Trailer tire tech in GCC! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-02-2016, 06:52 AM   #1 (permalink)
Johann's Avatar
Member # 4251
Trying to rehab a venerable old 6x10 Enclosed trailer that is eating tires. I know there is a trailer forum but GCC will do for this level of tech.
It's wearing only the passenger side outer edge, badly. Goes through a tire in a few thousand miles. Not cool! Here is the tread wear. You might not be able to see that the threads are showing. It was more scalloped in wear pattern when there was still tread there.
Spring mounts seem sound. Rear hanger angle is not quite the same but not terrible. about 4* off.
Axle is bent upward in the center. Isn't there supposed to be some of that to counter bowing when loaded? How much is too much? It is a 3500# axle
This thing has been AROUND. Close to 20 years of heavy use toting our reenactment gear. Overland trailering our 3 canvas tents with stakes and poles, wood furniture, rugs, kitchen setup has given it a few knocks. We do not camp light.
I'm sure I have clipped that tire into a few curbs over time pulling out of gas stations that might have bent that side of the axle tube. It's come down hard on the springs a few times getting to and from camp sites.
So for $140 and a hours drive I can chuck a new axle under there. So far that is my plan. I do not have access to a press to try and straighten it. Is that spring perch angle a concern? Should I put a pair of springs under there too? I plan on keeping this trailer for the long...haul.
It's a Pace trailer if anyone cares.
Need reloading dies, brass and such for .351 WSL- PM me with what you have.
Johann is offline   Reply With Quote Quick reply to this message
Old 07-02-2016, 07:12 AM   #2 (permalink)
Change is good.
Roc Doc's Avatar
Member # 20631
I would get a new axle and keep the springs. And yes the axle should have bow to it and mounted frownie face style.
I get adds for ghey cruises.....
Anyone else????
Roc Doc is offline   Reply With Quote Quick reply to this message
Old 07-02-2016, 07:22 AM   #3 (permalink)
Johann's Avatar
Member # 4251
Thanks man!
Wouldn't be too hard to put springs in later if it really needed it.
Old 07-02-2016, 07:28 AM   #4 (permalink)
Johann's Avatar
Member # 4251
Edit:
Not sure how but double post!
Old 07-02-2016, 07:35 AM   #5 (permalink)
Under Powered
onlyonedr's Avatar
Member # 19543
Do the tire types match left/right? You will get strange wear like that if you mix bias and radial tires on the same axle. Are the bearings really sloppy on that side?
'01 Nissan KC Desert Runner: Work in Progress
'69 Chevy K5: Non-Wheeling Fun Rig
NOAS Club Membership Coordinator and Treasurer 2016-2017
onlyonedr is offline   Reply With Quote Quick reply to this message
Old 07-02-2016, 11:07 AM   #6 (permalink)
Brimmstone's Avatar
Member # 177990
Been down this road with the crew haul company. When I started the trailers were eating tires constantly. Before I left we ended up replacing the axle in almost every trailer they had.
Make a fixed reference point at the center of the hitch. Measure from the very end of the spindle to the hitch reference point. If reading is off you likely have a bent axle. Only saw two that had bent frames out of 27 trailers.
Brimmstone is offline   Reply With Quote Quick reply to this message
Old 07-02-2016, 04:10 PM   #7 (permalink)
Change is good.
Roc Doc's Avatar
Member # 20631
I'm guessing it has 3500lb axles or less? I bent two axles towing my 4000lb rockcrawler, they're just not very strong out at the ends. And you'll likely have to weld the spring perches on.
Anyone else????
Old 07-02-2016, 05:30 PM   #8 (permalink)
Johann's Avatar
Member # 4251
Yeah, 3500# dogleg axle.
Got another one from Agri-supply. Fortunately has the perches on it. Not that couldn't weld them but nice I dont have to.
Comparing the two it looks like the original was pointed 5* down on the tire wearing side. The frown bend of the original axle was more pronounced. Not sure if I bent it dragging it over something or it just was more bent from the factory.
The biggest surprise was that the tire wearing side leaf spring pack was 4 thin leaves and the other side is three- slightly thicker. Someone swapped one before I got the trailer. Not sure if they are considered the same rate or not. They both look OK. I am considering replacing one of them so I have two of the same construction.
Also thinking of hacking the ends off the old axle tube to use as tire/hub spare mounts. I carry two tires so I can keep driving if I have a tire issue. Had a tire loosen up and shear all the studs on a hub so I carry one as well. A hub issue will put you dead on the side of the road. Might as well have them mounted all together on the tounge.
@onlyonedr: Both tires the same. I went through the bearings after I had to replace a hub. Either could have been a problem so thanks for the suggestions.
@Brimmstone: Thanks for the diagnostic. It's bent for sure. Makes me realize I'm not the only one hard on trailers!
Old 07-02-2016, 06:48 PM   #9 (permalink)
WHEEEEEEEEEE!
gavan's Avatar
Member # 22597
Send a message via AIM to gavan
If you need a hand or further diagnostic drag it in up. You probably passed my house in the way to agri supply
gavan is offline   Reply With Quote Quick reply to this message
Old 07-02-2016, 06:57 PM   #10 (permalink)
Johann's Avatar
Member # 4251
I forgot you are out that way! I'd would have appreciated a second eye on it. I think I have it figured out but we will see what it does with the next set of tires!
Would have been nice to see what you have done with the miata. I'm sure the pics don't do it justice. Loved what you did with your Diesel jeep conversion.
It may not be my last trip to Agri on this project. If I head that way I'll give you a shout.
Old 07-02-2016, 07:11 PM   #11 (permalink)
WHEEEEEEEEEE!
gavan's Avatar
Member # 22597
Free test rides!
Old 07-02-2016, 08:05 PM   #12 (permalink)
Johann's Avatar
Member # 4251
Free test rides!
Do I need to bring my own "oh shit" grab handle or do you have one bolted in there for your passengers?
Old 07-03-2016, 09:55 PM   #13 (permalink)
Under Powered
onlyonedr's Avatar
Member # 19543
I'm also local, let me know if you need any help. Agri-Supply is one of my favorite stores.
Old 07-04-2016, 05:38 AM   #14 (permalink)
WHEEEEEEEEEE!
gavan's Avatar
Member # 22597
You can't really go anywhere.... You will be fine. Probably.
Old 07-04-2016, 10:16 AM   #15 (permalink)
Ditchrunner's Avatar
Member # 34517
OP:
Did your replacement axle include hubs or was it just the spindles? I have the exact same problem with my trailer and am fixing to order an axle. If there was a place reasonably local to buy an axle that cheap I would have already bought it.
Are most 3500lb trailer axles the same at the spindle? It would be nice to just repack bearings and swap my hubs over and save some coin.
Ditchrunner is offline   Reply With Quote Quick reply to this message
Old 07-04-2016, 10:35 AM   #16 (permalink)
Member # 49232
Send a message via Yahoo to Camarogenius
Most trailer axles, hubs, etc are Dexter style. Then you get the oddball chinee stuff that looks like a Dexter, but is just different enough that nothing fits right.
Camarogenius is offline   Reply With Quote Quick reply to this message
Old 07-04-2016, 12:28 PM   #17 (permalink)
Johann's Avatar
Member # 4251
Originally Posted by Ditchrunner View Post
OP:
It was just the tube and spindles. My hubs swapped right over no problem. Just check the spindle condition before you buy them. They were just saran wrapped for protection.
Slight differences included- replacement had cotter pins to hold the nuts on rather than the fold over tab that engaged with the castle nut. As well as the grease nipple not being centerline of the spindle. New one is Rockwell American brand. Old one is Dexter.
Old 07-04-2016, 12:34 PM   #18 (permalink)
Johann's Avatar
Member # 4251
Thanks man! I appreciate it. Yeah, I could wander Agri all day. Wish they were better at keeping stuff in stock though. Its a bit of a drive to just drop by.
I found at least part of my problem. Here is the spring pin from the other side
Just slightly bent! Missing the nut on it as well. Hope it wasn't the only issue driving the tire wear since it was exactly the LAST thing I noticed while I was bolting up the new axle tube. Probably lost it when I had the hub problem and lost a tire last year. Drug that side on the spring plate and ubolts. Replaced those at the time and still was having tire wear.
Old 07-04-2016, 12:58 PM   #19 (permalink)
Member # 49232
Everwhich. If you've had the trailer in service that long, a new axle is great insurance for your peace of mind.
Old 07-04-2016, 01:01 PM   #20 (permalink)
Johann's Avatar
Member # 4251
I keep telling myself that as well!
Old 07-04-2016, 04:23 PM   #21 (permalink)
Member # 686106
Check the bolts, and the springs have nylon bushings, replace those. get new shackles as well.
IF you have a good machine shop nearby that straightens axles, they can straighten trailer axles as well.
Out here West Coast Collision and Frame does it. trailer axles are best local because shipping would kill it, but they get housings, differentials, and transmission cases from all over the country to straighten.
SIR BLACKMAN is offline   Reply With Quote Quick reply to this message
