Ford 6.4 oil in intake. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-16-2016, 10:37 AM   #1 (permalink)
Member # 104517
Should I be pulling these turbos out to check them or is this normal? Truck will randomly smoke and clear up over a 1-2 minute period.
08 f550 6.4 auto 50k miles
It needs a water pump gasket. Holy fuck did they cream a ton of shit under this hood.
R.I.P. Jason Payne
chevy_man is offline   Reply With Quote Quick reply to this message
Old 05-16-2016, 10:59 AM   #2 (permalink)
Member # 84067
Are you running it hard enough? Turbo seals will leak oil into the intake, but it'll mostly be a residue if you keep it blown out.
moggie is offline   Reply With Quote Quick reply to this message
Old 05-16-2016, 11:07 AM   #3 (permalink)
Member # 104517
It gets a good amount of idle time running a crane. When it's being driven we run it to the floor at all times since it's a gutless wonder. I started it, dropped it into gear and drive about 100 yards into the shop this morning. It's been sitting for 2 weeks since it was driven last.
R.I.P. Jason Payne
Old 05-16-2016, 11:19 AM   #4 (permalink)
Member # 31384
My 7.3 does the same thing.
My build thread, an 4speed Atlas in a Tacoma
NSW Sparky is offline   Reply With Quote Quick reply to this message
Old 05-16-2016, 11:26 AM   #5 (permalink)
Member # 74407
Are you sure the smoke isn't from it going into regen?
Edit: Btw, you posted this in the waaaay wrong section. I doubt it'll stay on topic and will turn into a shitfest soon enough.
Edit edit: Id almost bet that oil accumulation is from the crankcase vent system.
https://www.pirate4x4.com/forum/38826018-post1418.html
TireFryerSS is offline   Reply With Quote Quick reply to this message
Old 05-16-2016, 11:30 AM   #6 (permalink)
Member # 74407
Crankcase vent causes that. Search for ccv mod for 7.3s on Google
Old 05-16-2016, 12:27 PM   #7 (permalink)
Member # 104517
No big deal. Figured I'd catch some shit soon enough. There is more traffic here during the day.
I was wondering about the crank case vent. Either way I'm not worried about it if it's not too abnormal. This truck has many other problems.
R.I.P. Jason Payne
Old 05-17-2016, 08:43 AM   #8 (permalink)
Member # 104517
So, I'm assuming I should be replacing the water pump housing.... fuck this thing. I'm so glad I didn't go to school for diesel tech right now!
R.I.P. Jason Payne
Old 05-17-2016, 09:11 AM   #9 (permalink)
Member # 49232
Send a message via Yahoo to Camarogenius
That one will survive, but a new housing would be nice. Also, make sure you're running CAT ELC, and add a coolant filter.
As to the oil in the intake, it's the PCV system. Not really that big of an issue.
Camarogenius is offline   Reply With Quote Quick reply to this message
Old 05-17-2016, 09:21 AM   #10 (permalink)
BigGreenMonster's Avatar
Member # 16809
50k on a 6.4! That has to be a record!
GDI4x4
_____________________________________________
BigGreenMonster is offline   Reply With Quote Quick reply to this message
Old 05-17-2016, 10:44 AM   #11 (permalink)
Member # 143307
He's better off taking advice from Hellen Keller on good TV shows.
Fuck that kind of engine service at 50,000 miles. What year is this, 1965? Don't give me shit about service truck life. Chevy 283s were dragging grain trucks around once upon a time.
:homer:
ToughBowtieTruck is offline   Reply With Quote Quick reply to this message
Old 05-17-2016, 10:45 AM   #12 (permalink)
Member # 49232
Okay, let's just bring in the expert. @Brimmstone What do you think?
OH! And at 50k miles, it would be interesting to know what the engine hours are. If you figure in idle time, that motor probably has a couple hundred thousand equivalent miles on it.
Old 05-17-2016, 11:05 AM   #13 (permalink)
Member # 225201
Nothing that costs that much should require that much maintenance so soon.
I hate the route modern Diesels have gone. I will never own one.
erictylers1 is offline   Reply With Quote Quick reply to this message
Old 05-17-2016, 11:26 AM   #14 (permalink)
Short change$$'s Avatar
Member # 277090
Location: Freedoms just another word for nothin left to lose.
The solution is simple. Jack up the radiator cap and drive a new truck underneath it.
Short change$$ is offline   Reply With Quote Quick reply to this message
Old 05-17-2016, 11:50 AM   #15 (permalink)
larboc@hotmail.com's Avatar
Member # 70148
I think you have to take the cab off to get to the cap. I've heard you can drill a hole in the firewall in a certain spot and do it but I'm not sure.
I don't pay nothing for anything.
larboc@hotmail.com is offline   Reply With Quote Quick reply to this message
Old 05-17-2016, 12:01 PM   #16 (permalink)
jemarshall's Avatar
Member # 50690
Send a message via MSN to jemarshall
Holly shit batman
For this, read this, best/fastest I can find for decent info.
Changing over to Cat ELC Cooling System - Diesel Forum - TheDieselStop.com
Info on this here also. I am doing an EGR/DPF with and full exhaust, intake and mini max to a friend of mines 08 6.4 right now. Scared the shit out of me when pulled the lower hose off of the inter-cooler and it dumped about a quart of oil out on the floor. Was not expecting that at all. To say the least the CCV on his is getting a mod to it too.
Oil Leak from the Intercooler Boot on 2009 F350 6.4 - Ford Truck Enthusiasts Forums
jemarshall is offline   Reply With Quote Quick reply to this message
Old 05-17-2016, 12:58 PM   #17 (permalink)
Member # 49232
Mod it, but don't delete it. I'm not sure what the exact sorcery is, but the rings seem to like having that little touch of vacuum under them.
Look into a slobber bottle.
Old 05-17-2016, 01:09 PM   #18 (permalink)
Member # 200478
That is one of the ways the 6.4 likes to kill itself. Cavitation eats through the housing and lets coolant into the oil.
isbj60 is offline   Reply With Quote Quick reply to this message
Old 05-17-2016, 01:34 PM   #19 (permalink)
Member # 104517
Well, boss decided to gamble on the housing. It's just getting a pump to fix the leak, and cat coolant. I'll check the hours when I get it back together, iirc it was a stupid amount.
I'm guessing this was buried headlight deep in mud at one point. It's been a mess. Broken tow hooks and there was mud packed solid from the intercooler to the fan. I spent about 2 hrs pressure washing all the coolers. Had to chip mud away from the fuel filter cover on top of the motor all idler pulleys replaced because they were sloppy from being packed with mud.
It has a VMAC compressed air system. It took a whole $100 to fix because it needed a tensioner. Previous owner just cut the belt off and said fuck it.
Damn oil field trucks. Run them till they break, then drag them to Richie Bros!
R.I.P. Jason Payne
Old 05-17-2016, 04:14 PM   #20 (permalink)
Brimmstone's Avatar
Member # 177990
Pump housing looks normal. I've seen much worse. Make sure your grounds are solid because that can cause the erosion. Oil in turbo looks like air filter was clogged and turbo pulled a good vacuum on the crankcase. As stated above dropping the lower CAC tube and having a quart or better drain out isn't that strange.
Brimmstone is offline   Reply With Quote Quick reply to this message
Old 05-17-2016, 05:15 PM   #21 (permalink)
Member # 86685
The guy right above me nailed it, change your air filter.
s10er8 is offline   Reply With Quote Quick reply to this message
Old 05-17-2016, 05:16 PM   #22 (permalink)
Green bastard
cslimfu's Avatar
Member # 123458
It'll probably take a cra...
Nevermind, I guess it's covered.
It's a hell of a thing, killing a man. You take away all he's got, and all he's ever going to have.
cslimfu is offline   Reply With Quote Quick reply to this message
Old 05-17-2016, 05:20 PM   #23 (permalink)
Safety third!
Dr.Danger's Avatar
Member # 168243
-Dave
By the way, Irregardless does pass spell check and it is a word. The meaning is exactly the same, you just want to play games
Dr.Danger is offline   Reply With Quote Quick reply to this message
Old 05-17-2016, 05:35 PM   #24 (permalink)
Member # 108445
Seems an odd place to jack off.
rocket flier is offline   Reply With Quote Quick reply to this message
Old 05-17-2016, 06:04 PM   #25 (permalink)
Member # 3132
Says ford.......
