Hey CG, 6.0 Powerstroke head gasket leak - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-08-2016, 05:11 AM   #26 (permalink)
Damn kids
plym49's Avatar
Member # 162771
All these 6.0 threads remind me how enjoyable it is, by comparison, to rub gravel in one's eyes.
plym49 is offline   Reply With Quote Quick reply to this message
Old 03-08-2016, 05:22 AM   #27 (permalink)
Member # 198851
Originally Posted by HUSSLR187 View Post
High Pressure Oil Pump HPOP is what they're talking about on your friends truck. No oil pressure in hpop = injector don't spray fuel
EDIT: beat by one minute
So the injectors and or injection pump is lubed by a separate oil pump using engine sump oil and not lubed by Diesel? Is this common on newer Diesels? My Diesel experience is old stuff.....
ADChevy4x4 is offline   Reply With Quote Quick reply to this message
Old 03-08-2016, 05:32 AM   #28 (permalink)
Member # 66677
My google fu skills are lacking but it's easier than typing everything out
HEUI - How High-Pressure Oil Injection Systems Work - Diesel Power Magazine
[QUOTE=Rooney77;14997648]We choose not to ignore you because we choose to "cleanse" our beloved PBB of as much ignorance as possible. I'm sure having klansmen in your heritage you can understand the mentality. You are the jew of the PBB. Look in you e-yard, that's our cross burning.[/QUOTE]
HUSSLR187 is offline   Reply With Quote Quick reply to this message
Old 03-08-2016, 06:13 AM   #29 (permalink)
Member # 12499
Other than injectors (which was the fault of Pilot Truck Stops fuel, not the truck) my 6.0 is humming right along and I couldn't imagine not having it.
Mileage isn't as good as my old IDI and I'm not willing to pour spent parts washer solvent or used engine oil in the fuel tank, but the transmission is one Helluva lot better than the IDI.
If you maintain a 6.0, drive it hard once in a while, and don't let it sit excessively, you'll be fine.
PTSchram is offline   Reply With Quote Quick reply to this message
Old 03-08-2016, 07:10 AM   #30 (permalink)
Member # 49232
Send a message via Yahoo to Camarogenius
The 03- early 04's used a different type of HPOP. It's known to go out from time to time. There are aftermarket pumps that don't have issues.
Since I was changing engines, I solved the problem by going with an 05 engine with the new style HPOP. New style lasts forever.
Camarogenius is offline   Reply With Quote Quick reply to this message
Old 03-08-2016, 07:13 AM   #31 (permalink)
FoMoCo MoFo
Totalled's Avatar
Member # 79002
Location: My little kingdom of awesome. Near Olympia, Thurston county, Wa
Especially when it doesn't run.
Tarped lawn art: 1985 BroncoII Eddie Bauer. V8/Automagic/Locked/MTRs.
I want everyone to have everything. I want gays to be able to fuck each other in the ass, in the middle of a field of weed while shooting pistols in the air like yosemite sam shouting that there is no god.
Totalled is offline   Reply With Quote Quick reply to this message
Old 03-08-2016, 07:59 AM   #32 (permalink)
Member # 198851
My friend's truck is an 05 he bought new...Forever was 10 years and 160,000 miles...
Old 03-08-2016, 08:07 AM   #33 (permalink)
Member # 44159
Most of the time it was the old two piece STC fitting that failed, not the actual pump and it was usually around 150K miles.
pb4u4x4 is offline   Reply With Quote Quick reply to this message
Old 03-08-2016, 08:28 AM   #34 (permalink)
Member # 137692
05 was a funny year, at least for my January build date truck.
I would occasionally have to reference '04 information to find what I needed.
75' Forty is offline   Reply With Quote Quick reply to this message
Old 03-08-2016, 08:29 AM   #35 (permalink)
Member # 44136
I'm diesel stupid. I'm assuming that is for diesel, not engine oil right?
Snowbird13 is offline   Reply With Quote Quick reply to this message
Old 03-08-2016, 08:48 AM   #36 (permalink)
Member # 19500
Think of it as a hydraulic pump that uses engine oil for the hydraulic fluid.
The injectors are hydraulically actuated, which is how they eliminated the traditional injection pump the old diesels had. Each injector has an electric solenoid, that then uses hydraulic pressure to inject the diesel duel at extremely high pressure.
OverThrottle is offline   Reply With Quote Quick reply to this message
Old 03-08-2016, 09:13 AM   #37 (permalink)
Member # 31422
Send a message via AIM to tmacie
In light duty engines, only ford uses this type of injection. Dodge and Chevy use a CP3 pump which does not use engine oil to function.
That is way over simplified, but answers the question.
tmacie is offline   Reply With Quote Quick reply to this message
Old 03-08-2016, 09:41 AM   #38 (permalink)
Member # 19500
Not sure about others, but the International / Navistar 7.3 uses hydraulic injectors with a HPOP as well.
Old 03-08-2016, 09:50 AM   #39 (permalink)
Member # 31422
Yes, because its the same motor. I was leaving out mid/heavy trucks for confusion sake, but Ford light diesel motors were sourced from Navistar until the 6.4.
Old 03-08-2016, 09:51 AM   #40 (permalink)
Member # 198851
I assume they are using the high high pressure direct injection ? What do the European and Japanese use?
Old 03-08-2016, 10:11 AM   #41 (permalink)
Member # 49232
500 to fix sounds more like the STC fitting. I'd recommend swapping them out good or bad, if it's the old 2 piece style. Depending on HPOP pressure when they fail, they can crack the rear engine plate. That causes an oil leak that requires the engine to be pulled, and disassembled to fix.
Old 03-08-2016, 10:15 AM   #42 (permalink)
No
Filthy McChevy's Avatar
Member # 106663
Might as well ask the Janitor at a Hospital about surgery you're contemplating.
Durrhh.
Filthy McChevy is offline   Reply With Quote Quick reply to this message
Old 03-08-2016, 10:26 AM   #43 (permalink)
Member # 198851
Hmm, I think CG is reasonably well informed on this stuff................
Old 03-08-2016, 10:52 AM   #44 (permalink)
Member # 19500
Maybe, but we sure as hell don't need it going to his head. Before you now it he will be petitioning the mods to change his username to CamaroAnd6OhGenius.
Old 03-08-2016, 10:56 AM   #45 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
.......on how to build the ever living shit of non running engine's.
Old 03-08-2016, 10:57 AM   #46 (permalink)
45acp's Avatar
Member # 13671
External only? Quart of coolant a week? I would let that bitch keep on keepin' on. Hell it's spring. Go get a couple gallons of distilled and dump one in each month. Switch back to dumping in AF in november.
45acp is offline   Reply With Quote Quick reply to this message
Old 03-08-2016, 11:12 AM   #47 (permalink)
Member # 44136
He has one of these trucks, and has spent the last 6 months and thousands upon thousands of dollars trying to make this POS work. Now it's in someone elses shop. Sounds like an expert to me.
Old 03-08-2016, 12:25 PM   #48 (permalink)
Member # 133009
Seriously. I'd wait until it gave me a damn good reason to take all of that apart, it's not like you'd have to wait very long.
86 Zook. Links are for websites.
DirtRoads is offline   Reply With Quote Quick reply to this message
Old 03-08-2016, 12:32 PM   #49 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
Originally Posted by TireFryerSS View Post
We have a forum for this...
And this is it...
& Blaine
:tank:
Beat95YJ is online now   Reply With Quote Quick reply to this message
Old 03-08-2016, 01:11 PM   #50 (permalink)
Member # 198851
I can't speak for his skills or lack of skills but it's easy to criticize what someone else is doing...But this forum being what it is you gotta expect some harassment
