Stop hurting your engine by 'warming up' the car when it's cold out - Page 6 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-23-2016, 10:40 PM   #126 (permalink)
Member # 66677
My truck can idle all winter and still be on the cold mark; I have to drive it to warm it up and if it's cold enough I can watch the gauge fall at a stop light
[QUOTE=Rooney77;14997648]We choose not to ignore you because we choose to "cleanse" our beloved PBB of as much ignorance as possible. I'm sure having klansmen in your heritage you can understand the mentality. You are the jew of the PBB. Look in you e-yard, that's our cross burning.[/QUOTE]
HUSSLR187 is offline   Reply With Quote Quick reply to this message
Old 01-23-2016, 11:31 PM   #127 (permalink)
Member # 125480
you have thermostat issues. It's stuck open. Nothing to brag about since you're stuck in open loop longer and you waste more fuel for no reason beyond well.. it's a new year so I'll try to be nice.
909wheeler is offline   Reply With Quote Quick reply to this message
Old 01-23-2016, 11:36 PM   #128 (permalink)
Member # 139150
Originally Posted by FordFascist View Post
That's completely untrue, try again. Or maybe you'd like to be coy and use a one-word response again.
Cold-running engine strategies retard the ignition timing while initially driving putting additional heat in the exhaust / cooling system. This causes the temperature to rise significantly in the emissions systems and warms the engine quicker - however none of these strategies are in use when the engine is idling and the vehicle is not moving.
In fact if you look in most new cars owners manuals they will say not to idle the engine for extended periods in cold weather. But you guys are right, PBB mechanics know more than the engineers who designed the engines and emissions systems.
no.
[COLOR="red"](input truck specs here to prove level of badass and gain Pirate street cred)[/COLOR]
[COLOR="Red"]<< post picture of badass pirate approved truck doing some epic wheeling[/COLOR]
sjracer is offline   Reply With Quote Quick reply to this message
Old 01-23-2016, 11:48 PM   #129 (permalink)
Member # 125480
...could...not...resist...
Old 01-24-2016, 12:03 AM   #130 (permalink)
Member # 328810
Agreed. My 7.3 warms up just as quick as any gas motor. When I bought it it had no thermostat, It never got to operating temp unless I was towing for a while.
There was however a thread here somewhere where canadians were discussing the fact that the new diesel jettas were unable to warm up in ridiculously low temps.
JKTweak is offline   Reply With Quote Quick reply to this message
Old 01-24-2016, 12:25 AM   #131 (permalink)
JediJesus's Avatar
Member # 132056
If I don't warm up one of the Italian engines it will destroy itself before 2500 rpm. I've pulled a fresh rebuild, with about 2k miles, apart that the guy didn't let warm up and bearings are shot, pistons are torched, cylinder walls are scored to shit, etc. We had to show him how the choke works
As for my own stuff, depends on the car/bike, I let bikes warm up to just about operating temp, the Toyota I let warm up for about a minute then don't shift above 2500 for a few minutes.
And yes, I do so with the engine life in mind, I don't want to be replacing bearings every 20k miles
JediJesus is offline   Reply With Quote Quick reply to this message
Old 01-24-2016, 12:32 AM   #132 (permalink)
Member # 125480
what italian engine is that? Carb or EFI? What part of th Earth is this where an engine designed on Earth cannot idle after being started?
Old 01-24-2016, 01:08 AM   #133 (permalink)
JediJesus's Avatar
Member # 132056
Alfa Romeo aluminum, with sleeves, 1300 and 1600 with either dual side draft Webers or a single Solex from the 50s and 60s typically. Where did I say they won't idle? Never heard of EFI w a choke either, pay attention. They don't run for shit until warm, and they'll blow head gaskets if ran too hard too quick.
Or the early Ferrari v12s with three two barrels, they're a little easier on start up but they need to be warmed up too.
Old 01-24-2016, 01:09 AM   #134 (permalink)
Member # 66677
Thermostat works. I had to flush the system last year when it was cold and it took about a half hour of driving to get the t-stat to open up so i can put the rest of the anti-freeze in. Its a 7.3 it starts and does everything else fine but maybe my definition of cold is lower than yours
Old 01-24-2016, 01:19 AM   #135 (permalink)
Member # 125480
So old carbureted Italian shit. No O2 sensors, no fuel trim and no real business in this thread rather than bragging that you work on Ferraris YET AGAIN!
Got it.
We get it, You change oil on Ferraris. ...old Ferraris.
Good job kid!
Old 01-24-2016, 01:22 AM   #136 (permalink)
JediJesus's Avatar
Member # 132056
So old carbureted Italian shit. No O2 sensors, no fuel trim and no real business in this thread rather than bragging that yopu work on Ferraris again.
Got it.
Good job kid!
You asked lol
If you wanna talk about new stuff, pretty much everything has o2 sensors and a computer so the whole thread is irrelevant
Old 01-24-2016, 01:27 AM   #137 (permalink)
Member # 125480
You asked lol
No genius. The OP topic was about MODERN VEHICLES and warming up.
Doesn't matter though.
I'm sure Ferrari made backpedaling better too!
... it just one more pedal right?
Old 01-24-2016, 01:32 AM   #138 (permalink)
JediJesus's Avatar
Member # 132056
Wtf got into your panties tonight?
Old 01-24-2016, 01:38 AM   #139 (permalink)
Member # 125480
Nothing. You just seem to like to drop the "Ferrari Bomb" on a bunch of auto threads (this guy works on Ferraris so I shouldn't mess with him) and you are surprised I called you on one. I asked you a question. Are you going to answer it?
Old 01-24-2016, 01:55 AM   #140 (permalink)
JediJesus's Avatar
Member # 132056
I haven't dropped a "Ferrari bomb" in a long time here, but I'm sorry I share my experience with the group. I'll stop, don't want to come across like I'm trying to intimidate anyone. Sounds like the only one thinking that is you though...
Which question is that? The pedal question? Lol calm down buddy
Old 01-24-2016, 01:58 AM   #141 (permalink)
Member # 43837
Sweet. I dropped the forklift bomb and no one shit all over me.
He works on Chevrolets.
RIP SPRING CREEK OFF ROAD
bigbroncojeff is offline   Reply With Quote Quick reply to this message
Old 01-24-2016, 02:02 AM   #142 (permalink)
Member # 125480
I'm, calm. It's all good.
Old 01-24-2016, 02:03 AM   #143 (permalink)
Member # 125480
About that... fuck you and your uppity Hyster shit. I've heard just about enough about Hyster.
Old 01-24-2016, 02:06 AM   #144 (permalink)
Member # 43837
Hyster lol. I deal with em... but thank god I dont deal with em much.
Old 01-26-2016, 11:55 AM   #145 (permalink)
Member # 88383
Originally Posted by Filthy McChevy View Post
I warm up my 73 K30 plowtruck with a 454 and a manual choked 750 doublepumper or it dies 2 or 3 times. I warm up my 77 Jimmy with a manually choked quadrajet because the power steering belt squeaks like a mofo if I don't, but they aren't DDs by any means. They do both fire right up no matter how cold it is, which is a very good thing. If there is not ice on the windshield of my FI 88 Ranger I hop in and go. It is my DD.
yeah my k30 is the same way, itll start up and idle but wont really go anywhere til its warmed up.
interesting to see how many people do warm up their vehicle for engine life i thought everyone just did it cause they didnt want to be cold themselves.
Since you perverts have a billion porn videos posted in the TP, I've disabled the function in the TP. It works everywhere else.
abig84 is offline   Reply With Quote Quick reply to this message
Old 01-26-2016, 01:17 PM   #146 (permalink)
Member # 18433
Yea no shit!
All the diesel airport equipment i worked with/on we idled them all winter because it was such a bitch to get it started in the first place that we were afraid it would never start again if we shut it off!! It was a cornucopia of military surplus equipment and old airline equipment 20yrs past the end of its usable life.
Ill join in with ferrari boy on the one upping and mention that a lot of small turbo prop aircraft you have to start and warm them up to check the oil level
2002 Tacoma, duals, flipped fj60 front axle, fj80 rear axle, 37s, not cool enough for links.
Gslander is online now   Reply With Quote Quick reply to this message
Old 01-26-2016, 01:22 PM   #147 (permalink)
Member # 627858
Whatever. i'm warming mine up.
CalypsoNotch is offline   Reply With Quote Quick reply to this message
Old 01-26-2016, 01:57 PM   #148 (permalink)
Need an LS
Kurtuleas's Avatar
Member # 23188
"Before 1980, carburetors were the heart that kept car engines pumping.
From the 1980s onward, however, electronic fuel injection took over and is still what powers today’s car engines
Huh. I guess no one told Jeep that.
My 1990 is carbureted.
I am stuck warming my junk up.
KEEP PUBLIC LANDS OPEN TO THE PUBLIC
Kurtuleas is offline   Reply With Quote Quick reply to this message
Old 01-26-2016, 03:46 PM   #149 (permalink)
Member # 88705
I let mine idle for 60 seconds or so because I don't like pulling out of the driveway at 1500rpm, a bit hard on the clutch. Its a 2010 so it's chock full of emissions shite.
Syncros is offline   Reply With Quote Quick reply to this message
Old 01-26-2016, 05:20 PM   #150 (permalink)
Member # 328810
How cold are we talking? I start my 01 7.3 in 20 degree temps and within 10 minutes of idling and 2 miles of very light driving my heater is blasting.
