6.0 build tech in Chit Chat..... - Page 39 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-13-2016, 06:11 PM   #951 (permalink)
Member # 49232
Send a message via Yahoo to Camarogenius
Every plug to the engine, yes. The chassis, no.
Camarogenius is offline   Reply With Quote Quick reply to this message
Old 02-13-2016, 06:13 PM   #952 (permalink)
WHEEEEEEEEEE!
gavan's Avatar
Member # 22597
Send a message via AIM to gavan
A lot of our ambulances baked the wiring harness and had random electrical issues. I would say probably a third or more of our trucks ended up with a partial or full replacement harness at some point in time. Lots of idle time and lots of hard running brings issues. But the vans have a much tighter engine bay.
gavan is offline   Reply With Quote Quick reply to this message
Old 02-13-2016, 06:15 PM   #953 (permalink)
drydocker's Avatar
Member # 34052
Great idea. Make a fake Pirate account for your wife. Make it look like she's so into you, that she will follow you down the rabbit hole of 6.0 ownership. I am no CG hater, but anyone that believes a high-dollar vehicle project will somehow magically become something other than just that, is fooling themselves. Add the whole 6.0 aspect, and it becomes sickening. The money and time that has been pissed into this thing could have been spent on a nice DD for the spouse, and a decent work truck for the Man of the house.
drydocker is offline   Reply With Quote Quick reply to this message
Old 02-13-2016, 06:36 PM   #954 (permalink)
Member # 106178
Have you verified fuel flow to the heads?
takotruckin is offline   Reply With Quote Quick reply to this message
Old 02-13-2016, 06:42 PM   #955 (permalink)
Damn kids
plym49's Avatar
Member # 162771
Originally Posted by Camarogenius View Post
The basic harness is original, I put new glow plug harnesses on it.
Yes, it has over 1/2 tank of new, clean fuel in it. I quadruple checked all the grounds, cleaned the hell out of them, and even added a couple extra. (I've been bitten in the ass by a bad ground before. Living in the rust belt for awhile taught me the grounding lesson.)
Have you checked pin to pin continuity of the various harness runs, including flexing the harness while doing so?
Something might have been pinched or perhaps it's just some place inside where you are getting an open or a line to line fault.
Separately I am not a 6.0 guru) can you confirm fuel pressure at the rail when the motor refuses to run?
plym49 is offline   Reply With Quote Quick reply to this message
Old 02-13-2016, 06:43 PM   #956 (permalink)
Member # 3132
did you see what the oil changes are supposed to be for trucks that idle a lot? since there is a tsb, it makes it ok....
does anybody make a kit that gives the injectors a stand alone oil system? I really do not think sharing with the crank case should have ever been ok.
I have one i just took out of service, not very many hours, i think i posted them here earlier, and 159k, a 2008 medtech.....engine 2k after "bullet proofing (you know fixing it and making the wife think it was for the better)"
Even the 2003 6.0's made it longer. I think i have an 06 coming in running/leaking oil condition. maybe i will keep camarogenious in mind while the chassis is sitting in the back lot after it's remount onto a 2016 chassis with a v10. that v 10 wants to light up the tires wit 14k pounds to haul.
Old 02-13-2016, 06:44 PM   #957 (permalink)
gbkeith's Avatar
Member # 183978
Originally Posted by TireFryerSS View Post
Ive throw away more money for worse. Im sure all of you have as well.
Shit, most of us are heterosexual. The PBB has collectively pissed away millions of dollars without so much as a dana 60 and 10.50 sterling sitting in the driveway to show for it.
gbkeith is offline   Reply With Quote Quick reply to this message
Old 02-13-2016, 06:44 PM   #958 (permalink)
Member # 125480
Sounds a lot like your timing is off. Did you put a scope on the CMP sensors and CKP sensors to verify sync at the sensor level (not what the PCM sees) and compare that to a known good set of waveforms? Disabling the glow plugs and hitting it with ether should get it to start. If your HPOP is at spec via the ICP sensor then your high pressure oil should be there to actuate the injectors. Buzz test of the injectors is ok right?
It's got to be timing.
909wheeler is offline   Reply With Quote Quick reply to this message
Old 02-13-2016, 06:49 PM   #959 (permalink)
Member # 49232
I have two fuel pressure gauges. One mechanical, under the hood, and one electric in the cab. Both are downstream of the engine, (There is no crossover, so fuel is definitely going through the fuel rails.)
The harness is a very real possibility.
Old 02-13-2016, 07:25 PM   #960 (permalink)
WHEEEEEEEEEE!
gavan's Avatar
Member # 22597
We changed it 2500-3000 miles. That's a lot of oil!
Old 02-13-2016, 07:28 PM   #961 (permalink)
Member # 49232
I run full synthetic, and change every 5,000.
Old 02-13-2016, 07:50 PM   #962 (permalink)
Member # 3132
Lifted ford's are easier. Slide a keg bucket underneath.
Old 02-13-2016, 07:57 PM   #963 (permalink)
WHEEEEEEEEEE!
gavan's Avatar
Member # 22597
4 gallon pickle bucket slides under the ttb front
Old 02-13-2016, 08:36 PM   #964 (permalink)
A_G
A_G's Avatar
Member # 118487
Same on both accounts for my company
Vagina advice number 1...never invite crazy into your home
Vacancy (daytona coupe, 66 charger, cougar eliminator)
1967 F250: Restomod
1998 f150 reg cab, swb, 4x4 5.4
2013 Yamaha fz8
2015 jetta
And 2 more
A_G is offline   Reply With Quote Quick reply to this message
Old 02-13-2016, 09:08 PM   #965 (permalink)
TrailTamer XJ's Avatar
Member # 140878
Disable your glow plugs if that'll make you feel better and see if it will run on ether. This is similar concept as to add some fuel in the tank to ensure there's fuel in the tank. If it's a no go then chances are no/insufficient compression.
TrailTamer XJ is offline   Reply With Quote Quick reply to this message
Old 02-13-2016, 09:25 PM   #966 (permalink)
Member # 84067
Has cummins swap ever been mentioned in this thread?
moggie is offline   Reply With Quote Quick reply to this message
Old 02-13-2016, 09:33 PM   #967 (permalink)
Member # 94825
Well, on the upside, you haven't spent a lot on oil.
[QUOTE=1TON73K5;14686609]Like you have ANYTHING to say with a avatar like that. Pig.[/QUOTE]
RedPurdueYJ is offline   Reply With Quote Quick reply to this message
Old 02-13-2016, 09:44 PM   #968 (permalink)
dieselboy740's Avatar
Member # 168108
Make sure your connectors are fully seated on you ficm. They can be a bitch at times. Also make sure you put the ground wire back on the back stud on the drivers side intake.
I didn't go back and read through that much so I could be just blurting out things.
'97 f-250 7.3, project, 3 link front, 4 link rear, back halved, fox co/bypasses/bumps, etc....
'08 f350 cclb 4x v10
'93 Volvo 940 fake rally car #trophyvo
dieselboy740 is offline   Reply With Quote Quick reply to this message
Old 02-13-2016, 09:51 PM   #969 (permalink)
Member # 96185
I run full synthetic, and plan to change it every 5,000 if I ever get there.
Fixed it for you.
Sent from AutoGuide.com Free App
[QUOTE]I haven't went from aroused to disappointed so fast since I lost my virginity[/QUOTE]
Midwestzj is offline   Reply With Quote Quick reply to this message
Old 02-13-2016, 10:46 PM   #970 (permalink)
Hophead
Joe_W's Avatar
Member # 4829
Send a message via AIM to Joe_W
That is his wife, CG is a pretty lucky guy
for a nan-hater, you sound a lot like a hater
Sure, there are 49 other states in the Union, but they are smaller, wussier, and the people talk funny.
Originally Posted by Muddin
The vagina doubles as a neat little fanny pack.
Joe_W is offline   Reply With Quote Quick reply to this message
Old 02-14-2016, 02:57 AM   #971 (permalink)
drydocker's Avatar
Member # 34052
I deal with people like CG all the time. Nice people, well intentioned people, who should never pick up a wrench. They ignore the advice of people who would have saved them time/money/aggravation. It takes a special disease to navigate the set of problems that professional vehicle repair/modification/maintenance brings.
Old 02-14-2016, 04:02 AM   #972 (permalink)
Member # 118035
$14k would've paid for a Cummins swap and had an extra $7k left over
I haven't looked into the dog laws....except for the one about fucking them.
IEATRKS84 is offline   Reply With Quote Quick reply to this message
Old 02-14-2016, 04:16 AM   #973 (permalink)
Member # 3935
A wise man doesn't need advice.
A damn fool does not heed advice.
southernfriedcj8 is offline   Reply With Quote Quick reply to this message
Old 02-14-2016, 04:17 AM   #974 (permalink)
Member # 3935
He could have cranked a 12V on the ground with a screwdriver and a battery.
https://www.youtube.com/watch?v=ZXEyxtDTNyE
Old 02-14-2016, 09:50 AM   #975 (permalink)
Member # 74407
Maybe if he used a shitass 12v, but I doubt it. There was a thread in the tow rig forum where a guy swapped in a common rail into an 08 F250 for a customer and the end price was 14k iirc.
And in the end, his setup will make more power.
https://www.pirate4x4.com/forum/38826018-post1418.html
TireFryerSS is offline   Reply With Quote Quick reply to this message
