bad things to say about the HD 8.1L vortec Chevy BB? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-19-2015, 08:16 PM   #1 (permalink)
trampas's Avatar
Member # 5433
Sits in a 2001 Silverado HD 2500 with only 16,000 miles on her.
What could it fetch / i don't have experience with a 496cid Vortec block.
Seriously good deal here? Clean longbed in white with super low miles. No other options besides the 8.1L which i believe WAS an option in Chev HD's before it was dropped in 2009. It made Class A motorhomes happy for roughly a decade..?
What are we supposed to do with nature, just stare at it? Is it like porn with leaves?
:Philipoff2:
trampas is offline   Reply With Quote Quick reply to this message
Old 08-19-2015, 08:22 PM   #2 (permalink)
Member # 49232
Send a message via Yahoo to Camarogenius
Subscribing. I've often thought of this motor in a 3rd gen or a 2nd gen.
Camarogenius is offline   Reply With Quote Quick reply to this message
Old 08-19-2015, 08:26 PM   #3 (permalink)
rockbuggy84's Avatar
Member # 45202
Depending on the transmission, you could have a badass setup for a swap.
Edit; from what I just read, all autos were allisons.
"Whiskey is cheap, Talk cost money"
rockbuggy84 is offline   Reply With Quote Quick reply to this message
Old 08-19-2015, 08:27 PM   #4 (permalink)
Gravity Works!
Landslide's Avatar
Member # 25608
Last of the gm BB's. They are a badass powerplant but a little on the piggy side weight wise so most people are running SB's. It's other bad habbit is crappy fuel milage.
Peg Leg Fab Lab
Landslide is offline   Reply With Quote Quick reply to this message
Old 08-19-2015, 08:27 PM   #5 (permalink)
Member # 102467
Powerful, reliable motor. 200k easy with basic maintenance. 10-13 mpg on a good day.
Bit of a bastard motor, not a ton of aftermarket support.
The party told you to reject the evidence of your eyes and ears. It was their final, most essential command.
I much prefer the sharpest criticism of a single intelligent man to the thoughtless approval of the masses - Johannes Kepler
LigBoozer is offline   Reply With Quote Quick reply to this message
Old 08-19-2015, 08:34 PM   #6 (permalink)
trampas's Avatar
Member # 5433
Originally Posted by Landslide View Post
crappy fuel milage.
No worse than my 7.4L is now with 136,000 on the clock. I get 12~13 on good day.
:Philipoff2:
Old 08-19-2015, 08:42 PM   #7 (permalink)
Member # 102467
Well, I've heard reports of more than eleven, but they lie.
Old 08-19-2015, 08:47 PM   #8 (permalink)
Member # 148982
My ex grandpa in law has one. He's had it since brand new and it's still a beast. And it gets used everyday on a farm. No major problems that he's ever told me.
Pat McRotch is offline   Reply With Quote Quick reply to this message
Old 08-19-2015, 08:47 PM   #9 (permalink)
Member # 113619
Send a message via Yahoo to stjames151
2002 suburban 2500 w 8.1 and Allison, 250k from the factory with no probs. The only down side is the shitty mileage and 2+gal of oil for a change. So far it seems like you could put together a story that could come from cummins guy....but it's only a quarter million miles so far
[QUOTE=Roc Doc;11597106]This is so weak it makes Richard Simmons look like he's UFC ready.[/QUOTE]
[QUOTE=ironpig70;13786791]But it renforces the point to kids guns are toys.[/QUOTE]
stjames151 is offline   Reply With Quote Quick reply to this message
Old 08-19-2015, 08:55 PM   #10 (permalink)
trampas's Avatar
Member # 5433
So, is this worth $6k
3/4 ton longbed, atx, 2001, 16,671 miles.
:Philipoff2:
Old 08-19-2015, 08:56 PM   #11 (permalink)
trampas's Avatar
Member # 5433
It's possible, remotely possible... i could get it for $4500
:Philipoff2:
Old 08-19-2015, 08:57 PM   #12 (permalink)
Member # 203479
Yes.
Toyota.
83' Pickup 4WD,81' Pickup 4WD,92' Pickup 2WD
UndefinedTaco is offline   Reply With Quote Quick reply to this message
Old 08-19-2015, 09:00 PM   #13 (permalink)
dieselboy740's Avatar
Member # 168108
That isn't sound images truck is it? (Customer of mine in Escondido that has a very similar truck with low miles)
'97 f-250 7.3, project, 3 link front, 4 link rear, back halved, fox co/bypasses/bumps, etc....
dieselboy740 is offline   Reply With Quote Quick reply to this message
Old 08-19-2015, 09:03 PM   #14 (permalink)
trampas's Avatar
Member # 5433
It's in Sunnyvale, Ca.
No interior pics tho.
:Philipoff2:
Old 08-19-2015, 09:08 PM   #15 (permalink)
Member # 19666
I freaking hate gm's with a passion and even I would be over there cash in hand right now for that.
QUOTE=gbkeith
Compassion has a maximum effective range of what, zero fucking meters?
ImNotRight is offline   Reply With Quote Quick reply to this message
Old 08-19-2015, 09:11 PM   #16 (permalink)
Member # 52361
I think it'd be hard to not buy it for the miles alone
PROJECTJUNKIE is offline   Reply With Quote Quick reply to this message
Old 08-19-2015, 09:12 PM   #17 (permalink)
Member # 41
I have a 2001 Suburban 8.1. Nearly impossible to destroy. I towed 10k up the grapevine in 104 degree weather with a cracked radiator. Did not overheat.
mpg is 11 highway empty, 10.5 city, 7 towing 10k
For someone who needs heavy towing capability but not too many miles they are great. If I was towing 10,000 miles a year, the mpg would be a huge factor.
Mine has the 4l80e. Stock has a tiny trans cooler, so I modified the radiator support and put in a ford 6.0 diesel trans cooler that is about 10 times bigger. Brought my towing trans temps down by 15-25 degrees. Hottest I ever see now is about 215 going up a long grade.
a little quirky with the crank position sensor, as it takes a bit of work to change, and the cam position sensor is no longer produced, but they can be retrofitted to the newer style.
82FB is offline   Reply With Quote Quick reply to this message
Old 08-19-2015, 09:13 PM   #18 (permalink)
trampas's Avatar
Member # 5433
That's what i'm thinking.
The range is $3,000 to $9,000 so it could go up there...
:Philipoff2:
Old 08-19-2015, 09:13 PM   #19 (permalink)
Member # 113619
If you don't take it, I will. Just pm me.
Old 08-19-2015, 09:13 PM   #20 (permalink)
Member # 77434
I've got one in my 2005 work truck and it's been a great engine with two exceptions. One is it uses a quart of oil every 3000 miles. Thats not a huge problem for me though. The other thing I don't like is it developed a bad case of piston slap at about 150,000 miles but its been doing it for years with no problems because of it. It just doesn't sound good. The only repair the engine needed was the oil pan gasket needed replacing at about 190,000 miles. Other then that, the engine has been as reliable as can be. The 5 speed Allison has had zero issues. The truck pulls great when fully loaded in the mountains. The gas mileage is always 9 to 10 in a 10,000 pound truck with a service body on it. It would probably get better mileage on the highway but I never get it on the highway much. It's pretty much all stop and go short trips in the mountains. Since it was new I've ran Amsoil 5-30 full synthetic in it and the oil change light comes on right around 9,000 miles.
If I was you, for $6000 with 16,000 miles on it I would take it in a second.
-Mike- is offline   Reply With Quote Quick reply to this message
Old 08-19-2015, 09:14 PM   #21 (permalink)
Member # 192237
decent deal
<- another one not so hot on IFS GMs
big plus if it has a manual shift t-case and base model interior (heater controls die, I would never want to own a dual zone pile of shit)
Old 08-19-2015, 09:16 PM   #22 (permalink)
trampas's Avatar
Member # 5433
Good to know. I'm running around in a 454 gasser with the 4L80E and i love it. Don't know which auto this 01 has.
:Philipoff2:
Old 08-19-2015, 09:22 PM   #23 (permalink)
Stingray's Avatar
Member # 175675
8.1
I have one in a boat, 10 years old, 450 hrs. runs great, and if I keep it below 3k on the tach. it's good on fuel.
As far as a truck............... I got nothing to add
But if one came up, I wouldn't be afraid to buy it.
4Runners in the yard--85 Trail Rig
96 Limited My daily----2001 2wd Wife's Daily
Stingray is offline   Reply With Quote Quick reply to this message
Old 08-19-2015, 09:25 PM   #24 (permalink)
Member # 102467
Only suburbans had the 4l80e, trucks were Allison 1000.
I think.
Old 08-19-2015, 09:34 PM   #25 (permalink)
Not a Wenzelite
MT4Runner's Avatar
Member # 44480
Vortec 8100 8.1L Chevy GM Performance Parts - 496MAG / 496MAG HO Marine Performance Parts - Raylar Engineering
MT4Runner is offline   Reply With Quote Quick reply to this message
