Need a 220/110 to 12v 10a power supply - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-19-2015, 09:28 AM   #51 (permalink)
Fistful of Boomstick
usmcdoc14's Avatar
Member # 13344
Send a message via AIM to usmcdoc14 Send a message via Yahoo to usmcdoc14
Originally Posted by Realsquash View Post
OK smartass, I'm trying to help. The power supply you bought was 10 amps, it says so right on the side in the ebay ad. But somehow you smoked it testing an LED? How did you connect the LED to "test" this power supply? Either way, it was underrated for your fridge. The one I posted lets you choose the correct amperage (go higher than needed) and they even ship to BFE.
Or, maybe you can post a photo of the transformer inside where you connect the 220vac up. Chances are very good that you can simply rewire the transformer for 110vac and get on without spending another dime.
If that doesn't work then you could probably just replace the transformer inside the unit with one that has primary connections for 110 and 220v, and even wire up a switch to it (eghads!).
sorry, kinda jaded on the chicom power supplies after waiting a month for it to get here and it did that. My mailing addres is not an APO, its a US embassy adress that send out mail via embassy courier...IE fucking slow
Yes, it was a test run using a 12v LED indicator light. Light went on, then the capacitor blew and caught fire.
Originally Posted by trackerbacker View Post
Now, this may sound silly if it's been covered or tried. But very brief search shows 240v 50hz for uganda, is that what you are running?
My brevity didn't look into if it's 240 2pole breaker like USA or if it's 240 single pole breaker. Any chance that could be your issue and if your equipment isn't enjoying 50hz as well.
only certain things dont like 50hz. Tomorow I am going to Kampala and looking for a "REAL" computer place and get a "REAL" power supply....with a fucking switch that says 110/220
we will see how that pans out
The fucking fridge is PIMP with its new digital control, shit even added a USB port for charging. Pics later.
Doc-14 Tactical Products:
When it absolutely, positively needs to be made from random crap found in the back of my garage.
usmcdoc14 is offline   Reply With Quote Quick reply to this message
Old 11-19-2015, 10:56 AM   #52 (permalink)
Member # 193950
That or find someplace that will sell you one for a server (perhaps from a server that was replaced?)...
Aaron Z
aczlan is offline   Reply With Quote Quick reply to this message
Old 11-20-2015, 08:49 AM   #53 (permalink)
Apple
makya's Avatar
Member # 41250
Jesus Christ you girls can bicker.
Doc, if you don't find what you need, let me know. I have a converted psu I will send you. It's only rated at 14a @12v, but I know it works since I use it for powering my rc car chargers through the banana plug outputs on both 12v and 5v and it does have an external 115/220 switch.
makya is offline   Reply With Quote Quick reply to this message
