, Bilstein, Marlin Crawler, Smittybilt, HendriX, PacificFab, G2 Axle, PAC Spring, G&J, MAXXIS
Roxy's in the industry and I'm a sponsored professional driver. The two of us together make a powerhouse.
Accepting the things I cannot change.
Mustard Dog is offline   Reply With Quote Quick reply to this message
Old 09-15-2010, 08:27 PM   #2 (permalink)
Member # 1636
Never seen such an item. The cast pans are fragile. It would probably be a better idea to build it into your chassis.
chris demartini is offline   Reply With Quote Quick reply to this message
Old 09-15-2010, 08:28 PM   #3 (permalink)
Gunmetalcruz's Avatar
Member # 6569
engine skid needs to be attached to the chassis not the motor IMO otherwise all you will be doing in the future is changing broken auto trans cases when you hit the motor and the trans doesn't move.
Team FOH# 321
Gunmetalcruz is offline   Reply With Quote Quick reply to this message
Old 09-15-2010, 08:34 PM   #4 (permalink)
Chubby Chaser
Member # 7889
Good call Tom.
New engine for this car and the pan sits a bit lower than the subframe making it a little tricky to add one.
Eric Anderson
TIN BENDERS
Old 09-15-2010, 08:36 PM   #5 (permalink)
Member # 1636
What pan are you using?
Old 09-15-2010, 08:39 PM   #6 (permalink)
Member # 86691
Eric get a Kevco pan, they are steel and a little shallower than the aluminum ones.
Ex racer guy:D
TCARP1 is offline   Reply With Quote Quick reply to this message
Old 09-15-2010, 08:46 PM   #7 (permalink)
Moderating Midget
wngrog's Avatar
Member # 1154
Send a message via AIM to wngrog
x2
Nolen Grogan
2016 4Runner TRD Pro
1998 Land Cruiser
1984 FJ-60
2013 RZR-XP4
USAF Veteran 1988-1998 GOD Bless America
wngrog is offline   Reply With Quote Quick reply to this message
Old 09-15-2010, 09:27 PM   #8 (permalink)
whypave's Avatar
Member # 28177
The picture of the whole in his pan looks like a truck pan which are about 8" deep. So a 5" kevko pan would be a good option but you could also go with an ls2 pan or f-body pan if you don't want to go to an external oil filter.
search around on here before making a switch though. the car oil pans have the pickup much farther forward and you really need to use an accumulator with them and if you have the f-body pan an Improved Racing baffle potentially as well. Quite a few people have kevko pans and they work as advertised but the fit and finish is pretty bad and you may have problems getting it to seal along the back edge. Dave Cole says he had a similar problem with his Kevko pan.
My Kevko pan dented even with a skid underneath it so there's no way an engine mounted skid will hold up to how we race.
whypave is offline   Reply With Quote Quick reply to this message
Old 09-15-2010, 10:14 PM   #9 (permalink)
Member # 106808
LOL... I would break that thing in my driveway. Kevko will make building a chassis mounted skid a bunch easier. Fit and finish is .......ok? Wish somebody would make a good quality unit.
KOH 2010
[COLOR="Silver"]Advance Adapters[/COLOR], [COLOR="Red"]Aurora [/COLOR], [COLOR="DeepSkyBlue"] Griffin [/COLOR],Baja Designs [COLOR="Blue"]Bilstein, CTM,[/COLOR] [COLOR="DarkOrange"]Currie[/COLOR], [COLOR="Silver"] D.J. Safety[/COLOR], Howe, J.E.Reel, [COLOR="Silver"]P.R.P Seats[/COLOR], [COLOR="Red"]Raceline Wheels[/COLOR], [COLOR="Orange"]Reid Racing[/COLOR], [COLOR="Plum"]Royal Purple[/COLOR],[COLOR="Silver"] Ruffstuff, [/COLOR] custom splice, Warn, 12volt guy
Mr.S is offline   Reply With Quote Quick reply to this message
Old 09-16-2010, 09:47 AM   #10 (permalink)
Member # 84593
x3 on changing to to an f-body car pan. You'll need to modify the pickup a little bit, and cut some "slots" to allow the oil to move to the rear of the pan easier for climbs (which adversely effects going down steep things as well, but where would you want the oil pressure?) Or you could buy a Kevko.
HardcorewannabeXJ is offline   Reply With Quote Quick reply to this message
Old 09-16-2010, 09:57 AM   #11 (permalink)
K^2
kirbyiv's Avatar
Member # 49704
Grab a Kevco, throw a skid under it mounted to the chassis and be done with it.
Just check to make sure the seal surface on the pan is perfectly flat before you mount it.
Walle Crawler
Benz Buggy
Slinky Blue Ballz
kirbyiv is offline   Reply With Quote Quick reply to this message
Old 09-16-2010, 11:19 PM   #12 (permalink)
Member # 115241
Send a message via AIM to varsis
Dry sump?
1997 Dakota, 4x4 green almost on 38's with 5.38 gears! and shift kit, with 5.9L mag. 64" deavers rear.
varsis is offline   Reply With Quote Quick reply to this message
