Any Duramax FICM experts in existence? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-18-2016, 09:45 AM   #1 (permalink)
larboc@hotmail.com's Avatar
Member # 70148
I've got an LB7 FICM on the bench that I'm trying to operate with a non-GM ECU and I'm trying to drive 8 injectors from an ISB.
It isn't firing injectors, I'm monitoring the CAN channels and I've got two CAN messages that I don't have definitions for.
I'm sending low side .5msec pulses for all 8 cylinders in firing order, I measured LCR on all 8 injectors and they are right around what an lb7 injector is (about .4 ohms R). I'm sending a tach signal to the engine speed pin that is a 50% duty cycle 0-5v wave with 2 pulses per rev.
I think I need to find someone who rebuilds or bench tests these to see if they can offer insight.
My next step is to buy the ECU for the truck and use that to read FICM diagnostics with a scanner.
Unfortunately these don't seem to fail like the Ford 6.0L FICM's do so there is VERY little info out there on them.
I don't pay nothing for anything.
larboc@hotmail.com is offline   Reply With Quote Quick reply to this message
Old 07-18-2016, 11:13 AM   #2 (permalink)
miniwally's Avatar
Member # 29513
I thought the Duramax FICM had some step up voltage and ran at 19V+.
Don't know why that's standing out in my head but it is.
miniwally is offline   Reply With Quote Quick reply to this message
Old 07-18-2016, 11:45 AM   #3 (permalink)
Member # 17596
I've read as high as 60
hpi_jeep is offline   Reply With Quote Quick reply to this message
Old 07-18-2016, 11:50 AM   #4 (permalink)
Member # 70148
That's pretty much what it does, it boosts the battery voltage up to 50-70 volts for the peak portion of the injector opening, then holds it at a regulated current for the duration of the injection event.
The early dmax used a separate module (ficm) until an ecu with injector drivers built in on board came around after the lly/lb7.
The FICM basically allows a gasoline ecu to fire diesel injectors because each PFI injector wire from the ecu goes to the FICM and low side drives the ficm's control wire.
