A helicopter is sitting on a large turntable - Page 6 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-17-2016, 04:52 PM   #126 (permalink)
Member # 108006
Originally Posted by Crisbee1 View Post
Hijacks Too...
This thing is badass, counter rotating ridgid rotor and a propulser.
Waiting to get tapped to fly a half scale in the Ames 40x80.
That would require a turntable rotating at a speed such to cause a downforce from the counter rotating blades eqivelant to the upforce from the other rotor while on a treadmill going the same rate as the propulsor.
i know you can't equalize the force as the rotor spinning the same way would continue to increase lift as the turntable spins faster
JunkCJ6 is online now   Reply With Quote Quick reply to this message
Old 05-17-2016, 04:53 PM   #127 (permalink)
Member # 397210
Originally Posted by Haole View Post
And -5 pirate points for bringing up rotor speed relative to the fuselage as a mode for lift.
You fail harder than Narrock.
I did not say it was the mode for lift. I am saying that the thing that is making the rotor turn (effectively the fuselage as the gearbox driving the rotor is fixed to it) is turning just as fast as the fuselage but just opposite. They are dependent on one another and thus they cancel each other out, so the rotor is not moving relative to the ground. It is moving relative to the copter but not to the ground.
Its kind of like how in the movies you see the wagon wheel stop spinning because the rotational speed is the same as the frame rate of the film.
Or like when you run on a treadmill. You are moving forward at some speed and the treadmill is moving opposite it at the same speed. That is why you don't go anywhere.
non-OP is offline   Reply With Quote Quick reply to this message
Old 05-17-2016, 04:54 PM   #128 (permalink)
jpnjim's Avatar
Member # 22209
So the main blades wouldn't be moving in relation to the ground,
but the fuselage will be spinning like a m-fer?
I'm going to go with no.
Keeper of hEEPs
jpnjim is offline   Reply With Quote Quick reply to this message
Old 05-17-2016, 04:55 PM   #129 (permalink)
Member # 108445
But what if you have a fan blowing on you like a headwind?
rocket flier is offline   Reply With Quote Quick reply to this message
Old 05-17-2016, 04:55 PM   #130 (permalink)
Crisbee1's Avatar
Member # 133544
So yes. IF the is rotor is pulling collective and the fuselage is creating lift. And there will be no torque if they are equal
Crisbee1 is offline   Reply With Quote Quick reply to this message
Old 05-17-2016, 04:58 PM   #131 (permalink)
Member # 19077
Originally Posted by Nightshade View Post
Which DJ is manning the turntable?
Z-Trip.
yotamasters.com
Max Volume is offline   Reply With Quote Quick reply to this message
Old 05-17-2016, 05:00 PM   #132 (permalink)
Member # 397210
well you are not rigid relative to your feet, you can bend backwards. If the headwind is enough to overcome your core muscles and cause you to lose balance and fall back, then technically you are moving, but that is not the case where the rotor shaft is rigid to the fuselage.
Old 05-17-2016, 05:11 PM   #133 (permalink)
Haole's Avatar
Member # 5859
The thread is about lift. Rotor speed in the air is lift. Yes, the fuselage of the helo is what's it's turning against.
Unlike Narrock, I can reread your post and see that I misread it. So kiss my Narrock.
Ka 'aina uluwehi, ko kakou
kuleana.
- The lush life-giving land, our personal responsibility.
- Darlington County Chapter
Haole is offline   Reply With Quote Quick reply to this message
Old 05-17-2016, 06:38 PM   #134 (permalink)
SilverZuk's Avatar
Member # 13420
Nope, unless the tail rotor is strong enough to over come the friction of the skids and the turn table.
The penalty for punching someone in the mouth is way too high in our society.
Always take a poison word as a promise.
SilverZuk is offline   Reply With Quote Quick reply to this message
Old 05-17-2016, 06:45 PM   #135 (permalink)
Crisbee1's Avatar
Member # 133544
We get a tail rotor? if we get a Tailrotor that means there will be a gearbox which will be turning at twice it's normal speed, yard sale...
Old 05-17-2016, 06:52 PM   #136 (permalink)
Member # 108445
It's not the french door thread?
Old 05-17-2016, 06:57 PM   #137 (permalink)
Member # 42503
Can we just mount the helicopter upside down and attach the rotor to the ground so we don't have to have a turntable?
Spork is offline   Reply With Quote Quick reply to this message
Old 05-17-2016, 07:09 PM   #138 (permalink)
Haole's Avatar
Member # 5859
That would just be a carnival ride at the fair.
kuleana.
Old 05-18-2016, 07:45 AM   #139 (permalink)
Member # 34987
Originally Posted by DirtyComanche View Post
And you are incorrect on your last point, perhaps. A cyclic input of anything other than neutral would produce the blade quivering effect. A collective input (typically referred to as 'pitch') would not produce this effect, you would simply see the stationary blades move to a high pitch. However, depending on what exact type of rotor system and rotor dampening system was in place, the blades may see some other pitch effects. Aerodynamic forces are also critical in allowing some control operations, and I am sure there would also be some undesirable effects from that.
This shows my ignorance of helicopters. I was talking about changing the angle of the axis of rotation of the main rotor so that it is no longer coincident with the axis of rotation of the turntable.
1 TON SAS'ed C1500 ECSB on 37s
axisT6 is offline   Reply With Quote Quick reply to this message
Old 05-18-2016, 07:50 AM   #140 (permalink)
Screwzer2's Avatar
Member # 38193
Originally Posted by OverThrottle View Post
If same speed but opposite, they should cancel out and the rotor would be motionless.
Spoiler.
Now, if the turntable was spinning in the SAME direction, would it take off twice as fast?
Yesterday is History
Tomorrow is a Mystery
and Today is a Gift
That's why they call it the Present
—Eleanor Rososevelt
Screwzer2 is offline   Reply With Quote Quick reply to this message
Old 05-18-2016, 07:53 AM   #141 (permalink)
Member # 157355
Originally Posted by ev13wt View Post
which turns at the same speed in the opposite direction of the spinning main rotor.
Will it take off?
depends on how idled up the rotor is.
Minimal mech. knowledge, overly ambitious
Pokeman is offline   Reply With Quote Quick reply to this message
Old 05-18-2016, 07:54 AM   #142 (permalink)
Screwzer2's Avatar
Member # 38193
Originally Posted by CrustyJeep View Post
So, there's a tornado in a hurricane spinning the opposite direction. Does Dorothy take off?
No, Dorothy gets blended.
and Today is a Gift
—Eleanor Rososevelt
Old 05-18-2016, 07:57 AM   #143 (permalink)
Screwzer2's Avatar
Member # 38193
Originally Posted by Beat95YJ View Post
It's an idealized test. It could not be done in the real world. The "parameters" are equal and opposite rpm. That's what you need to consider for this round of mental masturbation.
Indeed.
and Today is a Gift
—Eleanor Rososevelt
Old 05-18-2016, 08:11 AM   #144 (permalink)
paragon's Avatar
Member # 40266
Originally Posted by 300sniper View Post
Not the same thing. Not at all.
go look at the physics of twin rotors. if you understand how they work, you can understand why the blades will not be stationary relative to the ground
why do you need a tail rotor or ducted fan on a helo?
besides stability and "steering", it's there to keep the fuselage from spinning which direction?
the main rotor instills small counter-rotational force on the fuselage. the frame reference is the air around (due to create lift). if the main rotor imparts small counter-rotational force on the fuselage, then the reverse must be true. the fuselage has little effect on the rotation of the main rotor. then what is the mechanism or force that keeps the main rotor stationary relative to the ground?
[COLOR="Black"].
[/COLOR]
[CENTER][FONT="Franklin Gothic Medium"][SIZE="4"]"For God and country, Geronimo, Geronimo, Geronimo"[/SIZE][/FONT][/CENTER]
paragon is offline   Reply With Quote Quick reply to this message
Old 05-18-2016, 09:52 AM   #145 (permalink)
300sniper's Avatar
Member # 26382
Engineers be all missin' the entire simple point of the OP by over thinking it....
Edit: fuselage be spinning 500 rpm counterclockwise and the rotor is spinning 500 rpm clockwise in relation to the fuselage, what is the airspeed of the blades?
It's time to switch to whiskey, we've been drinkin' beer all night.
300sniper is offline   Reply With Quote Quick reply to this message
Old 05-18-2016, 10:00 AM   #146 (permalink)
Member # 102467
Edit: fuselage be spinning 500 rpm counterclockwise and the rotor is spinning 500 rpm clockwise, what is the airspeed of the blades?
Above or below the equator?
The party told you to reject the evidence of your eyes and ears. It was their final, most essential command.
I much prefer the sharpest criticism of a single intelligent man to the thoughtless approval of the masses - Johannes Kepler
LigBoozer is offline   Reply With Quote Quick reply to this message
