RUN FLATS - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-02-2016, 09:33 AM   #1 (permalink)
vanr's Avatar
Member # 422626
RUN FLATS
Our company has the operational need for utv/automotive run flats We are currently testing tire blocks in our UTV's, with great results.
https://www.youtube.com/watch?v=oA1gqeZcuxI
https://www.youtube.com/watch?v=ALn1BfWjb9g
For our automotive and off road needs/capability we are working with a company who uses a system called tire spines
https://www.youtube.com/watch?v=pr7JwGnoGDg
wondering if there is anyone out in pbb who has any experience with either of these system as an alternative to tireballs
y2kzr2
vanr is offline   Reply With Quote Quick reply to this message
Old 10-02-2016, 01:10 PM   #2 (permalink)
Extended Member
Member # 69765
For the Polaris rangers my dad has the tires filled some sort of foam. Never ever ha so any issues. Running over anything never gets a flat. I don't know if it's the same as the video above or a spray in foam. It's really nice though to not g flats from mesquit and whatever other stuff pops tires.
~ Kyle
2003 Montero
2006 Montero
Follow my adventures on Instagram:
Kyle_T is offline   Reply With Quote Quick reply to this message
Old 10-02-2016, 01:39 PM   #3 (permalink)
YotaAtieToo's Avatar
Member # 25632
That's all good for ranch/farm type stuff, but that stuff is super heavy and I believe makes the tires very stiff.
YotaAtieToo is online now   Reply With Quote Quick reply to this message
Old 10-02-2016, 04:31 PM   #4 (permalink)
vanr's Avatar
Member # 422626
Right, that is the exact reason why we did not go with foam . so far with the blocks our utv,s have met and exceeded all at speed , flexibility, handling , braking , cornering requirements to include operation with at least 4 rounds thru it
automotive has a whole new set of requirements and challanges
y2kzr2
Old 10-03-2016, 08:11 AM   #5 (permalink)
Extended Member
Member # 69765
No clue on weight but they squat and conform to rocks and stuff like air would.
Sent from AutoGuide.com Free App
~ Kyle
2003 Montero
2006 Montero
Old 10-05-2016, 03:03 AM   #6 (permalink)
vanr's Avatar
Member # 422626
can you tell me the weight of ea tire and what brand, maybe an alternative
y2kzr2
Old 10-05-2016, 03:16 AM   #7 (permalink)
BamaJeeper's Avatar
Member # 14620
You will be welcomed by whoever does your suspension maintenance when the tie rods, ball joints, tie rod ends, idler arms, shocks/struts, rack and pinion, and other components shit the bed prematurely multiple times before they should.
Tell your employees to look at the tires before they drive the vehicle. Train them.
I forgot. Common sense is everyone's friend.
Priest "The time has come to liberate the potential of the coming porkappocalypse."
BamaJeeper is online now   Reply With Quote Quick reply to this message
Old 10-05-2016, 05:34 AM   #8 (permalink)
Member # 84917
On my buddy's class 1 car, he runs Slime in all the tires, does a pretty good job, but still looses quite a few tires to sidewall blowouts ect.
If you live near Chattanooga TN, DON'T buy a car from Tim Short Mazda. Piss poor customer service!!!
Yesterday is History
Tomorrow is a Mystery
and Today is a Gift
That's why they call it the Present
blugreenformula is offline   Reply With Quote Quick reply to this message
Old 10-06-2016, 05:15 PM   #9 (permalink)
vanr's Avatar
Member # 422626
we can't have that , tire needs to be able to sustain continued operations for xxx miles without any air pressure
y2kzr2
Old 10-06-2016, 05:19 PM   #10 (permalink)
Member # 107967
How many miles do you need to go? Goodyear makes run flat atvs tires.
Pukemaggots is online now   Reply With Quote Quick reply to this message
Old 10-07-2016, 08:46 PM   #11 (permalink)
vanr's Avatar
Member # 422626
atv/utv tire must not fail with 4 556 holes in it 250 miles
auto must allow continued operation fo r250 miles
y2kzr2
Old 10-07-2016, 09:00 PM   #12 (permalink)
Member # 81619
One of my units tested these. I put 1500 miles on them in an up armored hummer.
https://i.ytimg.com/vi/i0xNzXTOXkE/maxresdefault.jpg
1st Recline Bn is offline   Reply With Quote Quick reply to this message
Old 01-24-2018, 07:42 AM   #13 (permalink)
vanr's Avatar
Member # 422626
Well, thought i would give you an update after one year of testing
Tire Blocks-excellent flat prevention, of the 14 units tested, 1 unit had a sidewall failure after 12 months of use/flat-sidewall cut caused. Pro-flat prevention works, Cons-expensive, special tools, a little too soft when coupled with no air
Tire Spines-Outstanding flat prevention, of the 14 units tested, no failures. Pro-flat prevention works superbly, even with no air, operation is unaffected, Cons-none listed to date
Tire Spines is also working to expand to road type tires in the future, maybe an alternative to balls and such.
Anyone out in PBB using either system
y2kzr2
Old 01-24-2018, 08:04 AM   #14 (permalink)
Member # 94747
Are those things cheap? I have only ever used tire balls and couldn't speak more highly of a company or product. I'm not sponsored by them so I pay full price for them.
Pros, any one can get them today, no experimenting, no waiting, everybody knows they work. You cannot tell the difference when they are in the tire, and you also cannot notice the transition of the tire going flat and the balls taking over the duty of holding the vehicle up. Tire case stability is still 100% when flat.
Cons, beadlocks required for install, special and expensive inflation device required to install. Will only last approximately 100 miles consecutively on a tire that is compromised to the point that it lets the lubrication out.
Assumptions, tireballs have to be lighter than the spine I would think. Probably about the same as that foam block system. The spine at least doesn't require lubrication.
[COLOR="Red"]MUDDNUTT racing #4531[/COLOR],[COLOR="Cyan"] Falken Tire[/COLOR], [COLOR="Yellow"]ADS[/COLOR], Jimmys4x4,[COLOR="Red"] RuffStuff Specialties[/COLOR], [COLOR="DarkOrange"]ARB usa[/COLOR], [COLOR="Wheat"]Savvy offroad[/COLOR], [COLOR="Silver"]Raceline wheels[/COLOR], John Rants
jr4x is offline   Reply With Quote Quick reply to this message
Old 01-24-2018, 08:13 AM   #15 (permalink)
Rednek
billybob_81067's Avatar
Member # 52387
Send a message via AIM to billybob_81067 Send a message via MSN to billybob_81067 Send a message via Yahoo to billybob_81067
About how much does the tire spine run for a typical ATV?
I hate it when companies don't list prices for anything or even give you an idea of what certain sizes cost...
The one, the only, the Dane.
billybob_81067 is online now   Reply With Quote Quick reply to this message
Old 01-24-2018, 01:16 PM   #16 (permalink)
vanr's Avatar
Member # 422626
I saw a post on their FB page that had prices, let me look for public pricing, and I have no affiliation or sponsorship with either company.
We looked at Tballs, however, due to miles required to run flat, we opted to try alternatives,
https://www.facebook.com/tirespineinc/
a few prices I saw
26x9x14: $185
27x9x14: $195
28x9x14: $205
29x9x14: $215 ...
y2kzr2
Old 01-24-2018, 01:51 PM   #17 (permalink)
arse_sidewards's Avatar
Member # 256962
Is that with or without a full load of donuts?
Old 01-24-2018, 02:08 PM   #18 (permalink)
vanr's Avatar
Member # 422626
With spline nuts
y2kzr2
Old 01-24-2018, 02:19 PM   #19 (permalink)
Member # 192237
The SHTF supply of operational doughnuts are small potatoes compared to the wife in the backseat with a NEF takedown 300 win mag for taking the long shots while they're laying down suppressing fire with their .357 sig glocks.
Don't forget to securely tape on the extra plates for sustained hits.
[486] is online now   Reply With Quote Quick reply to this message
Old 01-24-2018, 02:20 PM   #20 (permalink)
Member # 192237
Can the squad cars fit 37s with minor fender trimming?
Humvee tires and runflat rings are pretty cheap.
Old 01-24-2018, 03:25 PM   #21 (permalink)
vanr's Avatar
Member # 422626
Humvee tires and run-flat rings are pretty cheap.
Yes they are cheaper, but you are very restricted to lub packs and prolonged sustained speeds, along with change in handling characteristic. We wanted/needed something that offered more then just immediate ingress/egress.
Thus far, our ops love blocks, but splines even more. Evolving tech!
y2kzr2
