lowest pressure for hydro bumps - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-13-2010, 09:05 PM   #1 (permalink)
Member # 127190
what is the minimum nitrogen charge you can have for the hydro bumps?
im running radflo bumps and there are currently charged with 150lbs but wasnt sure what the minimum pressure is without doin any damage
penski61 is offline   Reply With Quote Quick reply to this message
Old 10-13-2010, 09:54 PM   #2 (permalink)
heepr's Avatar
Member # 26806
Send a message via AIM to heepr
I believe FOA says 50psi is OK.
I ran 100psi in my radflo bumps for almost 2 years with no ill effects. I now run 200psi and like it better but obviously every rig and suspension is different.
heepr is offline   Reply With Quote Quick reply to this message
Old 10-14-2010, 09:58 AM   #3 (permalink)
miniwally's Avatar
Member # 29513
I run my 2.5"X 2.0" travel kings as low as 50 psi. I have yet to set them higher than about 80 to 90 psi.
miniwally is offline   Reply With Quote Quick reply to this message
Old 10-14-2010, 11:27 AM   #4 (permalink)
mobil1syn's Avatar
Member # 9795
Send a message via AIM to mobil1syn
Uh have you called radflo?
mobil1syn is offline   Reply With Quote Quick reply to this message
Old 10-14-2010, 02:13 PM   #5 (permalink)
Blase's Avatar
Member # 63692
What damage would a low pressure cause? As long as it's got oil the only one I can think of is the bump not being real effective.
I run my 2.5 x 4.0" kings at 30PSI. I do that cause with only 7" of up travel higher pressures make for a rough ride on the trail. For 4400 racing that would need to be raised of course!
[QUOTE=JR;13666387]:laughing: You know, Ifs is kinda like a vagine. It's soft,sexy and expensive.[/QUOTE]
Blase is offline   Reply With Quote Quick reply to this message
Old 10-14-2010, 07:08 PM   #6 (permalink)
mobil1syn's Avatar
Member # 9795
7" is plenty of uptravel. Air bumps are for hard hits not to make up for lack of compression valving. Destroke the bumps and add some compression valving.
The most travel you'll realistically see out of a solid front axle is 16". 8" of uptravel unless you got something crazy going on or waant a sky scrapper.
Quality or quanitiy when it comes to travel.
Old 10-14-2010, 09:11 PM   #7 (permalink)
Member # 127190
thanks guys , reason i asked is because at 150lbs when the bump stops hit it jarred the truck pretty bad
at 50psi much smoother and what i was looking for
